查看: 7024|回复: 33
Hotfix_SPB17.00.005_wint_1of1
发表于 2015-8-13 10:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本帖最后由 紫菁 于 2017-9-14 14:21 编辑 0 H  M! Q9 ?+ A6 z* w
9 y' a. p2 x* @# E* w- z! X
) U. Y( |. J0 s# Y9 D  p/ D( w
& X: J; j; {9 K# w3 ?- l" G* ^# k2 D+ w" H" T6 l
DATE: 08-07-2015   HOTFIX VERSION: 005===================================================================================================================================CCRID   PRODUCT        PRODUCTLEVEL2   TITLE===================================================================================================================================1260002 allegro_EDITOR INTERACTIV       Symbols with ALT_SYMBOLS_HARD property are mirrored by Edit 鈥� Move 鈥� Mirror1356381 ALLEGRO_EDITOR INTERFACE_DESIGN PCB Editor hangs when adding net to a net group1357843 ALLEGRO_EDITOR PLACEMENT        The net association of a via changes when a replicated circuit is placed using Place Replicate1394052 ALLEGRO_EDITOR INTERACTIV       Edit Mirror preview is wrong1412635 APD            DATABASE         APD crashes on saving design1427732 SIG_INTEGRITY  SIGNOISE         Constraint Manager does not display results of Xtalk simulation1436070 SIG_EXPLORER   SIMULATION       Incorrect rise time for IBIS buffer when simulated in SigXplorer1438848 APD            OTHER            Layers of a module, mirrored using the Mirror Geometry command, change on refreshing the module1440332 ALLEGRO_EDITOR ARTWORK          The oblong slot hole changes size in the IPC2581 output1441672 SIP_LAYOUT     ASSY_RULE_CHECK  ADRC Hangs and does not close1443249 MODEL_INTEGRIT GUI              Model Integrity does not show version number in QIR 91444932 ALLEGRO_EDITOR INTERFACES       When exported to PDF, the octagonal pads in a padstack are larger than their size in Allegro PCB Editor1446259 ALLEGRO_EDITOR INTERFACES       Export PDF prints a big square box instead of a frectangle on the board1450135 ASI_SI         OTHER            Linked differential signal waveform of SigNoise report is not displayed in SystemSI viewerDATE: 07-10-2015   HOTFIX VERSION: 004===================================================================================================================================CCRID   PRODUCT        PRODUCTLEVEL2   TITLE===================================================================================================================================295747  ALLEGRO_EDITOR PLACEMENT        Place manual form takes a long time to open832170  SIG_INTEGRITY  SIMULATION       IBIS buffer results with two TV curves do not correlate with HyperLnx or MATLAB results926138  SIG_INTEGRITY  SIMULATION       IBIS buffer results with two TV curves do not correlate with HyperLnx or MATLAB results1306988 SIG_INTEGRITY  SIMULATION       Support needed for the multiple VI and VT waveforms for the buffer with TLSIM1315048 ALLEGRO_EDITOR INTERFACES       IPC2581 translation inconsistency on negative layer1416221 ALLEGRO_EDITOR INTERFACES       Allegro PCB Editor crashes when exporting a board drawing as a STEP model1426286 ALLEGRO_EDITOR EXTRACT          The Oval slot orientation for a footprint is different from the actual design in the exported STEP file1429526 ALLEGRO_EDITOR INTERFACES       A blank PDF is generated for a symbol file when orientation is set as Landscape and the left margin as 01430405 ALLEGRO_EDITOR MANUFACT         Running Export - IPC-2581: The exported .xml data does not contain the Probe figures or the probe information1430564 ALLEGRO_EDITOR PLACEMENT        On moving a group in the pre-selection mode, the place_bound shape separates from the parts in the group1430822 ALLEGRO_EDITOR DATABASE         Incorrect pad stack associations in packages created by PackageWright using the skill API1434375 ALLEGRO_EDITOR INTERFACES       Running Export - IPC-2581:  The last or largest pin in a series of pins listed in pinOneCfg.txt is selected1437150 APD            DIE_GENERATOR    Creating a die using the Compose from Geometry command gives error, "E-(SPMHA1-70): Pin is outside of the extents"
推荐
发表于 2015-8-13 17:28 | 只看该作者
pzt648485640 发表于 2015-8-13 16:42
* A  J8 w8 a8 U* M5 R2 `% o3 s估计是等不到了;到2016年初发布新版本;从16.6版本更新来看17.0中的功能已经更新到16.6中,甚至16.6还要 ...
: j5 R0 E* j- d- {7 A2 G
多谢。我一直用着16.6,只在家里另一台电脑上装了17.0玩玩。真搞不懂搞个17.0出来有什么用?过渡一下?安慰用户?' a- l5 Y2 G  S: |
17.0 是64位啊,这是大进步,提高电脑C PU的使用效率,但别想能降32位的了  详情 回复 发表于 2016-10-4 15:15
推荐
 楼主| 发表于 2015-8-13 16:42 | 只看该作者
steven.ning 发表于 2015-8-13 14:49' R" a9 u1 r' n
谢谢,还是没有看到可以转低版本的消息.
" v+ ^; d7 \* N* ]% v
估计是等不到了;到2016年初发布新版本;从16.6版本更新来看17.0中的功能已经更新到16.6中,甚至16.6还要多于17.0;还是建议大家不要使用17.0作为主要的layout工具。
1 P  l6 J/ \/ C: b' D2 w
现在感觉17.0的pad designer太吸引人了,别的我倒是没有迫切的升级欲望。  详情 回复 发表于 2015-8-26 12:01
多谢。我一直用着16.6,只在家里另一台电脑上装了17.0玩玩。真搞不懂搞个17.0出来有什么用?过渡一下?安慰用户?  详情 回复 发表于 2015-8-13 17:28
推荐
发表于 2015-8-26 12:01 | 只看该作者
$ q% |; W; b; _# [) }2 w+ U; f/ }估计是等不到了;到2016年初发布新版本;从16.6版本更新来看17.0中的功能已经更新到16.6中,甚至16.6还要 ...
8 k- `! I+ D+ l, W现在感觉17.0的pad designer太吸引人了,别的我倒是没有迫切的升级欲望。/ z. ~% ~7 c( i% w
发表于 2015-8-13 14:49 | 只看该作者
谢谢,还是没有看到可以转低版本的消息.
估计是等不到了;到2016年初发布新版本;从16.6版本更新来看17.0中的功能已经更新到16.6中,甚至16.6还要多于17.0;还是建议大家不要使用17.0作为主要的layout工具。  详情 回复 发表于 2015-8-13 16:42
发表于 2015-8-13 15:33 | 只看该作者
虽然没坐到沙发  但是这个更新太及时啦~
发表于 2015-8-13 15:43 | 只看该作者
大感謝!
  y* }' \" e7 j3 r感謝版主快速地分享!
发表于 2015-8-13 18:50 | 只看该作者
谢谢,低版本还是不能转换!
    2025-10-29 15:00
  • 签到天数: 721 天
    [LV.9]以坛为家II
    发表于 2015-8-14 18:55 | 只看该作者
    那发布17的目的是什么呢?感觉有点无厘头啊
    过度测试版;;固网上也没公开下载  详情 回复 发表于 2015-8-15 00:10
     楼主| 发表于 2015-8-15 00:10 | 只看该作者
    suiwinder 发表于 2015-8-14 18:55* T8 }( W2 E6 B% X* t* p  s
    # U9 X: S) a$ G: f
    过度测试版;;固网上也没公开下载* g# `! A% I' ]1 @2 m5 K
    貌似的确如此。不管了,先用用吧。  详情 回复 发表于 2015-8-25 19:11
    发表于 2015-8-15 09:27 | 只看该作者
    谢谢楼主分享
    - M9 x1 _9 b' r/ D4 v4 I6 D
    2021-10-7 15:18
    发表于 2015-8-15 18:48 | 只看该作者
    感谢lz分享!
    擦汗
    2019-12-12 15:00
  • 签到天数: 13 天
    [LV.3]偶尔看看II
    13#
    发表于 2015-8-17 09:07 | 只看该作者
    暫未使用17,先收下保存囉,
    ) I( z# U) ~" O謝謝大大的分享了!!
    14#
    发表于 2015-8-19 15:15 | 只看该作者
    好资料,感谢楼主!!!!!!
    15#
    发表于 2015-8-19 16:24 | 只看该作者
    Vista系统一样,他有的别人都有,别人有的他没有,还用得不爽
    GMT+8, 2025-11-2 00:17 , Processed in 0.156250 second(s), 26 queries , Gzip On.
