新手刚开始学习HFSS,在做180度环型电桥的例子时,按照教程上面的步骤一步步操作,仿真时出现如下错误:9 W- \) w5 I2 c
[error] Fast sweep setup, process abc3d : "p1" mode 1 crosses cut-off in the specified fast sweep range. Consider splitting the sweep into multiple ranges. Use a port-only discrete sweep to locate the cut-off frequency. K& y1 W# P" S" s9 o1 D1 H( s
[error] Simulation completed with execution error on server: Local Machine. 求大神指教,谢谢! 3 N8 q# Z+ {2 ]/ N
