typedef union
4 X0 q1 w/ a) ]9 _/ M1 e* V$ Z{ 3 P! f0 y& ?5 {7 Y
u8 sensor_type_value% f- \7 _" \/ y" j& E/ f w: B
struct
/ _ D+ _7 D. U {
9 R0 m8 o4 }2 i unsigned TYPE_ACCELEROMETER :1; 加速度传感器
}, p* d& Y9 n% [7 n8 I unsigned TYPE_MAGNETIC_FIELD :1; 磁力传感器% y- c! U9 |4 T2 M6 e0 I. Z
unsigned TYPE_ORIENTATION :1; 方向传感器6 T6 F& ]2 Y! F3 B! a b4 s6 h
unsigned TYPE_GYROSCOPE :1; 陀螺仪传感器
* Z A! j2 C& v: y* h8 V/ g. H. | unsigned TYPE_LIGHT :1; 环境光照传感器
, M) Z3 L6 U/ F; M: \( \- T& Q9 _ unsigned TYPE_PRESSURE :1; 压力传感器5 R) f) O7 F L: E
unsigned TYPE_TEMPERATURE :1; 温度传感器! {% W/ Y! q3 q
unsigned TYPE_PROXIMITY :1; 距离传感器$ V& c! ?( v( a! e, |7 H+ D9 |
} type_bits;
& V! g5 K( a4 G$ L4 f) q$ c}TYPE_SENSOR;
4 L5 k7 x) @- B( C. j
* p T+ n3 V b6 ?8 mstatic TYPE_SENSOR type_sensor;2 }* q- b y1 _0 D- o7 w s
- j8 R2 V7 o0 [; F3 {% y# `
瞎写的,如果有错误,笑笑即可, ) e" Z! C0 [0 i; i, {& N
$ y) K W' \! v& Z. D& ~- q6 r |
