TA的每日心情 | 开心 2023-12-4 15:58 |
签到天数: 1 天 [LV.1]初来乍到
16.5的orcad,
" q2 e, _* Q( ]4 C- z d& p从旧版原理图A.dsn拷贝到新建的B.dsn,并且删除部分原理图1 A5 ]) H' L4 r# J# _4 g
通过选择orPADSPCB.dll文件导出.asc文件,然后用.asc文件导入到pads layout工具的一个pcb文件中
- X1 H2 {3 Y: E6 h& L结果,pcb文件几乎没有变化。
! s u: _* g+ b2 K& A
' i! W6 A5 X- e9 R9 R# F按理应该会删除一堆器件的,结果,却反而在top层增加了一个莫名器件,求教各位大神,如何解决?2 l) l+ Y5 { _5 i, b
2 e. L3 h2 e# }/ h. X
有警告对话框如下:
3 d# w0 s9 ^! W wWarning: Improper data found in file D:\Project\360SDAS_V1_20120727_04.asc may be ignored.* S6 S! y1 g& U0 {2 z. t9 p
" ?( f; ~( l `; K
有错误提示如下:
/ `) R" |6 D+ H$ R% m6 }- Q....: y* b; d) o P% S9 q& n9 X5 `
Part name already used U4) O9 a/ t n0 X2 S5 ?: w
U4 U_LT3506EDHD(DFN16_P0.5_H0.75)8 k1 h. b; [' A: K! m
Part name already used U5
A5 D* p- T" n4 }- }4 HU5 U_LM2833(LLP-10_P0.5_H0.8)4 x6 t0 G- X# i1 p) {8 X
Mixing nets 0 C158 2 CPU_3P3V FB26 2
* A* }" i \% EU3.AC19 C100.1 C111.2 R61.2 C157.1 C158.2 FB26.2
' n. Y. x# R6 }Mixing nets ACC_36V C2 1 N18284478 R256 2$ h! ?- i2 k- U4 E, g8 I
C8.1 L1.1 C2.1 R256.23 m; k( \+ b: K
Mixing nets ADC_3P3V D13 2 CPU_3P3V FB25 2" o# Y0 @; P5 {" s E% f7 `# w& m& y6 R
FB25.2 D19.2 D17.2 D18.2 D20.2( _7 H; G- d! z3 u
Mixing nets CAM_5V C33 1 N18080613 R229 2
3 g! W# A% z" E% C# x3 VC35.1 D7.2 C34.1 C33.1 R229.2- ?; B' |/ e0 w$ l1 x- _
' ]2 c/ A) N. N; O*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N08401
7 f2 B2 O! W' Z# E4 v' O# O2 XMixing nets N08425 Q4 1 N19283404 Q4 1 W* c- E! Y9 z; @. `$ r$ `
Q4.1 R9.2 R10.2( @' j8 E" w- l9 I! I
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N084257 z6 y _( {/ S j" k( V) r% S7 M! p
Mixing nets N08433 TP2 1 N19283364 TP2 1) i/ g5 g+ t0 G. q0 K2 n
TP2.1 D2.1 Q3.3 R7.1 Q1.1+ F; C; M# e+ _' q7 G
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N08433
1 |3 |. W# {% i5 E1 GMixing nets N08613 R3 1 N19283412 R3 18 K0 c4 M, k- ?* ^# }
R3.1 Q4.3 Q3.2
- H. t8 R6 l0 f5 P! |" E*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N08613
3 U7 |5 f6 G K" t9 \& I, IMixing nets N08735 C11 1 N17859713 C11 1
' J% t) Y4 [) m; h! T2 N! {C11.1 L1.2 FB2.1 C3.1 CA1.1 FB1.1 C10.1 C1.13 M# V) n, Y0 T1 C, T4 }
( D/ S, d" P$ D) J% Q |
