查看: 4586|回复: 44
原创ALLERO转PADS文件视频教学-无声
发表于 2016-12-1 10:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本帖最后由 紫菁 于 2017-9-19 11:02 编辑 # ]; n3 p6 U$ G; t6 u+ k0 Q
6 |2 V* [# U- G5 N& S, @
手把手教你allegro转PADS文件方法。
& C) e5 G' Y4 [. Z1 M6 O; }小刚-制作3 i$ W8 T: ]8 d' Y% |
游客,如果您要查看本帖隐藏内容请回复
  n6 F! t5 [! |. e5 |
/ m3 ~% ^# u1 c! K
推荐
发表于 2021-10-28 10:39 | 只看该作者
ERROR: Unable to issue shapes for padstack C4_5TH3_2 - layer problems
7 b6 j" q4 Q0 }  ]' ~0 VERROR: Unable to issue shapes for padstack R0_25X1_55 - layer problems2 _( n# i+ {5 W  V. z9 y, D( T
ERROR: Unable to issue shapes for padstack R2_05X7_55 - layer problems
# s4 ]% \1 U* V0 H2 jERROR: Unable to issue shapes for padstack VIA0805_via - layer problems
$ }8 i0 ~( ]. e+ \7 MERROR: Unable to issue shapes for padstack C1_3TH0_7 - layer problems
0 r1 W4 c! B; y# XERROR: Unable to issue shapes for padstack C1_4TH0_89 - layer problems4 ?5 i& V4 S8 T5 w; C3 D
ERROR: Unable to issue shapes for padstack C1_5TH1 - layer problems
& U% `8 }8 o  s7 {/ FERROR: Unable to issue shapes for padstack R0_5_1_2 - layer problems- ?6 p  _# f, ]- E$ ]7 d- g$ Z
ERROR: Unable to issue shapes for padstack VIA045025_via - layer problems0 L& H( {% b7 O6 i7 f! \  @/ {  C. B- a) Y
ERROR: Unable to issue shapes for padstack VIA0402_via - layer problems: x# E. {) k" Z
% R- g$ |/ M3 @# P' _: @: WERROR: Unable to issue shapes for padstack VIA0603_via - layer problems
, d; @8 P2 H" X7 ?9 \& y7 H, oERROR: Unable to issue shapes for padstack VIA0704_via - layer problems" C4 a' S5 p& n2 r% Q* @' ~
WARNING: Could not find placement outline for symbol 'JH_4X2_2MM' - using bounding box2 ]. x" L0 X' I5 ^( d& A  |2 _
WARNING: Could not find placement outline for symbol 'USB_DX4R205JJA' - using bounding box
. D7 f; F8 O* m! ~6 H6 I3 qWARNING: Could not find placement outline for symbol 'USB_DX4R205JJA' - using bounding box
: p$ |( V! j! s0 [; {. }' S: h! V) xWARNING: Could not find placement outline for symbol 'USB_UB1112C-4K5-4F' - using bounding box0 w  a7 H2 O8 A3 W2 f/ H( P' b
WARNING: Could not find placement outline for symbol 'SWTT_ST-1114A' - using bounding box
# F1 @! B4 J, [4 o9 Y1 z2 w- OWARNING: Could not find placement outline for symbol 'SWTT_ST-1114A' - using bounding box) {$ a& Z' M  @
WARNING: Could not find placement outline for symbol 'MX25L25645GM2' - using bounding box
, r5 V+ g9 `; e/ W- N) ]WARNING: Could not find placement outline for symbol 'JH_1X3_2P54M' - using bounding box3 D8 L/ t& h& D
WARNING: layer OUTER_LAYERS not found in layer table.  Check the Allegro cross-section!
% E  ]* s0 a: z; d% D% RWARNING: layer internal_pad_def not found in layer table.  Check the Allegro cross-section!# l4 I& J! N1 r. [$ k( ~1 ?
WARNING: layer ~TSM not found in layer table.  Check the Allegro cross-section!( d% v$ o9 E- P& o; |
WARNING: layer ~BSM not found in layer table.  Check the Allegro cross-section!
' M. K; S% m% i! f. K6 EWARNING: layer ~TPM not found in layer table.  Check the Allegro cross-section!3 c1 p- g% B  P/ \( y/ B
WARNING: layer ~BPM not found in layer table.  Check the Allegro cross-section!
8 L3 E" b# o9 A. T: T7 SWARNING: layer ~TFM not found in layer table.  Check the Allegro cross-section!2 `' r8 y5 t+ L6 \. g' E+ |
WARNING: layer ~BFM not found in layer table.  Check the Allegro cross-section!& I% L: ^! O! ^; \! i% B
WARNING: layer ~ALV not found in layer table.  Check the Allegro cross-section!
# A( N; k0 u& w! Z! S  W; |6 @0 A7 L  l. ^
推荐
 楼主| 发表于 2016-12-15 15:32 | 只看该作者
304495297 发表于 2016-12-7 11:07
5 j4 ?: Q  B' b# ]: F! W& X概率性失败!!
) ~/ S0 g; ^; G2 @3 s: h+ M
这个不敢保证,因为软件本身就是不兼容性的
推荐
发表于 2023-3-2 16:46 | 只看该作者
看看                  , U9 s6 {4 d9 C& P5 e
发表于 2016-12-7 11:07 | 只看该作者
概率性失败!!
这个不敢保证,因为软件本身就是不兼容性的  详情 回复 发表于 2016-12-15 15:32
发表于 2018-9-14 10:09 | 只看该作者
看看,学习学习
    2021-11-13 15:29
    发表于 2019-11-15 13:14 | 只看该作者
    2021-2-20 15:47
    13#
    发表于 2020-4-7 15:55 | 只看该作者
    大神求助ad转cadence# U4 N! z) \% A" x
    2020-12-1 15:20
  • 签到天数: 38 天
    [LV.5]常住居民I
    14#
    发表于 2020-5-5 15:20 | 只看该作者
    看看,感謝分享
    擦汗
    2022-3-7 15:11
  • 签到天数: 334 天
    [LV.8]以坛为家I
    15#
    发表于 2020-6-15 20:26 | 只看该作者
    看看,感謝分享
    16#
    发表于 2020-6-17 14:46 | 只看该作者
    看帖不回者 么有小JJ.........
    17#
    发表于 2020-9-29 14:30 来自手机 | 只看该作者
    弱弱的问一句,铜皮会掉吗?我转的铜皮不见了
    GMT+8, 2025-11-1 21:25 , Processed in 0.203125 second(s), 29 queries , Gzip On.
