: J! C3 Q( u" a5 S& ?. D+ w
Port refinement, process hf3d: '1' conductors touch lumped port '1', typically a lumped port contains 2 conductors. Please verify conducting boundaries and objects are correctly assigned and touch the port. If a Radiation boundary touches the port and it is desired for use during the port solution, select 'Use Radiation Boundary on Ports' under the Advanced tab in the Solution Setup. 这是仿真中出现的,我添加的lump端口,就像看一下板子的电磁场分布情况,可是板子上器件啥的都没有分布情况,只有过孔处有点淡蓝色分布,这是怎么回事?3 ]; ?- I& K5 q. B
这个lump端口不是可以在内部添加么,我添加之后板子仿真就出错了,请问这个lump端口的添加还需要注意啥?
. c' R" `& b$ {2 n6 h1 W哦对了,我添加wave端口就看不了场分布,那个操作树种E Field下的Mag_E1这个是灰白的点不了。
/ }5 B& c1 J1 W$ V$ j& R- M问的有点多,希望大家多多参与,谢谢。
& [' r, H0 U5 r/ {0 }8 y4 H( ^0 |) h |
