查看: 918|回复: 12
[仿真讨论] IBIS 6.1
发表于 2015-9-13 22:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
5 u: p/ ^: o2 o, \5 i6 [9 [) J. Q% ~6 G
The following BIRDs  (Buffer Issue Resolution Documents) are incorporated into the new specification:( u3 j9 s0 w* ?3 U8 U- P
( m7 u# d' R  r% K9 O# FBIRD155.2 New AMI API to Resolve Dependent Model Parameter
% l+ y3 e1 [( TBIRD167.1 Table Corrections for Tx Jitter Parameters and Ignore_Bits3 s- v7 i5 m$ q
BIRD168.1 Handling of Overclocking Caused by Delay in Waveform Tables4 _# m0 k5 u+ {  B. |/ I5 G
BIRD169.1 DLL Dependency Checking7 l& C3 V* V. E" @7 h" a! K
BIRD170   Delete Extra Paragraph for Ports under [External Circuit]
; A& T% E) `* Z; [; JBIRD171.3 Clarify that Empty Root Name is Not Permitted in AMI Files$ I( C, u* n! `# {$ a/ ^
BIRD172.2 Extend Multilingual Parameter and Converter Parameter Rules
$ J! w. I. e- s8 P0 [: A8 aBIRD173.3 Package RLC Matrix Diagonals
/ H' T' s/ Y6 l9 I7 D/ y  ?BIRD174.1 Quote Character Clarifications- [* r9 |2 ^  z7 I* U3 L4 [
BIRD175.3 Extending IBIS-AMI for PAM4 Analysis& M* {# V, [8 H! h: Z
BIRD176   Power Pin Package Modeling7 V8 \- r6 `1 W  L7 z* R$ }
BIRD177   [Initial Delay] keyword for Submodels and Driver Schedules
4 }$ Z" X+ z9 ]BIRD178.3 Specifying Buffer Directionality for AMI' h+ e9 @/ x/ L
) j1 F( w7 e* d ver6_1.pdf (1.29 MB, 下载次数: 95)
参与人数 1威望 +10 收起 理由
shark4685 + 10
发表于 2015-11-23 10:54 | 只看该作者
谢谢分享
发表于 2016-5-17 21:27 | 只看该作者
谢谢分享谢谢分享
发表于 2016-8-12 10:45 | 只看该作者
感谢楼主分享
发表于 2016-8-14 08:50 | 只看该作者
有興趣, 感謝分享
GMT+8, 2025-10-5 23:28 , Processed in 0.156250 second(s), 30 queries , Gzip On.
