查看: 2207|回复: 3
OrCAD网表导入PCB Editor有告警
发表于 2015-3-22 16:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
- p5 ?8 B& x$ W; R/ I# j) m) s9 O. ~
, e2 p  E+ ]  i% {, G" K(    allegro Netrev Import Logic                                      )* z; L  N% ^$ T8 }1 a
(        )% ?/ W5 ^8 X: ?" y
(    Drawing          : 123.brd                                       )
; O# d+ E# \7 [4 F5 L7 j% P' }5 k(    Software Version : 16.6P004                                      )
( `6 a" @4 }% D& G& _(    Date/Time        : Sun Mar 22 16:16:02 2015                      )
, E. i( x( e: S5 P, H" u: Q(        )- K+ R) x& c$ t2 H
(---------------------------------------------------------------------)- e6 z% E- }: G" h' l1 h  c0 q+ [
------ Directives
; j& b0 o2 z4 h8 c1 H------RIPUP_ETCH FALSE;
5 C: v  C: y. A6 \* \9 w9 o" a0 xRIPUP_DELETE_FIRST_SEGMENT FALSE;7 u* `) l$ G; T9 y7 G% ]0 J! U
RIPUP_RETAIN_BONDWIRE FALSE;RIPUP_SYMBOLS ALWAYS;
$ f- P8 J, \% {% \9 w5 UMissing symbol has error FALSE;SCHEMATIC_DIRECTORY 'D:/AppData/orcad/palm_Pspice/allegro';BOARD_DIRECTORY '';* ]9 I* Z' ?5 V
OLD_BOARD_NAME '123.brd';NEW_BOARD_NAME '123.brd';1 v# ~  O# r3 `% `7 F; N
CmdLine: netrev -$ -i D:/AppData/OrCAD/palm_pspice/allegro -y 1 D:/AppData/OrCAD/palm_pspice/PSPice_example/example1/, r( {/ }8 o5 g7 g+ C& _: s
#Taaaaat03092.tmp
4 A  v+ `; h# b3 \------ Preparing to read pst files ------
/ B% A1 v( J7 {8 P) Q& D% J- YStarting to read D:/AppData/OrCAD/palm_pspice/allegro/pstchip.dat
; u! X7 d4 H8 aFinished reading D:/AppData/OrCAD/palm_pspice/allegro/pstchip.dat
" m, g+ `0 ?, o) N8 ~(00:00:00.03)' M# x0 C8 y4 a$ A6 K; L& ?: z! |
Starting to read D:/AppData/OrCAD/palm_pspice/allegro/pstxprt.dat
5 @  s- o8 `2 ?3 r. D8 C; C' @( }Finished reading D:/AppData/OrCAD/palm_pspice/allegro/pstxprt.dat
6 K7 x4 V" ~7 D% }: o4 Z(00:00:00.00)Starting to read D:/AppData/OrCAD/palm_pspice/allegro/pstxnet.dat
0 d* v& u# j2 J, U$ e9 s5 E* KFinished reading D:/AppData/OrCAD/palm_pspice/allegro/pstxnet.dat! m1 D' f6 E8 [. }$ Y
(00:00:00.00)------ Oversights/Warnings/Errors ------#1   WARNING(SPMHNI-192): Device/Symbol check warning detected. [help]WARNING(SPMHNI-194): Symbol 'C0805' for device 'C_C0805_1N' not found in PSMPATH or must be "dbdoctor"ed.
" T' }5 S: H# X#2   WARNING(SPMHNI-192): Device/Symbol check warning detected. [help]WARNING(SPMHNI-194): Symbol 'HEADER2' for device 'CON2_HEADER2_CON2' not found in PSMPATH or must be "dbdoctor"ed.! G# u/ Y) f0 Y* h4 M: h
#3   WARNING(SPMHNI-192): Device/Symbol check warning detected. [help]WARNING(SPMHNI-194): Symbol 'R0805' for device 'R_0_R0805_1K' not found in PSMPATH or must be "dbdoctor"ed.------ Library Paths ------MODULEPATH =  .            C:/cadence/SPB_16.6/share/local/pcb/modules PSMPATH =  .            symbols            ..            ../symbols            C:/Cadence/SPB_16.6/share/local/pcb/symbols            C:/Cadence/SPB_16.6/share/pcb/pcb_lib/symbols            C:/Cadence/SPB_16.6/share/pcb/allegrolib/symbols PADPATH =  .            symbols            ..            ../symbols            C:/Cadence/SPB_16.6/share/local/pcb/padstacks            C:/Cadence/SPB_16.6/share/pcb/pcb_lib/symbols            C:/Cadence/SPB_16.6/share/pcb/allegrolib/symbols ------ Summary Statistics ------netrev run on Mar 22 16:16:02 2015   DESIGN NAME : 'WHAT'   PACKAGING ON Sep 10 2012 04:46:09   COMPILE 'logic'   CHECK_PIN_NAMES OFF   CROSS_REFERENCE OFF   FEEDBACK OFF   INCREMENTAL OFF   INTERFACE_TYPE PHYSICAL   MAX_ERRORS 500   MERGE_MINIMUM 5   NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'   NET_NAME_LENGTH 24   OVERSIGHTS ON   REPLACE_CHECK OFF   SINGLE_NODE_NETS ON   SPLIT_MINIMUM 0   SUPPRESS   20   WARNINGS ON No error detected No oversight detected  3 warnings detectedcpu time      0:00:24elapsed time  0:00:00SPMHNI-192:
9 b- [" G3 ]3 ?) P5 Y2 \9 d! a; T. ?% ?This is a general warning that is normally paired with another message. Check the secondary message for more detail.
$ c$ L+ R' @. P2 L$ S9 n* \- j, ~, O: a) k
SPMHNI-192:
% l% w: E2 P' ]* e# w' Z! T. _This is a general warning that is normally paired with another message. Check the secondary message for more detail./ \3 X5 q/ L! ~: B
9 u/ X1 K+ o0 m' b
SPMHNI-192:
, p! R- p& Z! u2 \# E$ l6 {
( p/ o; _! q8 [4 e( ~6 f* [( p. H! l/ m  [+ p- x' n
4 R' n' t0 o/ ?5 U# j; P
& |- J' g% Q: v$ \. G( v9 w9 M; S
/ y$ w3 f0 T7 T0 d% U/ K5 x( L% e+ W6 e) o( D7 H/ i2 L
    2024-2-21 15:59
  • 签到天数: 313 天
    [LV.8]以坛为家I
    发表于 2015-5-22 14:16 | 只看该作者
    PCB封装库中无C0805、HEADER2、R0805对应的封装。
    GMT+8, 2025-8-20 12:03 , Processed in 0.109375 second(s), 23 queries , Gzip On.
