查看: 14259|回复: 6
PADSVX.1.2 Free Viewer
发表于 2016-9-13 09:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
To install the pads Free Viewer:
  • Before     installing the viewer, disable virus shields and screen savers. If your PC     is unable to support Java-based installations, change your computer’s     language setting to English.
  • Download the     viewer from http://s3.mentor.com/pads-free-viewer/pads-viewer-1.2.zip     and save it to your hard drive. The file download size is approximately     142 MB.
    / \. f: h8 E3 G2 ?     2 B1 ?3 o% Y: c, F. m0 j( e$ f
         Your Activation     Code is* Y/ N9 \4 o9 I8 n4 q3 ~$ o& m0 |4 x
         9Hpi26QBWQBWaBX.
    # y# ]7 U2 ~1 f
  • Use the Extract     button to unzip the file. Save the contents to the directory of your     choice, being sure to preserve folder names.
  • Double-click the     PADSVX.1.2_Viewer_mib.exe file found in the (unzipped) installation     folder.
  • Enter your     Activation Code when prompted. Use Ctrl C to copy the Activation Code and     Ctrl V to paste it into the Activation Code dialog box. Once installed,     the PADS viewer will run without expiration. You may use it as long as you     like.5 X/ N" e! u. {1 a0 S/ t
9 }* {& R8 N* n
 楼主| 发表于 2016-9-13 09:19 | 只看该作者
可以点击下面的连接申请免费查看版本的软件% L0 F2 y$ [8 B" E! \! d) J) R
https://www.pads.com/request?&am ... b-9689-01bf88ddbb8a
发表于 2016-9-13 16:44 | 只看该作者
怎么都没有pads vx1.2 professional 的学习资料?
    2025-9-27 15:17
  • 签到天数: 1051 天
    [LV.10]以坛为家III
    发表于 2016-9-14 10:46 | 只看该作者
    免费查看?有什么用?
    奋斗
    2021-3-10 15:58
  • 签到天数: 11 天
    [LV.3]偶尔看看II
    发表于 2017-8-29 14:37 | 只看该作者
    我把9Hpi26QBWQBWaBX中的X去掉就可以安装了,原本还说激活码有误
    发表于 2021-8-8 10:50 | 只看该作者
    感謝大大無私分享
    GMT+8, 2025-9-28 10:39 , Processed in 0.125000 second(s), 23 queries , Gzip On.
