1 {: ?" K" m; {2 B. b& q0 }3 \
) T. G$ N+ ]: I8 S) S altium 如何输出3D step文件到SolidWorks
8 V0 E" Z6 H) {3 {8 o( E直接导出 然后在SolidWorks 里面打开 3D模型不显示 不知道怎么解决 。8 T% C9 ]8 G0 m- W- ~( ]
方法我应该是找到了 但是看不太懂他们的英文 6 T$ n2 p, s6 U
请高手翻译下 关键是这些 Altium 就没有中文的7 m5 ]8 u+ T/ t# n6 \. ?
6 p" g3 N7 B' d$ q9 R/ I2 Chttp://techdocs.altium.com/display/ADOH/Step+Exports 这个是地址0 l6 p* Z$ f; F; O
http://techdocs.altium.com/display/ADOH/Third+party+import+problems. m) ^7 U' B/ e5 {8 g
& y C! K! z5 z& b
1 l( B8 J' t' f) X0 C# TSTEP export from Altium to Third Party6 H- ^. t* j0 R' K7 J* u* P
Any Altium PCB document should be considered a candidate for Step export. Apart from proclaiming which objects are to be included, no other actions should be necessary in order to create compliance with major third party MCAD software. The exported file is in accordance with ISO-10303-21 and the files should be recognised as AP-214 version software.# }4 ]8 n T9 `" `
7 X4 A \/ ]2 S1 Q
Exports of Boards and footprint componentsAltium Designer exports step files via the File » Save As menu. By selecting .STEP as the file extension, the save function will begin the export set up. You are immediately presented with a dialog describing that all Step files are exported according to an absolute origin. You will be prompted to select which objects to export. Altium's protocol in this instance is to include by means of previously selected objects. This means that if you wish to be selective about which components to export, you will need to make certain actions before you begin the save process. For instance, if you choose to export selected components - and none have been selected - this will ensure that no such objects will be exported into the file. This image displays the export choices. {Note} One note of advice - the step export file will retain the view configuration for colours of soldermasks, only if the export is carried out whilst in the 3D view state. If you choose to export whilst in the 2D view, the export will retain individual component information for appearance, but the board will be exported as a standard green colour. {Note} . }$ q' ]+ m2 G5 N: w
2 G. w$ e ^- {6 C4 |/ |![]() The saved file can be imported back into Altium Designer as part of an assembly of another main board in a PCB document. The recently saved STEP file will be the default drive and path directory for the next import process making a comparison style import of a step file placed next to the original - or placed in another document - an easy practice. This image is of an assembly stack example where several boards have been exported and then 'Placed' (imported) into an Altium Designer main board document to check their physical alignment characteristics along with a through hole connector. This kind of process can determine connector selections based on their ability to be handled or auto assembled in large volumes. 4 f5 l1 w: @ @' T, R! d- J/ a* z3 Z
7 T0 l" C! V& I t1 H4 j7 `This can be useful for making comparisons when importing the step files you have created alongside the original - as in the image below. Because Altium does not export either copper or text(不能输出铜皮和文字), the file size is reduced without losing mechanical information about individual objects on the board.
7 ~1 U l5 E) i- j) K* n: B6 V( y8 [7 t5 ^7 n7 i" O
! k# N) g& X7 V" ~
The resultant step files of populated boards can be imported into many third party CAD tools for whatever purpose is required. Most third party tools will involve options or filters which may need to be configured in order to enable the imported models to draw as expected. The following example is from the Solidworks 2008, SP5 Step import options list. The settings in this example should be considered as a reasonable standard when importing Step files exported from Altium Designer software.
! w. j# U6 `0 Y; a8 }6 q! Z
0 m0 M8 d" Q' z& a ~
/ p9 z& g( [+ D3 o
Exports of Boards and footprint components5 \$ L& u6 ] O! O6 J6 C7 [
The Solidworks import showed up a number of problems involving the import options for the board. Setting the import options to "Automatically repair errors" cured the 'hollow' board effect. This happens when the importing CAD tool cannot tolerate or trim certain objects correctly. Most of our problems in this area relate to polygonal representaions of arcs or circular shapes. Altium's software does not cope well with importing ellipsoids and the like manufactured with third party tools such as Solid Edge. This can lead to invalid suRFaces. This image came from an import into solidworks and displays the 'hollow board' effect - easily corrected by applying the auto-repair options. Closer examination revealed the corners of arcs to be a problem. Some step models are not placed correctly, but rather they appear to be placed according to their original positions when they were first constructed, ie. According to their original co-ordinates offset from 0,0,0 when they were first constructed in a CAD tool and not relative to the origin of the board. This is an example of how Solidworks does not always place objects at their correct location. Note the pin is instanced once only and at the origin also - not in a socket position.
; r4 t6 w& q! J* @* A9 xThese models tend to show no problems in other CAD tools and replace well in Altium's 3D views. By constructing a clone of the model and removing colour or other appearance attributes, many of these models import correctly but it does not appear to be because anything was wrong. Developers are currently looking into the cause of these problems - but in every case, the history of the model is not known, ie, third party suppliers of components have supplied the models.
In Pro Engineer, the DT01 imported correctly without any alterations necessary. In Solidworks, one model was misplaced and single instanced instead of multiples. In this particular case, the 2X5 10 pin connector appeard at the origin and with only one pin! These objects turned out to be coloured step models. When the original neutral was replaced, the import went smoothly. If other models of an extruded variety were used, there was no problem. Unfortunately, I cannot say that there is a particular reason, since other examples which were used 'as-is' after their import have also misplaced during an import into Solidworks. There doesn't seem to be any hard and fast rule as to why, just pointers such as Text Block step models or indeed any step model where intricate trimming of surfaces is involved. The models themselves come through perfectly formed - just not in the right place.
8 t+ I6 w. P$ T2 ^2 n* A$ f. W& p; F0 O( c+ l
DT02 Project
o9 Q6 g U" Y1 kThis DT02 image is the best unfettered result. Solidworks imported the connector (bottom of image) in the right place. But it was a different file - this one had no colours added. This is simply a pointer that the reason for misplacement could be found in the comparison of different versions of model files. ( N X' M8 S+ s# y* Z0 d& h
4 D2 |9 r+ ^% B: ^* A% R( n D q
![]() Solidworks could only import the neutral 2X5 10 pin connector as before, but there was no trouble converting simple splines and shoulders on the USB connector. PROE on the other hand has problems interpreting these curves into solids and this area of the USB connector is therefore semi-transparent. Again, this model was supplied by a third party.
' K; r' p- p5 KCases and free models
3 \) Y; C5 u- e1 S T; fThe cases ( free models ) from the DT02 were labelled as rebuild errors in Solidworks, but displayed correctly. In PROEngineer, the DT02 did not 'paint' some casing side walls at all and the board inside could be seen. ) n* {1 ]; M- ]: G5 P0 e
2 { S3 S% T [) _: r
The above image shows one of the current innaccuracies of defining board shapes from PCB blanks
& B4 x1 z0 F0 O4 e! ?4 ]- GWhere the curves are true arcs or radii. This was the DT01 after a simulated board modification. ![]()
. U. F# n2 N/ \ ?3 x# X- b: gPRO Engineer does not have any problems with where to place any objects but has a bad habit of not drawing all planes of all objects. Here the case walls are missing. Included in the import is arc information used to perform the cuts in the case shape?? 1 @8 I B7 H2 X3 n V; z& `3 S
L3 W! h. c) z6 O5 [This is a small cutout imported into PRO Engineer and below is the close-up, S% [8 C5 I# [7 P
8 F+ L/ t+ l W6 E7 B: X: H+ R6 N4 S
2 L8 e7 R; I$ [% F4 v' I2 o; W
Pro/E did not recognise some of the line segments involved in this misalignment, but still drew the plane and solidBelow is the same cutout according to Solidworks using the method of auto-repairing imports. Solidworks handled inconsistencies between arcs and straight line that do not join properly - almost without user intervention.
4 `9 V. d) F& r7 Y" u g: X! M![]() Board thicknessCurrently, the board object is displayed in Altium Designer 3D inclusive of all objects drawn on layers that extend outside the core. Included in this layer stack is the Solder mask. If users consult the Layer stack and distribute thicknesses of pre-preg and core dielectrics, these thickness alterations will reflect directly into the 3D view. But if the Solder resist (mask) is altered in thickness, Altium currently does not reflect this change in the 3D view. Therefore, such a difference is not translated when the Step export takes place. The misleading factor is certainly that the over all thickness displayed in the layer stack dialogue box will only be translated to both the 3D view and the Step export if the solder resist thickness remains at the default 0.0127mm (0.5mil). In the following images, RhinoCeros was used to make the comparisons after importing the step file produced by Altium as it made for an easy comparison. ![]() Although this setting can be altered for integrity tests and manufacturing information, they will not affect the visual display and therefore the thickness of the board object in a step export. $ c& }) r6 V' o5 k$ s- U$ N
- |; U) p, V& \, r- {. W4 h" I5 XIF the core or copper layers are altered in thickness, these changes will be reflected in both the 3D and therefore the Step export file, as in the following images. 8 T! Z+ V3 x A
. x) I: s2 V" U' s# Q8 K
One last mention; as noted elsewhere in the ECAD-MCAD documents, you can find that the imported step in a third party CAD tool will actually display the board object as 0.0127mm above the CAD tool's impression of the zero plane. This is because the solder mask which is hard coded at that thickness is declared 'above' the thickness of the board proper and therefore is displayed 'proud' compared to the rest of the asssembly. This may not suit various cases of analysis. Secondary CAD tool Tests0 P+ D' g1 d& y9 t, T' B4 V4 h
*Alibre Express5 K) R8 M& C% [" ^% L
Alibre Design will import all objects to their correct destinations but the troublesome objects which Solidworks could not place correctly are often not displayed at all. Outside this, everything else represnts well in both the visual displays and the heirarchy in their editor panels.7 K: _: ^' M! z' P8 b
Alibre deals with minute arc differences very well.
- L3 a4 F2 A( a; ], r
8 K- _: H" ]0 {5 H( T# l*CO-Create (PTC) Onespace modelling
" I5 V' ]3 {4 H% ^+ o( SThis CAD tool imported everything into the correct place as did PRO Engineer but the important difference was that Co-Create would redraw everything - even those surfaces that were showing short edges and incorrect surface sense. This reversal of surface seems to be the only problem suffered by CO-Create whereby the surface information is somehow reversed - and CO-Create knows that it is wrong. Catia V5 R19Altium Designer may create from the Board Shapes a Polygon on Layer Mechanical 1. If this is deleted the STEP result may not as expected. - b8 i/ W+ M. O+ d
: h% Q% j) I, X0 f7 f! S
! e# ]1 z% ]9 t' L# i8 l |
