1 Q. V! q9 n0 k3 r5 N
不確定是不是這個問題造成的,但可以參考一下這些資料。
# |& v$ I. ?" v0 l# y9 Z" Q$ Y0 `0 ~) q$ A# |+ {5 w
下面這段話是肥死卡好(Freescale)的技術文檔節錄下來的,講得一針見血、但內容較雜( 不只討論這個問題),我給你另一篇 ATMEL 的技術文檔,它專門討論 MCU 的 Start-up Time,淺顯易懂、還有一些電路上的建議!/ y+ l/ g5 M, n+ s* `
3 x$ _8 G0 f& o1 |; T
Long Start-Up Time6 u- D9 x, i; Q- r
A long start-up time is usually a more common problem with low-frequency crystals, since they tend to start much more slowly than high-frequency crystals. One of the causes of a long start-up time is weak loop gain. Oscillator start-up times will also be affected by the rise time of the power supply. When the power supply has a sharp rise time, the crystal will experience an energy impulse that will usually make it start faster than it would using a power supply with a slow rise time.
b4 c- O" w2 @
# {0 B- p7 {# c% o4 J& z % |8 `# k3 Y5 d+ y, a
