查看: 2822|回复: 8
matlab2015b64bit和谐文件
    2025-10-2 15:00
  • 签到天数: 704 天
    [LV.9]以坛为家II
    发表于 2015-9-29 19:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    # u/ k7 d- ~9 K% R- l6 Z% m& [, x) }2 F( P
    专业版license,可以支持80个feture。
    3 }# s9 Y- d8 t+ N+ x- a4 _MATLAB                                                Version 8.6         (R2015b)' c- Z' w! v& o
    Simulink                                              Version 8.6         (R2015b)
    ( Q0 a. O& N$ C: T) v Aerospace Blockset                                    Version 3.16        (R2015b)
    ( [' S7 x; e0 F# k3 d6 m Aerospace Toolbox                                     Version 2.16        (R2015b)
    : ~' r* f4 |  z: A5 N! l Antenna Toolbox                                       Version 1.1         (R2015b)
    : V( E/ c+ r/ q0 p( n. ~2 N. W Bioinformatics Toolbox                                Version 4.5.2       (R2015b)
    & ?% |5 c* J5 N+ l6 q Communications System Toolbox                         Version 6.1         (R2015b)8 D5 s* u! o" \' W% Q1 x- r$ b! U
    Computer Vision System Toolbox                        Version 7.0         (R2015b)! Y# o# G3 u* H& B% s
    Control System Toolbox                                Version 9.10        (R2015b)1 t6 ?. y% G) v' l1 e
    Curve Fitting Toolbox                                 Version 3.5.2       (R2015b)
    , G. t+ Z0 p4 u7 D' C8 `3 M' [" u DO Qualification Kit                                  Version 3.0         (R2015b)" b( r  e* S/ ~' q1 l
    DSP System Toolbox                                    Version 9.1         (R2015b)) e7 _" h  L1 ?0 ~0 q# _0 n# p9 j& P3 W
    Data Acquisition Toolbox                              Version 3.8         (R2015b)0 z0 c$ g. {" {* Z" ~/ J
    Database Toolbox                                      Version 6.0         (R2015b): o  m% C3 Q6 g
    Datafeed Toolbox                                      Version 5.2         (R2015b)
    9 \+ F0 c1 s! y, K6 ~% B: ? Econometrics Toolbox                                  Version 3.3         (R2015b)
    ' s$ I# H; D7 h# h, v6 @5 P Embedded Coder                                        Version 6.9         (R2015b)( I2 L1 R! h& P% v
    Filter Design HDL Coder                               Version 2.10        (R2015b)
    # N6 G% }1 Z; j1 G1 m: C Financial Instruments Toolbox                         Version 2.2         (R2015b)8 x; `2 b' V2 x5 Z
    Financial Toolbox                                     Version 5.6         (R2015b)
    # B% ~) x6 z, ], s Fixed-Point Designer                                  Version 5.1         (R2015b), z$ W$ m" v% c* B. ]+ Z$ K
    Fuzzy Logic Toolbox                                   Version 2.2.22      (R2015b). x6 G0 I/ V5 z- }4 h9 A) |
    Global Optimization Toolbox                           Version 3.3.2       (R2015b)
    2 @$ W# h3 s2 R$ M0 d5 ~ HDL Coder                                             Version 3.7         (R2015b)
    0 v. e+ ?% n3 ^" B/ |$ J HDL Verifier                                          Version 4.7         (R2015b)
    4 e" @* _* s; q. @8 e! r IEC Certification Kit                                 Version 3.6         (R2015b)
    ; u5 l! b5 w$ L Image Acquisition Toolbox                             Version 4.10        (R2015b)9 x. `  w0 I' m
    Image Processing Toolbox                              Version 9.3         (R2015b)
    / \) h& q7 e2 \4 R& j+ I Instrument Control Toolbox                            Version 3.8         (R2015b)
    5 ~6 U. `* C0 R4 n% `; X LTE System Toolbox                                    Version 2.1         (R2015b)( W& G  g) {( Z' [
    MATLAB Coder                                          Version 3.0         (R2015b)7 U. T8 w3 ]8 h3 P: |+ M) I
    MATLAB Compiler                                       Version 6.1         (R2015b)
    9 k4 K& ~5 G. e) }$ j# f$ T MATLAB Compiler SDK                                   Version 6.1         (R2015b)
    7 @8 @" u5 Q0 {7 k! v( W MATLAB Report Generator                               Version 4.2         (R2015b); Q0 v& o. V- u8 i5 ?: {
    Mapping Toolbox                                       Version 4.2         (R2015b)9 \+ u, r, x; I' L- s
    Model Predictive Control Toolbox                      Version 5.1         (R2015b)
    / Y! [' N+ O0 B; T+ l2 M Model-Based Calibration Toolbox                       Version 5.0         (R2015b)
    & x( z: j, M6 v* S: f  b) ]& ?* @ Neural Network Toolbox                                Version 8.4         (R2015b)
      b5 T3 K; J1 X) J4 D OPC Toolbox                                           Version 4.0         (R2015b): G# n0 \  H  v+ `" U
    Optimization Toolbox                                  Version 7.3         (R2015b)( s9 [* D$ P) B0 q
    Parallel Computing Toolbox                            Version 6.7         (R2015b)
    8 _" W* P) t* `8 B1 N Partial Differential Equation Toolbox                 Version 2.1         (R2015b)7 ?9 ^9 g; g2 |4 `6 f
    Phased Array System Toolbox                           Version 3.1         (R2015b)
    ' `3 _0 z/ t6 ~ Polyspace Bug Finder                                  Version 2.0         (R2015b)% {5 D$ e# i/ w
    Polyspace Code Prover                                 Version 9.4         (R2015b)* A; P- U! }! }* Q% P$ h
    RF Toolbox                                            Version 2.17        (R2015b)/ z- H# j; b, d0 J% G% V
    Robotics System Toolbox                               Version 1.1         (R2015b)' |% e. p9 P& d" w
    Robust Control Toolbox                                Version 6.0         (R2015b)
    $ e( h8 ~+ L$ y- l2 k9 g' \1 q7 D2 N( [ Signal Processing Toolbox                             Version 7.1         (R2015b)
    # y3 H/ j" a+ I/ U4 s9 }  I SimBiology                                            Version 5.3         (R2015b)5 v, J2 \* K. @, ~' W( D; ~0 j
    SimDriveline                                          Version 2.9         (R2015b)
    # I% B$ b1 b  j, Z" [ SimElectronics                                        Version 2.8         (R2015b)
    1 G, c0 T; @& ~/ J3 T SimEvents                                             Version 4.4.1       (R2015b)/ Z* M/ T- Q" P2 E6 {
    SimHydraulics                                         Version 1.17        (R2015b)
    + e! n  f# n. ?7 S; {* y  k SimMechanics                                          Version 4.7         (R2015b)
    - t' ~- B  i! D; s SimPowerSystems                                       Version 6.4         (R2015b)% W5 [. \3 [$ s( R$ o3 V/ ]# p9 g
    SimRF                                                 Version 4.5         (R2015b)' v: S( ?/ r' P* a! |) R
    Simscape                                              Version 3.14        (R2015b): i' M5 M# X! o! Q) o
    Simulink 3D Animation                                 Version 7.4         (R2015b)6 n8 K4 Q% o# y& G" l8 [: i: C2 {
    Simulink Code Inspector                               Version 2.4         (R2015b)
    & i  Y6 e8 q' @( l+ s& K: ~/ M Simulink Coder                                        Version 8.9         (R2015b)/ w7 e3 G0 |" k0 C' q6 x, Z
    Simulink Control Design                               Version 4.2.1       (R2015b)) a( Q+ R2 k- r$ D. y; E) t
    Simulink Design Optimization                          Version 2.8         (R2015b)
    " H* C' t3 d- S4 F Simulink Design Verifier                              Version 3.0         (R2015b), q9 j' |: N: V& k
    Simulink Desktop Real-Time                            Version 5.1         (R2015b)
    " j1 _) f( Y: D8 d: Y0 h5 C. b3 f Simulink PLC Coder                                    Version 2.0         (R2015b)
    8 u6 B$ y/ Z& {/ X2 U1 a& e# q6 P Simulink Real-Time                                    Version 6.3         (R2015b)
    " _! X( P- C2 Q7 S7 O Simulink Report Generator                             Version 4.2         (R2015b)! {9 d7 {" Y* A& H' [
    Simulink Test                                         Version 1.1         (R2015b)
      o, _; M8 y# G6 S Simulink Verification and Validation                  Version 3.10        (R2015b)
    2 [3 L. J! ^/ ~$ ?9 T$ k; n: v Spreadsheet Link EX                                   Version 3.2.4       (R2015b)9 L% L. ?: I4 W# k
    Stateflow                                             Version 8.6         (R2015b)  i+ M5 B  ]/ ?
    Statistics and Machine Learning Toolbox               Version 10.1        (R2015b)0 u9 h4 X# l$ K3 ~& ]0 a: b
    Symbolic Math Toolbox                                 Version 6.3         (R2015b)
    $ R9 ]/ c% k. y+ M System Identification Toolbox                         Version 9.3         (R2015b)
    2 E9 N8 L+ ~7 n* T" K  { SystemTest                                            Version 2.6.10      (R2015b)/ L  g* U, |" G$ M: b
    Trading Toolbox                                       Version 2.2.1       (R2015b): H$ B$ T2 E% A, {) z' a
    Vehicle Network Toolbox                               Version 3.0         (R2015b)
    % Z8 ^5 g( T/ H" Z6 v Vision HDL Toolbox                                    Version 1.1         (R2015b)/ v+ z/ S' {/ ~1 r- \% j
    Wavelet Toolbox                                       Version 4.15        (R2015b)
    4 J" M7 T/ t; ?5 \
    游客,如果您要查看本帖隐藏内容请回复
    * w$ q8 Q6 A, x5 p) s& y& I) d
    . ?. _' F: |9 t. J( [' ~
    2025-10-2 15:00
  • 签到天数: 704 天
    [LV.9]以坛为家II
     楼主| 发表于 2015-9-29 19:18 | 只看该作者
    MW_2015B64_Full.part1.rar (14 MB, 下载次数: 61) 4 R# c& f  {; E
    竟然少了一个,现在补上。* s% r7 M; r1 t7 w
    发表于 2015-9-30 21:05 | 只看该作者
    不知道能不能用  之前找了一个密钥就几个工具箱
    发表于 2015-9-30 21:24 | 只看该作者
    这密钥怎么就几个工具箱 @suiwinder
    2025-10-2 15:00
  • 签到天数: 704 天
    [LV.9]以坛为家II
     楼主| 发表于 2015-10-1 10:42 | 只看该作者
    java下的那个install文件要先替换。
    发表于 2018-5-22 11:53 | 只看该作者
    GOOD THANKS.
    . @3 Y4 ~1 U; R9 u
    GMT+8, 2025-10-4 13:27 , Processed in 0.156250 second(s), 26 queries , Gzip On.
