#2 Run stopped because errors were detected
6 o1 V, n$ V' ^7 X! ?: y R) Z, |' L1 i' B3 H
netrev run on Feb 9 9:12:59 2017
: O3 m7 c1 R! t; i' d4 W9 t, W DESIGN NAME : 'TX144'8 Q$ w& m2 n' L' \, P" _9 G2 U* ^
PACKAGING ON Mar 2 2016 00:37:24
3 T9 U! Y, m/ i5 s% H t _2 p4 U7 n
COMPILE 'logic'3 x) j& d; Z' Z/ a
CHECK_PIN_NAMES OFF' u, E/ s. {$ c7 T F* t
CROSS_REFERENCE OFF6 J9 x" x; E1 |; r8 \" R5 R$ d
FEEDBACK OFF
f, I6 d% ]+ P0 t! U7 s INCREMENTAL OFF! u7 U. r# L, z
INTERFACE_TYPE PHYSICAL
8 k# [( ^0 k) ~9 Y( r3 H MAX_ERRORS 500; V7 S: y6 c6 H3 y2 X
MERGE_MINIMUM 5
- s* B- i6 ^1 E8 P4 J NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
9 ?: K, l) Q: p% t! a& [/ N6 ` NET_NAME_LENGTH 24+ s* K' y0 g# k A1 D; H$ z
OVERSIGHTS ON* T6 H* p" J6 f+ x
REPLACE_CHECK OFF& e" ]) l) _$ b2 k5 W/ ]
SINGLE_NODE_NETS ON9 u* C' x$ Z a1 ]. P9 A' f
SPLIT_MINIMUM 0 ^# G/ \( a" g8 X
SUPPRESS 204 r& D; o% p6 p: j
WARNINGS ON
' a! D F. O: U" D, P- J4 r2 p D6 p4 j' q: b; g( y
2 errors detected
8 j s! n; Z+ T# r; s) m No oversight detected* \" ~& v! D9 L* m9 @
No warning detected$ }/ m& H! T9 k7 s
( t5 b# u2 k/ O! R3 `
cpu time 0:00:11
: N' ]4 V! P; x& P. \elapsed time 0:00:00
* @; H) S% j# I% W6 g3 l" ?$ o$ H) M
INFO(ORCAP-32005): *** Done ***8 h* Q- B b5 n/ j
2 k; F4 W1 z( \, w, e7 q, @
+ U6 j7 i0 _! `. ?1 w; r |
