查看: 4977|回复: 26
Hotfix_SPB16.60.066_wint_1of1 百度网盘分享
发表于 2016-3-6 20:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
链接: http://pan.baidu.com/s/1kU2nqxp 密码: wbh3 ) P+ O1 C/ _% j( p
/ P7 k$ [+ O, ?  w# @
, W0 v: s7 D( i/ K1 n觉得好就帮忙顶一下吧!" ?# W$ f' Z. [' |; S% k) t
参与人数 2威望 +4 收起 理由
rhamppk + 2 很给力!
yueyuan2003 + 2
    郁闷
    2023-9-28 15:01
  • 签到天数: 16 天
    [LV.4]偶尔看看III
    推荐
    发表于 2016-3-8 09:32 | 只看该作者
    DATE: 02-26-2016   HOTFIX VERSION: 066: u9 a0 D3 q4 _# L9 D
    # ]+ H7 q: R% wCCRID   PRODUCT        PRODUCTLEVEL2   TITLE6 Q4 x7 p6 h( N$ |
    7 r# F* N$ `9 ~4 `& H# I, S7 p1523426 ALLEGRO_EDITOR DRC_CONSTR       Dynamic shape not adjusted based on keepout; DRC generated4 s3 l7 L% D2 P$ Z8 h; S* j9 o) S
    1526729 SPIF           OTHER            Exporting a dsn file causes PCB Editor to crash - in the interactive and batch modes/ d" `7 W; C; M; E# K6 f
    1529209 CONCEPT_HDL    CORE             When adding a component symbol version, the More option does not show all the versions
    & i! v4 H- `: p3 U7 ^1530888 ALLEGRO_EDITOR INTERFACES       IPC2581 does not generate production files and fails with a segmentation fault message
    2 _: d2 E& R5 q' W6 D1532865 CONCEPT_HDL    CHECKPLUS        Provide the ability for Rules Checker to report a GND symbol from the standard, and not our local library, in .mkr- J# M1 [* T8 g8 j8 ]
    1536273 CONSTRAINT_MGR CONCEPT_HDL      Model-defined differential pair is removed, and Constraint Manager Design Differences does not report an issue5 o0 B0 z: T8 _3 t) c# \
    1538343 APD            OTHER            Inconsistent behavior when running Reports > Design Summary Report in Allegro Package Designer2 F$ Q: O9 k- `- j7 Z
    1539077 ALLEGRO_EDITOR SYMBOL           PCB Editor crashes when choosing Layout > Renumber Pins
      P* b2 b% J& S( [4 {4 Y1539997 ALLEGRO_EDITOR SKILL            PCB Editor crashes when the axlStringRemoveSpaces() command is run: p. r% \2 s# G' G2 N  C  E
    1541445 APD            DIE_EDITOR       There are two Recent Designs submenus in the APD Symbol Editor; one should be removed
    - t% p  K7 m3 l: p& i
    推荐
    发表于 2016-4-14 23:10 | 只看该作者
    你好,楼主,最新的破解补丁是从哪个网站找的?
    2021-7-21 15:48
  • 签到天数: 51 天
    [LV.5]常住居民I
    推荐
    发表于 2016-3-21 14:38 | 只看该作者
    多谢楼主的分享!给我们带来最新的补丁程序!
    发表于 2016-3-6 21:46 | 只看该作者
    支持你,但是,,,,好像有人发过了
    发表于 2016-3-7 09:20 | 只看该作者
    顶!破解和065一样吗?
    发表于 2016-3-7 09:26 | 只看该作者
    好快的 更新速度……。支持了
    擦汗
    2019-12-12 15:00
  • 签到天数: 13 天
    [LV.3]偶尔看看II
    发表于 2016-3-8 18:15 | 只看该作者
    謝謝大大的分享囉..
    发表于 2016-3-9 00:26 | 只看该作者
    支持一下/ z6 C! b# A% ]8 ?
    謝謝大大分享
    13#
    发表于 2016-3-9 19:06 | 只看该作者
    帮忙顶,感谢分享~
    14#
    发表于 2016-3-13 18:02 | 只看该作者
    顶顶更健康
    2025-6-10 15:51
    15#
    发表于 2016-3-14 16:28 | 只看该作者
    谢谢分享  辛苦了=
    GMT+8, 2025-9-30 21:40 , Processed in 0.140625 second(s), 29 queries , Gzip On.
