推荐
楼主 |
发表于 2016-11-17 20:02
只看该作者
VERSION 17.0.6
9 C9 ^% T% M# F% C2 I8 E% T* Y# [% G% N" S& L- Z |5 }
Build: 354 Date: 16 November 2016 ; v E R4 F4 K2 Q+ M1 T
' j# V( r, _4 ~) T! R) u6 b6 ~! o3607 Fixed a bug causing 3D holes to appear in the board with zero edge thickness (BC:149).
1 n8 `! P* V7 {6515 Fixed a bug that would not allow a STEP file to be exported to a folder whose name path includes Cyrillic symbols or an umlaut.. \: T8 [9 e- F/ [
6554 Improved mixed simulation with added ability to duplicate an existing waveform chart.
$ z" c+ e" E9 F5 N; s- l6569 Fixed a bug where Splitlines were missing from the Board Planning view.3 I7 \. M0 @) Z# X
7597 Fixed a bug causing Paste and Solder information to be missing from Gerber exports." B+ W- j# N7 N3 L6 h
7937 Added Zuken CR-5000 ASCII format PCB, schematic, and library files support for Import Wizard. (BC:1467)
: O8 e3 y8 l1 y) {# [+ T5 V: P8363 Improved Outjobs to support PDF/A for use as an Output Container.
; G6 x/ Q8 V' V9 I* c8691 Fixed a bug that did not auto-delete Unions that contain 0 primitives.: Z; a6 u1 f8 z6 ]& q8 T
8919 Fixed a bug causing incorrect IPC D 356 netlist generation.
f, {7 E+ E, }& }! n/ _0 A- U8929 Fixed a bug causing board Cutouts on board edges to be missing from exported STEP files.3 A3 |9 g$ Q- P* E' n( I. L1 D: J
8948 Fixed an issue causing STEP 3D flex sections to remain unfolded in the output.: ?' F. N) H" Q$ P" U; E9 Y9 x
8956 Fixed a bug causing Polygon Thermal Conductors to extend beyond defined polygon outline (BC:3936).' ~( X- a; N& |! u
9183 Improved BOMs exported to PDF, which now contain page breaks for increased readability and printing (BC:58).
! ^; ^: l: P+ n* q! }9241 Improved mixed simulation with the addition of a Simulation Probe Manager to optimize the functionality and flexibility of simulation probes.* @* q" W% [: t1 g& W: u( A- c
9476 Added support to automatically register all exporters and Save As formats as Export Outputs (BC:1324).
6 Q5 R: b6 S. V6 i2 l9 v7 X9 T9516 Fixed a bug causing Special 008E symbols to be duplicated during read/save cycles in Schematic documents.
4 W3 F% {7 H$ Q4 I9583 Fixed a bug causing redundant hollows in the core to be displayed around through-holes on the bottom side of the board.
6 e7 U) p t7 S2 y( X* `" B9598 Added support for simulation profiles to improve the functionality and flexibility of simulation runs.
; z" o6 L/ a) p1 B0 o2 j2 K9615 Improved Undo-Redo functions." i3 F) l4 @2 y. R8 V2 A* k) F1 \
9624 Fixed a bug causing Drill Pair Properties to not refresh in Via Stitching/Shielding and Via dialogs in Win7 with Windows Classic theme.2 S1 R: W8 L! R
9649 Improved PCB STEP with new option to export as a single part or as one model (BC:5582).9 R8 B; R' h9 G* G. o K8 L4 T$ O
9736 Draftsman now supports Ordinate (single reference) dimensions.
' v0 q/ }6 i" ~" B$ D8 E9751 Added a new back drilling rule, as well as 2D & 3D representation and support for backdrilling output to main fabrication formats. Back drilling information is also available for display in the Drill Table.. M# `5 C9 u+ C5 S. ?
9653 Fixed a bug causing zoom and scroll commands to behave incorrectly in a CAM document after importing Gerber files.$ a0 h2 a- R+ \; x7 n+ Q/ _
9676 Added a lasso selection tool for use in PCB documents (BC:962).; I' l4 G, Y: x! l" F
9966 Fixed a bug causing Altium Designer to crash on startup when username contains Korean characters.
/ |0 v* n( x, w1 P10007 Fixed a bug causing DIP .xls template files from the IPC Footprints Batch Generator to be mis-named.8 r$ B# ?8 |& ]1 s4 q1 U) i6 }. |& X
10127 Improved trace quality with addition of a new gloss command for use on selected tracks.% t: i. {, w" r1 [- `% o! x3 U
10235 Improved Polygon cutouts so they now produce corner-rounds for rectangular Pad objects and Internal Plane cutouts produce corner-rounds for rectangular Pad holes (BC:2940).6 ]: Q" q' N% G; D$ P0 s
10296 Fixed a bug causing AD to crash during xDxDesigner import.' N0 F0 s; I6 |+ p* }: U' y
10338 Improved Primitives Clearances with the addition of an Add Hole constraint (BC:5744).3 i$ a+ N0 M2 P/ W
10340 Improved the Clearance rule so only frequently used items present in the matrix now.
; v8 |, S# P4 P& |10341 Improved Un-routed net rule with new option to 'Check for incomplete connections' (BC:1119).' z7 j; d( ]! d6 @- G
10357 Improved Parallel Segment rule checks to exclude Diff Pairs./ U$ \- L) m, ~. g
10403 Fixed a bug causing catastrophic failure using Network Address.
: h4 K6 ?. {2 ` I0 g5 e10412 Fixed a bug causing Pitch1 parameter in SOT23 IPC Compliant Footprints Batch Generator to be handled incorrectly (BC:6245).
4 w7 j9 s/ p3 _. l" l q' d10679 Fixed a bug causing "Include Parameters from PCB" option in BOM Report Options to become unchecked (BC:2086).$ \, F( Q& }4 Z- E4 E ]' v
10876 Fixed a bug causing Messages about Parallel Port to be displayed when Altium Designer is started.$ ]: N* y$ b/ O8 S- W" Z
10877 Fixed a bug in Eagle Importer, where schematic parameters were incorrectly imported.
/ o& w2 i$ y+ \4 r6 Z4 e11007 Draftsman has a new Show Silkscreen option for Assembly View.& ~# m$ q) E4 [+ h" O6 Z
11010 Fixed a bug causing Allegro v16.6 import designator to assign 'Designator1' for all components.
; x% t/ m# Y1 Y. N$ D) K11201 Draftsman now has optimized speed in Assembly and other views.# i6 Z$ p6 g& p# v. [" r! y+ t
11226 Improved PCB footprints so that all objects within the footprint are connected to the same Net (BC:3488).
% Q4 @$ t$ Q( S' D/ K5 B$ }' c) \11403 Improved Interactive routing to include the display of Net Class info in the Head's Up Display and the ability to swap to opposite route point while multi-routing and diff pair routing.
/ |% b% V7 W8 R2 c- v" J11407 Fixed a bug where invisible objects in single layer mode were able to be selected.
, _1 p2 f9 I: ?2 h) ?- `0 z11425 Improved "Select Next" feature in PCB to be extended to apply when multiple traces are selected.
2 h4 r4 D+ s- i$ W; [0 V. J+ w* u11440 Fixed a bug where the Interactive Route Auto Complete shortcut (Ctrl+Click) was not working correctly.9 m5 L" _4 \3 k# G4 L/ S: J
11446 Users can now swap to the opposite route point for Multi-Route and Diff Pair Route.6 w: F' [3 e0 w
11455 Fixed a bug causing "Abstract Error" when searching for and removing an extension in the "Installed" section.1 z; l- i4 n1 g9 w o9 ^5 A
11554 Fixed a bug that caused a solder mask expansion to not generate in 3D and output files.# J+ z) @9 c0 Y$ Q/ N4 m& N
11689 Improved the Zoom factor specified in the PCB panel and Preferences so it can now be used for cross-probing from the Messages Panel for all PCB messages.( I7 H! r" S: A# X$ b% l
11722 Fixed an issue with loading the Ibis model after selection of the full file path.
" c* B! S6 R0 \) z! @9 D, D11728 Fixed a bug that caused a 'Net with multiple names' violation to disappear.7 o* M5 D* H" l
11793 Fixed a bug where schematic design elements did not stay within the grid in DxDesigner Imports.5 q5 Z- n' m4 C+ J( A
11838 Fixed a bug causing P-Cad pin lengths to import incorrectly.
3 |3 m' P2 Y" w8 c _11877 Improved the PCB editor with the implementation of Right and Left selection.
[$ O* s6 i0 A( f. P: Q0 U6 F+ e11878 Improved the Schematic editor with the implementation of Right and Left selection.* I" A5 j1 @0 ^+ Z* h
11879 Improved ability to use Tab key for expanded selection and Shift+Tab keys for iterating overlapped objects.
! n; n' h( @' C+ G11880 Fixed a bug causing overlapped objects to be cancelled during group selection when using Shift+Tab.! L+ j# k, B* @! l% ~1 u6 ?8 z" z8 i4 X
11884 Fixed a bug where Horizontal Scroll Bar is not displayed in PCB String Editor (BC:6364)
( |$ z, n4 a1 V, ?4 ^3 a11902 Fixed a bug where an exception occurred when attempting to import OLE objects./ Y3 x" x0 ^9 j$ y# i6 F' A" m
11913 Fixed a bug causing the Electrical Clearance Rule for Via against Via to not work.
: B8 t; \; U& v) d- r0 A( q11915 Fixed a layer sequence inconsistency between Layer Stackup and ODB++.# z: C) \7 Z; E0 C _. e
11919 Improved SCH component parameters, so they now synchronize with PCB footprints (BC:477).( A) l' d1 y7 h( b9 ?
11954 Fixed a bug where modifying the parameters of a digital SIMCODE model resulted in simulation errors.9 w: h# s8 }% V/ w8 X% \5 [
11967 Fixed a bug causing Snippet creation to crash when selection contains an Accordion.
4 \3 V( o( B. F11970 Improved ECO performance by optimizing the speed of Import Changes during the initial import on large designs./ e8 U# M z6 o
11975 Fixed a bug causing Room Width Rule to work incorrectly during interactive routing when the Board Outline clearance rule is also active.$ M5 a6 G4 ^* R* M
11996 Fixed a bug that caused the scrollbar for the PCB panel to work incorrectly.
2 y; F1 W8 `+ j' R3 Y+ z; [0 \11997 Fixed a bug where the Query Builder was missing entries when accessed from PCB.
9 z# p* @: p/ |$ ^1 o11998 Fixed a bug where using the * key in Board Planning Mode behaved incorrectly.+ i7 u$ N H# _3 w
12016 Fixed a bug causing 3D STEP export of Rigid-Flex stackupboards to occur incorrectly.
1 m1 |1 s Z- R8 M8 ~9 m12051 Added a new Pick and Place generator to select pick and place options before generating output (BC:999; BC:2067).- Z( H% {7 X1 F! r& V
12054 Fixed a bug, which caused analyzation to take a long time if the design includes From-to and accordion objects./ N: ~' i, F k. @& g$ F
12059 Fixed - Folder Structure Settings "Use Custom output file name" option for all outputers.- m/ R/ W) M4 T Z0 m
12076 Fixed a bug causing Electrical Clearnance Rule to not check clearances between split planes as well as between cooper polygons on signal layers (BC:554).. Y0 [$ e* b. c5 y* p" h
12077 Improved Clearance Rules by adding an option to Ignore Pad to Pad clearances within a footprint (BC:1817).& r" @) V0 Y; r% K4 }2 d# U8 O2 T
12080 Fixed a bug where moving tracks behaves incorrectly with PCB panel open.
) Q) c& i, u: e% o! T1 q4 Y12082 Fixed a bug that caused overlapping text in the File Format window.
% K# l1 I E. Q3 k/ M12092 Improved Smart copper editing to include options for merging and subtracting polygons, as well as the addition of improved editing (BC:1295).
5 g+ d2 `9 @1 L9 ^' V$ D/ `1 R, o; f12096 Improved thermal connection to include simple and advanced modes.# ?/ R" M/ w* v E
12109 Draftsman now supports 3DConnexion Space Navigator.% p' n$ H, D/ ?8 n. g. L+ d4 T. C/ S
12112 Fixed a bug where schematic output changes net label and port names to uppercase.$ p# ]' M, Y) Q8 O4 M
12117 Draftsman - Added ability to use several FAB views in document template (BC:7140).' l& M# \2 B; X$ S3 U
12131 Fixed a bug where the rule 'Silk to Silk Clearance' was incorrectly processing multline text.
2 {& j0 q, V8 ?& ~7 ~0 L# \! c12142 Fixed a bug causing Free 3D model positions to not store after STEP file changes.
4 F3 O5 o/ K9 m) @5 H12184 Improved ability to re-size unpinned panels to minimal dot size.+ @, M* ^0 A# s5 b; Z& a/ V2 X
12212 Fixed a bug blocking global update due to Altium Vault network activity option./ D ?3 w" }2 t2 _7 _
12213 Fixed a bug causing Flip component command to not work correctly for test point properties (BC:2971)., V, R' C2 N9 p1 T
12216 Several bugs in the Ibis model linking in the SI tool have been fixed.6 x1 m$ ~+ O, C" U+ r
12227 Draftsman documents have been improved to support Mouse Wheel Configuration (BC:6652)
9 g$ r1 R8 _' u; z1 p6 _6 b12228 Improved mouse wheel configuration settings by merging them all into one Preferences page.; B+ V" \# u( ~& y' V6 y8 z
12234 Fixed a bug causing 'Toggle Select Sheet Ports IO Type" to only cycle through Input and Output port types.- r; c. k+ }9 ~2 i3 T
12240 Improved Cross Select Mode now allows selection of various types of object and can be configured through the Preferences dialog.
8 p# o. I" a3 |& R: N. [12248 Fixed a bug causing Access Violations after deleting a variant with alternate parts created in a batch.$ x2 o, Z# V* Q1 _" g4 |
12249 Improved the Synchronize Ports to Sheet Entries window size to work more smoothly.
' d" A- }9 X) K1 m8 z12252 Improved routing with a new constraint for checking Hole to Primitives Clearances.) R/ @7 E8 q/ e
12270 Fixed an issue causing IPC Compliant Footprint Wizard to generate BGA 3D models incorrectly.5 e7 x: w R$ f ]/ c- t7 r
12298 Improved ODB++ outputs by replacing spaces with underlines for object names.
6 r' i- R- y: x/ i# K! h9 ]12302 Fixed a bug causing a rules difference between 15.1 and newer versions of AD.( q# |6 M6 r: ]' v
12304 Draftsman has added Dual Unit capability for Dimensions and for global Document Options (BC:6686).) C" ~+ _ @$ g2 j& u5 @) A
12306 Fixed a bug that prevented Mechanical Layers 17-32 from being added to All Plots in ODB++ Setup (BC: 6573).' s `; X0 }2 D
12310 Improved Polygon Pour to include a new constraint for checking Hole to Primitives Clearances.
, z+ f K0 B6 r, C: m12374 Improved software speed while using the PCB panel for object selection.
~! b/ g. Z0 w12390 Fixed a bug where probing waveforms during a transient simulation only displayed the Magnitude rather than Real value.% e# K0 X0 _) ~) |8 G& B
12419 Fixed a bug where SIM: Voltage source and inductor loops were reported incorrectly.( x+ u0 S4 v4 h- h. p" j# K& E, ~
12500 Fixed a bug causing Access Violation to appear when exporting to PCB from CAMtastic and "Layer Physical Order" option isn't defined.5 P' C' `! B+ u/ j f. X
12542 Fixed a bug causing the use of Shift+V shortcut when selecting routing via for template to work incorrectly.
3 M, T8 V3 e" @4 j, z5 u12569 Fixed a bug where redundant hyperlinks for Strings on PCB caused Access Violations.' V3 J% p( M0 T( w: Z
12678 Improved support for latest version of .Net.
9 i0 I( k% T3 j5 F12741 Improved routing menu by combining all route commands together under Route menu.5 e5 Y' D5 q. v9 c7 d& K
12799 Improved Allegro footprints import so that ComponentClearance constraint works properly by building artificial 3D bodies for certain components.
& m. p2 a0 D( \: Z12810 Fixed an issue when using "mm" in Report Rules.! |. J& z9 C0 m7 p0 Y
12812 Fixed a bug where STEP model generated with IPC Compliant Footprint Wizard for BGA footprint imported incorrectly when BGA package included a large number of balls.
) U+ g" t! q# m* ]3 T12846 Fixed a bug causing the xDxDesigner Importer to function incorrectly.
- d4 w0 m$ b0 f i+ _9 x12887 Fixed a bug that caused the "Arrange Rooms" action to stop working (BC:7046).
; e: w) E; k1 p4 l4 ^$ g7 z4 Q12937 Fixed a bug where sheet blocks templates are missing parameters in Importer xDxDesigner.
' i6 k( t1 q9 z( I5 |; r" g6 q$ {12938 Fixed a bug causing a constant error for Z-axis distance measurement between the board and 3D body face.1 y; J( C0 @0 D4 k+ z# S+ |9 |0 l9 V# n# ?
12987 Improved query language with new function which allows for the conversion of engineering notation from string to number. For example, StrToNumber('2K5', Ohm) > 2500.; V" r1 t, C" h/ V, z1 f- i2 B/ {
13019 Fixed a bug causing xSignals to break after updating from library.
4 ~7 w" \; ~; m# Y$ ?13043 Fixed a bug where custom icons disappeared from the toolbar.
2 i- [+ E' C3 E# k ?& C13082 Fixed a bug causing AD to lag while routing in 'Hug n Push Obstacles' mode.! w7 K# T% `* u, N6 x
13159 Improved components so they can be locked/unlocked from the PCB panel.2 m& L4 c R5 h8 d( j# V8 O1 i: s8 Z
13341 Draftsman has changed the default font to Arial.( q5 W1 S) }$ \& Q( e$ x, ~6 P* g
13348 Improved support for Eagle hierarchical schematic format.
+ |/ l1 d( P; w [' k13409 Draftsman bug causing incorrect bounding boxes for not-fitted components has been fixed.
" t8 I- P) w" C! I, } P13439 Improved FPGA by combining all FPGA and related technologies within one extension.
m) H! U2 b- m9 |; q0 N( a, Z" v13440 Improved Templates and Annotation menus which have been grouped together on the Schematic Design and Tools Menus.
" l* h6 J. Z1 S. F% e) Z13469 Fixed a bug preventing Designator autoposition from updating after moving a selection (BC:3534).
' y/ S$ v1 s! I {13471 Improved confirmation dialog when deleting mixed group of vias and traces with option to Ignore Locked Primitives.0 }6 V; v. z9 Z6 c* U4 y! W
13503 Fixed a bug where PCB printout sets were not using the correct layer order.
# ^1 ?+ F/ D: K13527 Fixed a bug causing layer order representation for blind vias to behave incorrectly./ v! P, {) ]1 r; O
13545 Fixed a problem in the Signal Integrity tool with using Ibis models of model type tristate.
2 T Q e' Y+ ?! R `) z6 O3 O; V5 j13554 Fixed a bug causing EOSError STEP Library messages when opening PCBLIBs.% O, i# x$ ~& v! t: G
13634 Improved Parameter Manager to reduce delay time when clearing multiple cells or a column.# j% L& Y7 i+ [, h
13644 Fixed a problem in the Signal Integrity tool causing false loops to be detected when arcs were present in the PCB routing.
; k9 `5 d# Q# s. F13663 Fixed a bug causing Access Violation errors when generating reports for Embedded Board Array.
, R5 X: |+ M- X9 b; a1 {8 J13664 Fixed a bug causing negation bar to shift in PDF output and Print Preview for Schematic prints.$ K# L2 H6 S3 o) W# l# Q' |
13671 Improved the performance of multi-part components.
/ \/ f/ x4 {6 j( O3 `' z13704 Fixed a bug causing artifacts from right and left selection actions to display on schematic documents.
6 o1 x" {) @5 H. G* R2 j13725 Fixed a bug where F hotkey was duplicated; U hotkey is now used for Full Circle in the SchLib Editor (BC:7011).
, w2 ]! q: q% V+ v7 J6 X8 ~- `13727 Draftsman - Fixed a bug preventing regions for Components from displaying properly when SilkScreen or AssemblyDrawing are selected as geometry source (BC:7009).% n: T, R& c$ k3 J2 n
13728 Draftsman now shows Outer Contour only for body projection.
8 X: N4 V& {; [2 {% p/ I5 d1 W% v13769 Improved the method to modify/edit/finish polygon borders (BC:1031).
0 ], d' J4 F! ?4 U( p7 `( ~1 `13807 Improved No Connect in Polygon Style settings by adding a field for Air Gap value (BC:1804).
# R- d4 A" W3 |8 G& g13809 The SIMetrix/SIMPLIS extension was updated to support version 8.0 of the SIMetrix software.; B# \1 {- K* v! K, c$ y5 b+ k; s
13819 Fixed a bug causing Access Violations when opening the Differences Panel in an unsaved document.6 J* I# V( X. x% E- h6 [0 [
13820 Draftsman: Added Default preferences for Ordinate Dimension.
+ I8 m+ M$ N) V1 d0 T e& i13857 Draftsman now supports Backdrilling in the Drill Table.
/ M5 p" |4 }5 F& R0 K, D14010 Fixed a bug in the Allegro importer that caused component origins to not match." a# T' n/ H6 H7 N2 g+ T( _" ~5 j
14059 Fixed an issue with Update From Libraries dialog: the 'Add models found in Library, but not in sheet' option does not work unless the 'Update which models are the current models' is enabled.$ }$ z4 y6 u, Q2 V7 R
14074 Implemented standard CAD right and left rectangle selection display.
7 t* k% q$ X2 u2 Z @* h14141 Draftsman - Fixed an issue with the graphics draw order being ignored in a PDF export via the File menu.
, v+ U( E' I7 Y r9 _7 j: z" A14192 Fixed an issue where component pins of a schematic in PADS are in a different order after importing into Altium.) @$ C+ y, u6 R. ^; n. _; p! U9 m
14308 Added a custom table for Draftsman.: g8 s, n3 V5 U) W% w
14345 Fixed a bug where big files opened via SVN fail on slow-speed networks due to timeout errors.( e' d+ y% G3 ] ^9 F
14381 Fixed a bug that allowed selected pins of a locked component to be moved without a warning using Ctr+Arrow keys.% }; V r! O" r) B( l+ g2 u: @8 S
14383 Improved routing menu by combining all route commands together under Route menu.1 i/ E0 \% p1 f( E6 B
14425 Cleaned up the graphic for the Dialog box button.+ o2 @0 `: x2 c7 O
14428 Added "Show in library panel" action to the Preview grid popup menu, if the library is installed.
- [( s8 M* k4 R14466 Fixed a bug in cross select mode preferences. Zooming option is now correctly saved and restored. |
