查看: 2425|回复: 1
2015的license问题
发表于 2016-6-30 10:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ADS其它部分用的好好的,在仿真PCB微带线的时候就完蛋了,请教一下谁有 好办法
. m: R' i0 P+ i1 VLicense check returned: Momentum Object* ]- h; M& _. R) K- S* Z) D
/ Y0 ?- G* F( d, `License file signature is invalid6 F' _) q/ h. k- [$ ^
0 T# J! O7 N) A- R8 p! g
Possible Causes:
, @: k& z! @9 i% E7 C9 R: Y1.        The license file was altered.9 U) q! Y$ K/ c, f' P# U
2.        The license file was created with an invalid key.
  [& I; t! W3 y' u3 [' u9 d
+ F1 b) s& X* kTroubleshooting Tips:7 w) T' A8 v5 d/ ?
1. Do not alter the license files unless directed to do so by Keysight tech support.
% _& T8 K& _! N4 N( d! v2. Obtain a valid license file and restart the license wizard.+ }: S' n7 o  y& T' Y2 _; Q# V9 L
0 H- F. C9 ^7 R
License Requested:  mom_obj; b0 Z8 z8 n$ t
License path:  C:\Program Files\Keysight\EEsof_License_Tools\bin\license.lic
7 h  G# f4 [) ]0 H# g.
! R0 o, i' z/ H, E  M8 p" Y--- ERROR ---------------------------------------------------------------------. ~6 `2 L5 R7 a& B% k
2 H0 n/ d. [* h1 z( F+ C
License not available
, ~( \/ K& G( m! e. u' @
: r7 e: _! c; K$ M6 `6 v# r  q7 Q# K0 _2 |9 V( {' r
. g& O: t9 j* n1 x' t3 k
9 E2 _; h" A" X
发表于 2017-8-1 10:57 | 只看该作者
我也是其它用的好好的。画图页面。用File>design parameter,这个功能,出现没有license这个错误,其他能用。
* r1 o! u- V: o, f) B, q
GMT+8, 2025-9-12 16:15 , Processed in 0.125000 second(s), 23 queries , Gzip On.
