查看: 3548|回复: 8
请教:DRC报告文件上的错误
发表于 2008-10-30 15:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
PCB图进行DRC检测
! g: [% H0 R& D选择其中Clearance Constraints Max/Min Width Constraints Short Circuit Constraints 和Un-Routed Nets Constraints 这几项(请大家帮忙看看是什么问题,我是自学的protel,尚不熟练,请指教!谢谢!)) P9 T+ b2 M' m7 c' u5 T
结果如下:
4 X2 y( ~% m9 E' r+ qProcessing Rule : Width Constraint (Min=10mil) (Max=10mil) (Prefered=10mil) (On the board )) s. @1 R7 y+ @+ g
   Violation         Polygon Arc (6033.874mil,6670.183mil)  TopLayer  Actual Width = 8mil$ Q  h1 {, Z) e
   Violation         Polygon Arc (6019.943mil,6665.654mil)  TopLayer  Actual Width = 8mil3 O7 I" I6 A! L  e. I
   Violation         Polygon Arc (6006.011mil,6661.126mil)  TopLayer  Actual Width = 8mil
# [4 l& i& P" B) K7 Y$ U. @- x+ K   Violation         Polygon Arc (5992.08mil,6656.597mil)  TopLayer  Actual Width = 8mil
/ r5 G- V; l2 U( X7 ^+ z……/ p9 a0 N/ A( k( B$ q
More than 120 violations detected. DRC stopped!
9 S* J$ ^& l; l0 d' I( W
. |, G2 N2 u3 V9 L# l2 Y
发表于 2008-10-30 15:53 | 只看该作者
地的规则违背了你的规则设置,把Min=8mil一下就可以了。另外Max最好在30mil以上)
参与人数 1贡献 +5 收起 理由
zyunfei + 5 热心解答
 楼主| 发表于 2008-10-30 16:23 | 只看该作者
谢谢指点!
8 ?! W1 o6 \6 M6 I& i我把规则改了,新的问题出现了……还请再帮我看看!  M1 k) E% N6 w7 h6 `
Processing Rule : Width Constraint (Min=8mil) (Max=10mil) (Prefered=8mil) (On the board )( L4 m4 Y# q; }8 t6 ^
   Violation         Arc (5794.822mil,4170.178mil)  TopLayer  Actual Width = 15mil/ D. j  T1 X4 s; F2 i7 l' V
   Violation         Arc (4932.201mil,5212.855mil)  TopLayer  Actual Width = 12mil5 x9 X! S; ?' W
   Violation         Arc (2558.006mil,6528.006mil)  TopLayer  Actual Width = 40mil. u. H6 \1 J2 n& u# h4 ]2 Z5 z2 q; p
   Violation         Arc (1769.887mil,6846.113mil)  TopLayer  Actual Width = 18mil' C  z6 w; [8 b
   Violation         Arc (2561.373mil,3711.373mil)  TopLayer  Actual Width = 30mil. d: K$ @8 M0 _2 K/ N. U4 N$ g
   Violation         Arc (6674.519mil,3869.968mil)  TopLayer  Actual Width = 50mil; ]. |. R" ]4 o- u+ ^7 C
……5 H. O' ?+ U. P
发表于 2008-10-30 16:59 | 只看该作者
还是同样的问题啊 哎!!只不过超出了max
发表于 2008-10-30 19:42 | 只看该作者
楼上正解,max设置的太小了。
发表于 2008-10-31 08:20 | 只看该作者
总结楼上两位的话:
8 {0 B- C$ q: u! v9 ~: q% Z你出现的问题是——你实际画的线超出你的规则里设置的范围' K; b. }# K) m; z, D
你的设置是:线宽min=8mil max=10mil Prefered=8mil
) O. Q5 l" W8 W/ x" T8 Z7 U0 @2 x你实际的宽度有15mil: k: w- y* M: Y1 C0 z6 b: @
                            12mil- v, Q8 P/ A0 Z' n
                            40mil4 R- I+ o0 B+ y( O: F# p# S4 i
                            18mil( a+ I) {5 u3 Y
 楼主| 发表于 2008-10-31 10:59 | 只看该作者
谢谢大家哈: k* K/ V# Y9 Z2 H( M/ m0 R
我的问题似乎比较浅薄
. N  R) \1 r) [; z4 ?我再仔细摸索摸索
/ z3 I. H/ X0 _, I; `假以时日,争取提出更具难度的问题* G4 e# [& z8 {0 s$ ^$ L$ X
, z) w+ h0 L+ N6 z/ [% P- J, E. g# g/ ~
我把设置的max得改成80mil了……) z# d0 G# D6 ^! v4 A& I
终于没有报错了
' s5 e$ Q" u1 f& R# a2 T& e! c( A4 i8 b  R& s9 U6 m' D/ R, C" z* b
可是,max这么大合适么?
- }8 `7 ~8 W# t如果DRC检查没问题了就可以交厂家做板子了吧?
' c# ^, U7 P: q* q第一块板子,希望一切顺利啊……
发表于 2008-10-31 14:26 | 只看该作者
Max和Min只是你规则限定的一个范围(这样方便检查一些定性的错误),而不是实际制板所用,实际制板 是用的你 所规定的值
 楼主| 发表于 2008-10-31 15:10 | 只看该作者
嗯嗯,谢谢!
GMT+8, 2025-8-19 22:59 , Processed in 0.125000 second(s), 25 queries , Gzip On.
