Replacing Selected Symbols/Parts * P2 o8 j# _, n4 v: b
8 {5 k1 p V' N' }3 S% I- gProcedure
6 N2 d* C# t0 s! ]( ^ 1.Select the symbol you want to replace.
4 p' f) }" k7 S 2.Choose the Edit > Replace Symbol menu item or right-click > Replace Symbol. The Replace Symbol/Part dialog box opens.5 U5 u, u9 g, q' b* `- E
3.Click Browse. If it is not already visible, the CL View tab of the DxDataBook window appears.
/ P$ L4 g# K2 w/ K0 R* x 4.Select the replacement symbol. It displays in the Replace selected symbol(s)/part(s) with: field.
) ^) R5 J' Q7 o! x 5.Return to the Replace Symbol/Part dialog box and specify options to control the replacement.9 b: R# Y9 E+ W6 L% D0 j
6.Click Replace.
?9 ?$ w2 J- O$ A. R! k2 L |
