看了论坛上知道NC Route出椭圆,方形焊盘,还有些不明白,不知道具体怎么做,哪为高手可以指点一下,网上看有人加个ncroutebits.txt文件,添加后提示以下,还有就是cutting path怎么回事?
1 }/ _0 ~ b( [* a' y* h/ O7 r! `" [9 J
Processing NC Parameters file ...
1 I- u5 X9 }) [ _2 j NC PARAMETERS; E; I- b' n( c; t
-------------3 P D0 z0 j) W
FORMAT 2.3 P+ D: j# U% H% @: K
MACHINE-OFFSET x:0.000000 y:0.000000- M/ H# m6 g4 A
FEEDRATE 14 H7 X5 X$ D( ^) M' l! x4 T
COORDINATES ABSOLUTE: i6 g l( O) u9 T y- J4 y
OUTPUT-UNITS ENGLISH5 L/ y$ ^- J- }$ b) M
TOOL-ORDER INCREASING
, T# I. Q0 U; o' ` REPEAT-CODES YES
4 {3 y* U( k5 Y3 X e' q$ a SUPPRESS-LEAD-ZEROES NO
4 ~5 T* f5 _ H2 O8 p7 v2 L SUPPRESS-TRAIL-ZEROES NO
& s8 x+ J* C. k; Z9 A1 `, j& ~ SUPPRESS-EQUAL NO
5 x, E0 p( e7 s4 F2 k3 Z TOOL-SELECT NO4 F3 v1 u* A7 {
HEADER none7 C: J7 \2 S; c5 [+ ~4 t
LEADER 12
: J2 e, I( u8 P, O$ O( i1 O CODE ASCII
# h2 V3 V1 G$ m) G SEPARATE NO& k' Y$ y& y" ~/ j6 q: ^; _
OPTIMIZE_DRILLING NO
1 q/ }' O2 {; t5 y ENHANCED_EXCELLON NO
3 M: k& c8 v/ d SCALE 1.000000 y: y5 I" Q( y( G: N
+ y4 \' |( l+ d: w# u0 J Processing route path data ...& m3 c7 c) U3 j+ }
WARNING: No route path data was found for processing!9 o+ H) z' x# h$ `7 P/ L
------------------------------------------------------------- L+ `9 |/ S0 q3 F$ }0 q
Processing slot hole data ..., T" s" w, L) [7 y7 o7 n5 Y* _
Processing tool file (ncroutebits.txt) ...2 ]4 [5 V% E) {2 V4 v" d
NOTE: All units are assumed to be inches.# V5 I' i( R7 H! z E
0.6 T200. j) r+ G% F, M, h
0.65 T201
) z% f! {0 H6 o$ U) _' s1 Y2 V 0.7 T202
+ `+ k" Y& S3 M8 n% W( T Z 0.75 T203& C) r- I+ p0 J1 }* z
0.8 T204
8 U. V3 @6 ]# S( A) M' ?: k; X 0.85 T205
; ?3 ?9 M# k1 \1 k3 b 0.9 T206
4 y2 P$ r- ^& C 0.9271 T207
+ u3 _4 {- }8 k 0.95 T208: n# S& t1 E, c2 v$ F
1 T209
. L7 Q* v2 I9 M9 b" }' W" {. | 1.05 T2104 U7 c# m& q, q2 E' ~
1.1 T2116 p8 Q! c$ u" u# w0 L
1.15 T212; A+ t0 B) L6 V4 o5 ~, \: p
1.2 T213
; |+ X' Y) H+ I 1.25 T214
9 s' }+ n3 m: y$ d4 k2 G! w8 k 1.3 T2158 I" F9 X& d( K9 Q0 q% p
1.35 T216
; N4 s& e$ D7 [$ s3 p G8 \ 1.4 T2176 U2 O1 t: e4 f5 Y
1.45 T2180 D! v- O% r7 }7 I
1.5 T219$ W0 B& V- \; t+ s
1.55 T220) H3 Q& C$ ^2 W, I) [: ~7 L
1.6 T221
7 O- [& W4 r- D 1.65 T2227 g- _6 m3 `6 \0 r
1.7 T223
. v9 ?7 T+ V0 d# ]4 Z2 T/ j 1.75 T224& m, T' d+ P9 |) \7 ?; x: M/ J @
1.8 T2254 ?6 K6 V( ]- u4 h% p
1.85 T226- [' T; ^6 ^+ Q1 X+ A7 r5 N$ r- g
1.8542 T227
8 |% c/ i& ~" l8 ~, ^' L# v 1.9 T228
5 f* U3 I. _ @" K3 y, \$ J1 S# H1 @ 1.95 T2296 x$ e$ ^ o: W+ C6 |
2 T230
) c8 x" \7 e f; C! q6 l 2.05 T231
8 b4 j5 K$ t( P% }3 B 2.1 T232( T) u( _+ @8 ]
2.15 T233
2 w) e5 Q5 f0 X, `+ A$ H! \( G 2.2 T234
2 R* X) z. Z; J: q" q# _, m( b 2.25 T235 S, ~7 Q/ l! t/ `1 j( x9 h
2.3 T2369 R1 B; F3 b# L0 d
2.35 T237
6 `8 h' f9 T. q& o7 {. x 2.4 T238% {4 G x; P9 X
No errors found.0 a# `. m# B+ M' ]% I7 y0 K' g4 A
4 s$ z4 T" l# v2 T WARNING: No toolcode of a size the same as or smaller than 39 found for an OVAL slot!: R4 k3 ~- v+ V. Z P% B* a% z
Defaulting to T01 as toolname.# L' J1 M$ n# d% w/ r. L
. T- Y/ D' r4 ^6 d4 z1 K9 Y( o Defaulting to T01 as toolname.. Z9 l7 X6 \) i$ M j7 r% K3 e1 _# \
7 T: G5 `) Q. \ Defaulting to T01 as toolname.6 D8 N& g3 w. o; U/ x
OVAL slots routed: 3
/ W" A) t. V* B6 D- } RECTANGLE slots routed: 0
6 C6 T& ^5 y3 Y, z7 M1 U L2 S-------------------------------------------------------------
; V, G1 @! a. C1 }7 E* H( G: L NC Route file BDPCB12.rou created WITH WARNINGS ... Program completed. |
