; |/ u* X t! G$ Q; T
挨打沒死六 官網討論版
! M9 F" j8 E6 B5 X& R: G4 ]$ J% K4 T. _/ f* `
問題:
, G" G1 w% i" Y" S5 g% p& k! LDear expert,
5 ^" W9 c6 ? g! L& wIn i.MX6SL platform, we use eMMC for data storage. Do we need the pull-up resistors at the datas (data0 to 7) and CMD signal?
5 X6 P" V/ V) u0 W+ O$ P' S9 x- qthanks,
. L/ a- l a' Y1 ]8 H& E. Y& J- r' z: ~) ?5 H# N
回覆︰
9 f7 M/ ?, V; R2 z: yThere is no special requirement for external resistors pulling up regarding the i.MX6 SL eMMC interface. You may look at the i.MX6 SL EVK design schematic.* A4 z' q6 }) X* v
. v, m6 [1 p7 i5 Q2 R1 o. s According to JEDEC specs :
* a' D- _' z0 S; c$ W! T/ Z“JEDEC eMMC includes internal pull-up resistors for data lines DAT[7:1]. Immediately after entering the 4-bit mode, the device disconnects the internal pull-up resistors on the DAT1 and DAT2 lines. (The DAT3 line internal pull-up is left connected.) Upon entering the 8-bit mode, the device disconnects the internal pull-ups on the DAT1, DAT2, and DAT[7:4] lines.”
! t8 ?% }4 Z7 } ]& J
' h5 c6 |# W( y9 m2 s8 q3 e0 Q& y & n8 Q7 y- `& k, [
" b6 k/ o5 j; _7 _ |
