记得用软件自带的用户手册。! Q$ k; K! `2 c, X$ K
Importing from Capture to Design Entry HDL & v; l+ J9 x% {
To import a part from Capture to Design Entry HDL, do the following in the Import from Capture to Design EntryHDL Dialog Box:
# t' j# C: ~/ X C( |5 TSpecify a library in the Library text box by typing the absolute path to the file or by selecting it using the browse button. The Part drop-down box is populated with names of parts in the selected library.
% y7 M ~$ T8 @' q N- TClick a part to select it. The Aliases display box is populated with all aliases of the selected part. + {$ ~: \7 S6 K4 M. y/ V' e; V
In the Options group box, select one of the three radio buttons to indicate whether you want to import only the master component and not the aliases, each alias as an individual primitive, or each alias as an individual cell. ( Z# C6 I0 g" {! k j: s; [' B
In the Design EntryHDL group box, select a library from the Library drop-down box. 1 X5 {7 g2 M- Q9 i2 C7 s
Click OK. The Capture part you specified will be imported into the library you selected.
+ X6 ~8 F4 E8 y: u6 R6 @3 w4 `% H
! y7 N2 Z4 g! I N8 M6 |+ l# W( ]补充内容 (2016-10-27 13:32):9 U- N3 e0 ]9 y5 |1 X
concept---> capture:# k$ T# r5 f: B5 A( ?* |( e8 B
Allegro PCB Librarian XL --- part developer --- File --- import and export --- export capture part(windows only)
( m B. e6 B2 t! Ycaptuer---> concept:/ A$ { f3 ^ \: g1 m
Allegro PCB Librarian XL --- part develop... |
