查看: 1191|回复: 3
AD16.0.8,已经发布,求个链接
发表于 2016-3-5 21:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Version 16.0.8
Build: 354 Date: 04 March 2016
8925
DRC markers layer is not being erased from the design anymore. It also being restored for the boards, that have lost it in previous versions.
9177
No error longer shown while modifying Vault list in Preferences
9182
Pin description are now being transferred to symbol during generation in Symbol Wizard
9229
ItemManager - Fixed component duplication after editing with defined custom grouping
9409
Both TGZ and ZIP archives are generated for ODB++ output
9445
User is now being properly notified if pcblib download has failed
9453
"Failed to get component template item revision" is no longer happens, if template with non empty comment is being defined for the folder
9466
"Visible in Vault panels" property of lifecycle state is now properly supported in Vault Explorer
9480
Fixed error in folder tree generation by PDF container in outjob, when "\" was not forcing sub-folder creation (BC:6137, BC:6123)
9512
Multiline text now properly display variant parameters in concatenated strings.
9519
Update from library do not show fake changes for the footprints with several identical extruded bodies on top of each other.
9534
"Builderstate RenderNodeManager" error is not happening any longer, while working with View Configuration
9561
Item Manager - Error "Can not change selection of record" does not happen anymore, while peRForming Auto-Match operation
9570
Common engineering notation is now used for unit-aware parameter data types in a Component Library (centi- is now used for length only) (BC:6068)
9605
"Missing file" error does not happens, while performing preview with had copy containers in outjobs (BC:6104)
9613
ODB++ tgz file output is now corectly structured to contain root odb directory.
9618
Overlay graphics for components marked as 'Not Fitted' are now properly displayed in Assembly Drawing outputs(BC:6100).
9638
"Access Violation" crash does not happens while accessing Tool menu on WindowsXP
9640
MCAD origin moves properly when board shape move operation is being cancelled
9646
Octopart links are now less aggressive in the UI.
9678
ItemManager - Footprint is now selected automatically, while updating component to latest revision
9694
"Default Checkout Path" parameter for SVN repository is now saved properly
9732
Fixed customizing dialog for menu/toolbar commands: now it properly handles image files of different formats
9839
Keepout regions are not longer exported to PDF3D
9949
Updated Japanese localization
10023
Fixed floating crash while releasing component templates to the Vault
10184
Crash, when multiple pad in one point is being selected, does not happens anymore.
10448
SQL error no longer happens, when where-used information is being process for the Vault model with more that 1000 references
10608
pads on mechanical layers are no longer ignored during an 'update from library' operation
10609
altium Designer no longer crashes when exporting a board containing a Design View, into STEP format
10832
Altium Designer no longer asks for repour confirmation, after modifying a polygon pour (BC:5936)
10891
An issue has been resolved relating to the display of board regions in embedded board arrays, when viewing the board in 3D (BC:4553)
10892
Use of the Align Vertical/Horizontal Centers feature - from the Align Objects dialog - no longer results in objects being shifted
10913
Generation of Gerber X2 fabrication output has been modified slightly, to comply with Gerber X2 Rev 2015.10.
10929
Opening a PCB that features via shielding, no longer results in an exception violation
10930
Long strings are now displayed in their entirety, when editing through the String dialog
1 M! y) ^; \2 {9 Z6 I
发表于 2016-3-6 21:47 | 只看该作者
https://www.eda365.com/thread-118017-1-1.html4 P( U/ M* C. F
这里有大神分享了。速去下载吧
发表于 2016-3-18 17:33 | 只看该作者
http://pcbask.maihui.net/article/78
发表于 2016-6-3 13:33 | 只看该作者
这么快,去看看
GMT+8, 2025-9-27 18:18 , Processed in 0.125000 second(s), 24 queries , Gzip On.
