第 22 頁︰* ]- ]7 M; V, z& e7 s( \" q
Figure 67 shows a high-side current monitor configuration. Here, the input common-mode voltage of the amplifier is at or near the positive supply voltage. The rail-to-rail input of the amplifier provides a precise measurement, even with the input common-mode voltage at the supply voltage. The CMOS input structure does not draw any input bias current, ensuring a minimum of measurement error.
( L& O" r" K5 q: h* Y2 Y: r9 z# t& F& u z& E6 Q- K
魔鬼藏在細節中!
) }) p5 L" G' i% B+ S3 l( g* t7 p( V0 ^+ r% |& `( L" ?5 X# ^/ e
" l( J+ B* l. k: W% o0 ?! w |
