* H, q) M% q0 L/ Y: Z2 s% O. \4 v2 Q4 ]
多谢!之前没勾preserve currente prefixs,所以重排一直有问题。现在重排可以了,但是回注的时候提示Unable to read physical netlist data.2 C* s( N; m( p4 R4 r3 l3 c! L
求解,这个怎么破?
( d/ ]8 P- ?: C8 P' J5 ~) |
7 O( I7 m, ^0 C# I! }下面是log,能否帮忙看看,谢谢!
4 L8 B' u0 W- c' m4 |
( @& h6 F. e% o# T" e8 Q# y7 B( Q/ ^Spawning... "E:\Cadence\SPB_16.6\tools\capture\pstswp.exe" -swp -d "D:\SPB_DATA\6735\YYW-M-6735-DEV-10-20160306.DSN" -n "D:\SPB_DATA\6735\ALLEGRO" -s "D:\SPB_Data\6735\rename.swp" -c "e:\Cadence\SPB_16.6\tools/capture/allegro.cfg" -hpath "HPathForCollision" -backwd1 ]6 a3 w e$ R! `* l2 m) j- Y
unzip: cannot find either feedbackview.cdsz or feedbackview.cdsz.zip.
# H K# ~1 z: Q* v G' b& iINFO(ORCAP-36108): Starting the Swp file dumping process ...2 S/ c" Q$ f/ n7 \. D
Loading netlist files ...( J1 F- m$ t) p! D* ~
Loading... D:\SPB_DATA\6735\ALLEGRO/pstchip.dat
. m' M/ C% v* M5 W, ?
) ]! D5 K) K Q4 d) s: u0 o7 XLoading... D:\SPB_DATA\6735\ALLEGRO/pstxprt.dat8 v4 Z( {3 p- R, G
, _7 H! Y# O& ~% ^5 w) g. h( zLoading... D:\SPB_DATA\6735\ALLEGRO/pstxnet.dat5 m$ \ k, O' ~! p
packaging the design view...Loading physical design view ...Loading... D:\SPB_DATA\6735\ALLEGRO/funcview.dat
2 m* h& R- N# B, s$ K#549 ERROR(SPCODD-549): No physical part found for COMP_DEVICE_TYPE=PJ-393_PJ-393_PJ-393, regenerate the netlist to sync with Allegro board.
9 L5 l/ [5 K" u. R( z ERROR(SPCODD-516): Line Number: 1786 m& I) {1 |* t2 T8 |( U' L
#1 ERROR(ORCAP-36027): Unable to read physical netlist data.- x% \, ]8 P3 s5 T. M/ h7 J
#2 ERROR(ORCAP-36025): Aborting Swap file creation... Please correct the above errors and retry.* y! p- {1 T/ t; J
7 i" q! i. ^# t: U t+ EExiting... "E:\Cadence\SPB_16.6\tools\capture\pstswp.exe" -swp -d "D:\SPB_DATA\6735\YYW-M-6735-DEV-10-20160306.DSN" -n "D:\SPB_DATA\6735\ALLEGRO" -s "D:\SPB_Data\6735\rename.swp" -c "e:\Cadence\SPB_16.6\tools/capture/allegro.cfg" -hpath "HPathForCollision" -backwd8 `' p0 P7 [! ~4 l/ ]( o
INFO(ORCAP-32005): *** Done ***
) W% s. `5 l( _
. c# g3 d3 g# @) M- @; P9 l8 b0 H! \+ n
! R5 \/ h7 C, c6 N; k$ w
; k$ b2 h% @: I0 [% j- ~
