RIPUP_ETCH FALSE;
0 w" i3 j1 A8 X9 o( I4 o) GRIPUP_DELETE_FIRST_SEGMENT FALSE;
( R) N I( E2 B! N3 K% p, s, oRIPUP_RETAIN_BONDWIRE FALSE;
% u: Q. |: t' ^2 k" r* MRIPUP_SYMBOLS ALWAYS;, y. k U5 A9 S% B
Missing symbol has error FALSE;
1 T3 c7 O7 r+ Y& U: q. A% e0 nSCHEMATIC_DIRECTORY 'xc4v1x160';
, C& _6 [, q( |+ ?BOARD_DIRECTORY '';
2 |; V& C2 q% f& IOLD_BOARD_NAME 'E:/works/cadence/sch/6416/sch1/physical/xc4v1x160.brd';$ `* f& a, q/ x8 \" |* o
NEW_BOARD_NAME 'E:/works/cadence/sch/6416/sch1/physical/xc4v1x160.brd';' B( S5 t2 ^2 Y3 |( W# ?4 q% C9 D
1 L1 }5 E- Z. b' V+ ~, p* {2 x
CmdLine: netrev -$ -i xc4v1x160 -l -y 1 E:/works/cadence/sch/6416/sch1/physical/#Taaaaaa07068.tmp \$ n j0 b I
. r1 r+ r! S% @; P. m. U& |, m, q------ Preparing to read pst files ------
: Y' G' |3 {9 Y% l' i4 M/ M! T: \* H6 a1 C: n8 C2 W, f' S
+ l* `2 B8 n. ?/ \" d
#1 ERROR(24) File not found
3 x% r6 L( t. l Packager files not found) L' X* t: h4 x/ s9 M' u9 S
5 z1 y" a. Q* V* ]; Z+ C9 F2 |
#2 ERROR(102) Run stopped because errors were detected) `" N0 A2 B" D6 P* n! A0 l( Z
9 q9 e K# F, g; q. R" unetrev run on Apr 2 19:40:44 2016# [$ L9 Z; j4 C: [6 v$ B& t1 a6 C1 R
6 b3 Q3 s6 h4 ~* _+ F# |$ ^% \1 u COMPILE 'logic'& R# [$ z d3 g: @/ Y2 [ |/ e$ T
CHECK_PIN_NAMES OFF
$ x. q( J! X, z! [ CROSS_REFERENCE OFF
! b) a8 w4 G6 ?3 I1 [. N2 x FEEDBACK OFF
9 U8 m9 o! A; h: `' }( a3 Q$ Q2 r% I: ^ INCREMENTAL OFF
$ E: q- g& M. L. d# a& I INTERFACE_TYPE PHYSICAL. @$ [ n) y4 w
MAX_ERRORS 5002 M" K, m8 X( A9 I0 \3 t0 m
MERGE_MINIMUM 5* G# t5 e9 k; ]. ?8 R( Y
NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'# A2 { K5 L0 M
NET_NAME_LENGTH 24; G3 p( u4 K" q: s* k
OVERSIGHTS ON1 t8 W, p4 P! Q/ u9 R2 |* [) _
REPLACE_CHECK OFF
7 Q! Q* l- p* ]; Z SINGLE_NODE_NETS ON
8 G! L0 w% e! o/ F7 A SPLIT_MINIMUM 0
& m. G* O: w0 W' \ SUPPRESS 20
. @) X: K- Q/ }$ m WARNINGS ON
6 V8 c9 N& A5 t# C/ d8 ~! X% K& l
5 h- |# y( P, k+ X 2 errors detected
( y( ` D1 r! c+ m# w& h6 H No oversight detected
0 |/ w- U- U& y2 S3 ~5 ` No warning detected
/ i+ V X: p6 _- Y7 M+ t$ K; r
' P, r" W0 Y! wcpu time 0:00:35: s) A8 {; v! a5 t! A: y7 }) e2 J: I
elapsed time 0:00:00 |
