查看: 1022|回复: 1
分享:Altium Designer V16.1.11(AD 16.1.11)
发表于 2016-8-20 10:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
下载链接:http://www.dongeasy.com/hardware-design/pcb-design-guidelines/1908.html( a4 K' T- t2 o) f* e
Version 16.1.11
) F5 Y8 v+ R: ]! U
Build: 255 Date: 20 July 2016! m& O1 L9 `7 t- Q  _2 \
11409  Added support for the SOLIDWORKS 2016 parasolid file format.  C5 K- i' N) G$ p0 O9 i8 A
12701
8 c$ o  D( M/ m8 P6 |Fixed a critical issue in the PCB Editor where arcs were being multiplied during interactive routing, or track! C' h- \5 ^6 K9 w7 n$ z1 O
modification (BC:6843).
! a- V* _. j" {12625" i7 `7 q0 v7 z' h1 g: [' D4 x; H
Fixed an issue in the PCB Editor where the 3D Lock option was not being taken into account properly for
0 u: Z& z& I7 q2 K  x$ Yrigid flex designs.
2 [  E  }9 X7 E3 |  E  U5 C12708
3 E" i# ]4 z3 ^7 i- ^5 ?. ~/ FFixed an issue of duplicated leasing of on-demand licenses, which was otherwise possible when the software
2 R$ |, L4 w8 J9 D2 ~0 z! Zstartup time took more than 20 seconds.$ S! u) q* M1 q3 X; r9 n+ J
12525  Fixed an issue where 3D Body Height Rule checking was not considering the real height of a STEP model.
* d6 \3 n: d0 L& ]12628
5 ^/ n5 z! ^. _; WFixed an issue where pads of components – with Alternate Parts in a defined Variant – were being incorrectly- n( ^; A" F2 ?  t: B$ c5 T1 [* a
displayed in Draft mode on the generated assembly drawing.
, U# J- k, B) y4 P; W+ Q12522# Y  F  |& v( @8 ~* \, @! [
Fixed an issue where special strings in footprints were not being correctly displayed as converted, after9 M. h  P/ E! w5 N
generating a footprint comparison report.
  L9 o! `0 N& k+ A11988! ]+ p/ J( Z8 p2 w) z  u
Fixed an issue where special symbols – in the User Name or PC Name – were causing a constant exception
* O  ~  L9 p6 Q1 S/ J1 qduring PCB Collaboration (after connecting to an altium Vault and opening a PCB file).
  Z0 M' r  F  w' M12513  Fixed an issue with the incorrect rotation of the QFN and PQFN STEP models in the IPC Wizard (BC:6692)./ U! c8 h9 d4 r, E1 ?. m
    2022-9-26 15:32
  • 签到天数: 30 天
    [LV.5]常住居民I
    发表于 2016-8-20 17:36 | 只看该作者
    Altium Designer V16.1.12  出来了 给个链接
    GMT+8, 2025-7-17 20:37 , Processed in 0.093750 second(s), 23 queries , Gzip On.
