本帖最后由 超級狗 于 2015-9-23 16:44 编辑 5 i c6 M* T y0 c( t! F
2 T' Y% w1 `0 s7 ~
呵!呵!不要把別人想的那麼壞,事實上是有原因的。高負載電流(High Load Current)的狀態下,反而對低頻的 PSRR 有利!
# A' I' r( j0 p' O' a5 g8 z% n2 A+ U( X# j) f: W/ L; {
As load current increases, the open-loop output impedance of LDO decreases (Since a MOSFET output impedance is inversely proportional to the drain current), thus lowering the gain. Increasing the load current also pushes the output pole to higher frequencies, which increases the feedback loop bandwidth. The net effect of increasing the load is therefore reduced PSRR at lower frequencies (because of reduced gain) along with increased PSRR at higher frequencies.- x+ z% n) I: g4 _5 `7 b4 X) D
3 E1 t7 I3 \& i, v9 }
0 L1 ?0 s7 m. Y t5 y |
