楼主: penny
原创ALLERO转PADS文件视频教学-无声
    2024-4-29 15:07
  • 签到天数: 466 天
    [LV.9]以坛为家II
    16#
    发表于 2020-9-29 15:26 | 只看该作者
    :victory::victory::victory::victory:
    奋斗
    2022-3-26 15:36
  • 签到天数: 112 天
    [LV.6]常住居民II
    18#
    发表于 2020-11-5 14:38 | 只看该作者
    感谢分享,谢谢!
    2022-12-5 15:27
    22#
    发表于 2021-6-8 17:01 | 只看该作者
    看看怎么转的
    24#
    发表于 2021-7-10 09:03 | 只看该作者
    thanks a  lot  for your share this meths
    奋斗
    2022-10-13 15:25
  • 签到天数: 19 天
    [LV.4]偶尔看看III
    25#
    发表于 2021-7-15 12:56 | 只看该作者
    谢谢分享:handshake:handshake:handshake2 `- ~) b  u: O8 h/ T
    27#
    发表于 2021-8-8 08:31 | 只看该作者
    不断的看这个方法的资料,希望能成功
    擦汗
    2019-11-20 15:12
    28#
    发表于 2021-8-16 11:31 | 只看该作者
    谢谢分享,学习了
    5 Z9 ~' g! b8 Z# O" a. F; h
    30#
    发表于 2021-10-28 10:39 | 只看该作者
    ERROR: Unable to issue shapes for padstack C4_5TH3_2 - layer problems
    / z- N9 ]3 ^9 _1 a, j2 _ERROR: Unable to issue shapes for padstack R0_25X1_55 - layer problems
    1 m5 f0 G- d( I4 CERROR: Unable to issue shapes for padstack R2_05X7_55 - layer problems
    ' I+ R5 S4 B( l" Z. D/ O1 k1 N- [2 Q) kERROR: Unable to issue shapes for padstack VIA0805_via - layer problems8 S" t2 Q: s3 s: r, |
    ERROR: Unable to issue shapes for padstack C1_3TH0_7 - layer problems9 N: f  T. {2 |& J7 g- J
    ERROR: Unable to issue shapes for padstack C1_4TH0_89 - layer problems
    % B5 @" Z7 i; D! h/ w- |ERROR: Unable to issue shapes for padstack C1_5TH1 - layer problems$ Q( ~$ N5 W' Z/ b
    ERROR: Unable to issue shapes for padstack R0_5_1_2 - layer problems* K* D3 ?, X, k$ [8 z
    ERROR: Unable to issue shapes for padstack VIA045025_via - layer problems4 j, j* N0 ]6 d2 h! M( {3 J, H
    ERROR: Unable to issue shapes for padstack VIA0402_via - layer problems( E6 y1 N/ z6 q. D9 w
    6 i& U8 W' S4 c4 j' TERROR: Unable to issue shapes for padstack VIA0603_via - layer problems
    ' Q2 Q* x& x% t% G# ~, m& v; w% MERROR: Unable to issue shapes for padstack VIA0704_via - layer problems" \- X- N, O7 r3 a2 W# M7 i) {) U
    WARNING: Could not find placement outline for symbol 'JH_4X2_2MM' - using bounding box  Y7 F) {/ v5 n" N5 v4 O
    WARNING: Could not find placement outline for symbol 'USB_DX4R205JJA' - using bounding box
    8 t- K: p! W) uWARNING: Could not find placement outline for symbol 'USB_DX4R205JJA' - using bounding box
    1 z) o1 r; [4 z( dWARNING: Could not find placement outline for symbol 'USB_UB1112C-4K5-4F' - using bounding box- S! {2 e$ \* @* U
    WARNING: Could not find placement outline for symbol 'SWTT_ST-1114A' - using bounding box' N! U* V$ S: a! r
    ' \/ A4 g8 U( W/ w$ }# G$ k* n9 J( jWARNING: Could not find placement outline for symbol 'MX25L25645GM2' - using bounding box& n( T1 P/ T% }0 z$ L. n. ?; O
    WARNING: Could not find placement outline for symbol 'JH_1X3_2P54M' - using bounding box- _$ Y2 u) b" Z
    WARNING: layer OUTER_LAYERS not found in layer table.  Check the Allegro cross-section!- O4 a3 Y! _* i3 Q6 \9 E8 O. w
    WARNING: layer internal_pad_def not found in layer table.  Check the Allegro cross-section!
    - S* X% i  q, V; JWARNING: layer ~TSM not found in layer table.  Check the Allegro cross-section!
    5 n% n- S% z% Y. b& g( p/ n5 T% f1 JWARNING: layer ~BSM not found in layer table.  Check the Allegro cross-section!
    ) p) ]' n3 w* ^! N1 X9 ZWARNING: layer ~TPM not found in layer table.  Check the Allegro cross-section!8 _4 h7 B! d  F0 u4 ?
    WARNING: layer ~BPM not found in layer table.  Check the Allegro cross-section!
    . a6 L) u, Q- q9 E5 @WARNING: layer ~TFM not found in layer table.  Check the Allegro cross-section!
    5 E* H8 ?' ^* g. z1 NWARNING: layer ~BFM not found in layer table.  Check the Allegro cross-section!
    , Z( C- P8 d" J4 U" C3 E: J- dWARNING: layer ~ALV not found in layer table.  Check the Allegro cross-section!! ?( v# ?/ R. A( o9 g/ |! y+ B, Q
    ( |8 `! L7 ^( K/ i5 q* Q! b" f
    GMT+8, 2025-11-1 21:25 , Processed in 0.156250 second(s), 19 queries , Gzip On.
