DATE: 6-12-2015 HOTFIX VERSION: 003
" O( v. z: e" z) e$ u7 M+ e. |* K=================================================================================================================================== & q) v5 p& j7 ^7 x* U4 a. N8 y$ J2 ^
CCRID PRODUCT PRODUCTLEVEL2 TITLE
2 E1 I- F- d; o===================================================================================================================================
1 W. i9 d6 i# |1371902 ASI_SI SPDIF Place boundary is not used for parts when using SPDIF
j% z/ {0 ]8 w& ?% Y# {1419081 ASI_SI SPDIF Multi-drill pad translate to .spd improperly) w- c7 H/ L* U1 ?6 O6 r
1403934 ASI_SI SPDIF Polygon shape can’t be displayed in 3D view' \$ q, U! X3 i) u$ m4 [
1401115 ASI_PI GUI Letters are hidden in checkbox sets when using PowerDC-Lite in Linux $ z/ g$ f& d* Z9 [9 u
1415345 OPTIMIZEPI GUI Question about OptimizePI # A/ R" o% [0 V% G7 P) F( C
1399396 POWERDC OTHER Maximum mesh edge length's TCL command does not seem to work
: G a+ u0 ^: ?& C1405821 POWERDC GUI_ELECTRICAL Different vout and vnom value in sign-off report5 V4 u5 ~' Z/ p( J
1413128 POWERDC OTHER Result difference between PowerDC 16.64 and 2015 : _: n' S ^- a1 \+ F! \# c( ~' B
1364059 POWERSI GUI PowerSI multiple structure simulation consumes multiple PowerSI license feature
# F r4 x! L$ ^! w$ ~5 G, D1403079 POWERSI ENG Coplanar trace option issue
+ e$ E$ j8 ^2 d5 N/ a1412432 SPEED2000 GUI_SPDGEN Launch 3DEM then crush3 s7 }9 d X$ ?3 f$ W D v) B
1415959 SPEED2000 GUI_SPDGEN Voltage level reduced to half compared to measurement result- `; V! q1 X9 {* ~) v
1407574 SPEED2000 ENG_SPDSIM SI metrics error in Sigrity 2015 : E8 r2 Q, W1 n' M
1418798 SYSTEMSI ENG_SLA Xtalk channel not work in Xtalk measurement simulation
3 S1 J' _7 f" [2 S. b- N1418800 SYSTEMSI GUI_SLA Xtalk mode in report does not match setting in Analysis Options- ?- S( O4 M' ]
1420310 SYSTEMSI GUI_SLA Unit is wrong in SSI Mask Editor Library
) ~/ Z! G: K6 k8 K1402939 T2B OTHER Cannot generate Validation report with batch mode
4 _, N; V+ @+ @4 c1423333 T2B OTHER Error about combine package model with .pkg file in T2B# n# [# ~1 `. {2 U& g8 w
1377708 TRANSLATOR SPDLINKS A box in a brd file is translated as a polygon and causes PSI extraction crash
$ ~8 U5 X* I0 G! P. E1377711 TRANSLATOR SPDLINKS Brd net name with "<" or ">" characters causes XtractIM's workspace file to fail to load9 e6 e r) | [) e1 v
1378423 TRANSLATOR BRD2SPD Pad offset is translated incorrectly4 ?1 ^, M$ ]# r6 d. F" v
1378763 TRANSLATOR SPDLINKS Some pins are missing when translate an ODB++ design
) R' }- ~9 k" f5 s8 D; v: _1394410 TRANSLATOR RIF2SPD Some circuit nodes are missing
7 g( u) P" d* A1397518 TRANSLATOR SPDLINKS Some short circuits created from a brd design! z6 _; ?6 R1 p, [& G/ d
1399657 TRANSLATOR PAD2SPD Some die wirebond pads are incorrectly rotated 90 degrees
+ _/ m1 ^7 \4 }1402554 XTRACTIM OTHER Wirebonds not extracted when dual and offset
0 z! U2 \7 ?9 o1 ^' l1395766 XTRACTIM GUI XtractIM 2D plots incorrectly capture screenshots of other application such as APD
/ T9 i( a* F; i1 _$ | z( i7 D: s6 O1 N1 B4 ], t2 h/ j6 S5 b: L
下载链接:http://pan.baidu.com/s/1sjBirwh
; I: m# \& x& E8 W8 ?& w% T$ c |
