JESD84-A44
0 k' |6 O* d8 ~) ]DAT0-DAT7: These are bidirectional data channels. The DAT signals operate in push-pull mode. Only0 M* }* v. e( [: e/ T* Y6 D U
the card or the host is driving these signals at a time. By default, after power up or reset, only DAT0 is% x1 Y, t `% `" `) I5 P9 d* c& D
JEDEC Standard No. 84-A44 Page 15 used for data transfer. A wider data bus can be configured for data transfer, using either DAT0-DAT3 or DAT0-DAT7, by the MultiMediaCard controller. The MultiMediaCard includes internal pull-ups for data lines DAT1-DAT7. Immediately after entering the 4-bit mode, the card disconnects the internal pull ups of lines DAT1, DAT2, and DAT3. Correspondingly, immediately after entering to the 8-bit mode the card disconnects the internal pull-ups of lines DAT1–DAT7.
* _" N( N8 i6 S: p' O. x! A7 I' Q7 b4 F3 N( A3 S- x! Q
