Preface page xi
3 C* P: D8 D$ _1 Introduction 1- Q1 `, H+ s- i7 c4 L0 ]* D
1.1 Background 1& P! T0 Y _. a$ j$ {8 Q
1.2 Applications overview 88 u& `0 C0 A+ A' N
1.2.1 Transmit optical links 88 k. ~8 Z8 n) v! S0 E
1.2.2 Distribution optical links 9) }7 ?* H9 p: Y( S& w: R& Y
1.2.3 Receive optical links 11' u+ q4 l* [9 }: N, ~2 m* _
1.3 Optical fibers 12
& V) O" W1 E+ N* E5 ^References 17
) T5 t# U7 @6 x6 Z% t2 Link components and their small-signal electro-optic models 19
5 M+ a& V( R! C- X! P& M/ i0 s2.1 Introduction 19 T! O5 x5 L I6 U# t$ M. k
2.1.1 Notation 20
) L u# v3 q& N. a/ I, ]2.2 Modulation devices 20
3 a' e9 ^$ [1 Z3 i2.2.1 Direct modulation 20% e: x8 \6 p/ H/ O8 J# N4 {) y
2.2.2 External modulation 34
1 `# e7 X b+ b2.3 Photodetectors 491 T/ G) V% L9 V! l3 @
Appendix 2.1 Steady state (dc) rate equation model for6 M) ^8 _" W" ~$ L- Y
diode lasers 546 J* v* L) ?/ C; r# T
Appendix 2.2 Absorption coefficient of an electro-absorption6 E0 f9 s3 A& x! |# F0 o8 g! _
modulator 63
4 D& p6 }& T/ I6 t" S) oReferences 63
3 O6 }/ t3 ?: l) C3 Low frequency, short length link models 69
7 U3 n6 u8 X U/ s% R3.1 Introduction 69; [+ G- x* x8 |# |# u5 b' o& g3 @
3.2 Small-signal intrinsic gain 70
8 p V" m- A' k4 b0 e3.2.1 Direct modulation 72* ]. w" t% h2 o3 j
3.2.2 External modulation 74
9 I8 D1 R$ U5 j) p) c" f d7 }3.3 Scaling of intrinsic gain 75
' |& v6 I; L, D8 i8 gvii; Q) o; S, O! z' d3 f& K/ Y
viii Contents/ g+ z1 L" N5 h; U( ~3 D
3.3.1 Optical power 75
, ]/ b$ x4 s9 }7 f3.3.2 Wavelength 79- _' T# P9 ?+ g Q
3.3.3 Modulation slope efficiency and photodetector8 l" A6 }9 X9 I0 E; a6 b6 L) J2 N
responsivity 813 e4 ~$ k: P0 V# T" x
3.4 Large signal intrinsic gain 82
2 O# }9 T$ y! W' d; mAppendix 3.1 External modulation links and the Manley–Rowe
: Z2 q/ [* I/ | sequations 87
( _' M, x8 C& H) h; m* HReferences 88
7 ^, d; k0 |+ A% H! M6 b4 Frequency response of links 912 D: N& |1 |+ A: A1 H& _
4.1 Introduction 91% O1 ^" h; b+ Q2 q3 n
4.2 Frequency response of modulation and photodetection devices 93( h9 h0 t8 O! B3 f) o! ?
4.2.1 Diode lasers 932 j1 R& N; L# ?: v
4.2.2 External modulators 98
' x L7 s: c( Z7 L/ U4.2.3 Photodetectors 1053 F& L* A2 A) t, n0 S
4.3 Passive impedance matching to modulation and photodetection, c. l+ D1 ]4 u- R
devices 1101 k- g: b$ Y! s
4.3.1 PIN photodiode 112* k3 `: V2 [( V8 W
4.3.2 Diode laser 117# W' I7 v' ]) h7 F& [
4.3.3 Mach–Zehnder modulator 129- A b. o5 Y- T3 i* F/ R9 I
4.4 Bode–Fano limit 1383 H8 H1 R7 ~8 i* D1 Q+ r
4.4.1 Lossy impedance matching 139; H/ ^, [' }5 I4 p" _+ ]# \$ @
4.4.2 Lossless impedance matching 142( ]& c% G' Y1 _7 J, B
Appendix 4.1 Small signal modulation rate equation model for# e2 W- P& Z% ~2 ] b! A
diode lasers 1521 b f6 \1 }1 U9 o8 O2 X3 r
References 1568 `) i5 g7 a( K* [! k4 s
5 Noise in links 159+ I. `$ }; ?( n G* O- S
5.1 Introduction 159
" c, b6 W V* z2 a: Y5.2 Noise models and measures 160
3 I* o1 [% X9 h- o2 w& F5 x5.2.1 Noise sources 160
, \6 T: c" _% P5.2.2 Noise figure 167
3 Y1 k( x, I, ]$ `; H5.3 Link model with noise sources 168
2 I5 W7 s( {* J: I6 G6 Q" T5.3.1 General link noise model 168# f5 u# Z/ V" z* d3 n/ e
5.3.2 RIN-dominated link 169' [- L$ @, C- Y, b0 t5 ]: o9 ?1 [
5.3.3 Shot-noise-dominated link 173* x6 P! J& | v3 y @
5.4 Scaling of noise figure 178
" ~+ N5 }/ G! v: w3 T5 f Z7 J9 E5.4.1 Impedance matching 179
* H& O \9 V3 z. @2 |) a' \5.4.2 Device slope efficiency 180* P* {" W* g i( f
5.4.3 Average optical power 182
3 S; d; p" c0 X% |5.5 Limits on noise figure 185
2 c0 R# K% C! o2 ^9 a/ H+ b3 R5.5.1 Lossless passive match limit 185
) |2 H% z- ?5 H" Q/ L5 X3 UContents ix2 d/ B- l* q0 I; z1 x2 e
5.5.2 Passive attenuation limit 187( M) Z) f; {5 `) B+ C4 I8 h& c
5.5.3 General passive match limit 189
5 ~2 A2 {3 ^) b1 _1 W IAppendix 5.1 Minimum noise figure of active and passive networks 196/ q/ V" Z# }- \2 K7 f* [
References 199
* [+ u" F7 [3 B- N5 ]6 a* P6 Distortion in links 201
; h" S7 A% \9 C- M6 v6.1 Introduction 201
6 Y) x8 W# Z) C4 K9 l' Z6.2 Distortion models and measures 2026 l/ U3 J w( {* M O
6.2.1 Power series distortion model 202
; `# g! k6 f3 S+ Z! @6.2.2 Measures of distortion 205# z, j; W+ }( w: e7 p9 s
6.3 Distortion of common electro-optic devices 217: R5 b0 `" y. [7 F3 Y, y( u2 I
6.3.1 Diode laser 217
# t- T! I' O/ R% }. x1 }, @6.3.2 Mach–Zehnder modulator 222; x1 X- n7 Q; {& c; I. M
6.3.3 Directional coupler modulator 2256 x, H5 p5 l: S8 y _6 W
6.3.4 Electro-absorption modulator 227
. U2 B2 U5 L1 j( o2 H/ i6.3.5 Photodiode 228
7 F4 C S4 _. T. q: Y: \) H6.4 Methods for reducing distortion 232- L8 c0 Q! ]+ ]2 Z7 U3 N6 Y: Q
6.4.1 Primarily electronic methods 233/ W7 g* `: {8 T* y* Q
6.4.2 Primarily optical methods 240- U, t! K5 \! G, H7 l
Appendix 6.1 Non-linear distortion rate equation model for% j3 k& E( e% [# H
diode lasers 249$ E1 u% k' [' C: Z5 V: [
References 259
Q! }$ p6 C! B& x A2 s' w$ @7 Link design tradeoffs 263% a' n; I4 y2 ?! e6 w6 i
7.1 Introduction 263
0 Q, Z5 ^6 _5 t- a7.2 Tradeoffs among intrinsic link parameters 263; I) i6 n' s/ Y D( ~9 {6 q' t/ h0 E
7.2.1 Direct modulation 263& G0 P- I( h _& B5 J" O' i
7.2.2 External modulation 268
0 D3 c$ B6 W4 w; F' f0 b7.2.3 SNR vs. noise limits and tradeoffs 273) _( t5 s3 l& F. u% h0 N/ ?2 Y
7.3 Tradeoffs between intrinsic link and link with amplifiers 277
- Q% ^9 W; q' @5 b0 j; B" D7 `7.3.1 Amplifiers and link gain 277
& d/ f! [' w( a+ U7.3.2 Amplifiers and link frequency response 278: z: |& l4 |' e" H7 V
7.3.3 Amplifiers and link noise figure 278% P( b9 O$ B$ }4 T; `% T2 H' a
7.3.4 Amplifiers and link IM-free dynamic range 279
5 W( b# b, M4 _6 R& P DReferences 284
. V; F" a) O) Z% U( E6 QIndex 285 |
