查看: 1419|回复: 6
NXP官网上的模型,仿真与datasheet上不一致,请大家指点一下
发表于 2015-1-22 21:44 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
*0 j! {9 Z# ?% x2 M, k' x7 ]
5 r! ?# l5 E2 F$ X1 d9 Y. v* j$ W. f' M*; }+ @, E3 Y% {. E' M
*PMEG3050EP5 W5 \( @4 s" V2 B& d
9 @% [  d# r4 C; H' J*NXP Semiconductors
3 \* Q: g0 D! S" v*
! `8 y1 [/ x  d*MEGA Schottky barrier rectifiers
0 g) x6 j  v: K% p( V  I( i*
: U; u' _8 ^7 _: b* n*3 V1 K( s) e& v, d
*6 @0 m9 @- I$ h9 M
*. C6 p- c  F- ]+ \3 g
*IFSM = 70A   @ tp = 8ms
1 P: T5 ]9 @, ~, h$ K: s*VF   = 360mV @ IF = 5A% z) s- ~4 }0 ~1 b0 F
*4 I' v, S' y$ @% y* T* ~3 ?* K5 v7 H
*$ s" e! _) d8 Y; q+ z% ]+ R
*- U& [) v. i& \
*+ R6 _- J; Z+ j# I- u
* P, I5 X" \  |- N** Z7 {! _* {0 D; J
*0 a8 d5 S" O% z: q% q6 _. A. ~
*2 I( @7 g, i$ f6 q2 d! K+ l
2 A7 b$ O, s6 Y# o9 d$ B*3 S, T; i: k4 |* l
*Package pinning does not match Spice model pinning.
6 K! h, q6 q/ w2 u' v$ c*Package: SOD128( |! R, I0 O% z- e4 N
4 C* e; R9 @$ Q1 r% q+ X# N*Package Pin 1: Cathode
2 G1 z6 _( x6 T5 C0 X*Package Pin 2: Anode
& _' q7 R& N: o/ a9 I*
3 W7 j2 A/ `) R- d1 m5 Y*6 e/ c* n, W# `4 v2 ^1 s0 |
*4 A* x5 z6 j( r& P; e
** C8 H: S, \3 k: T2 r( L, A
*Simulator: SPICE2
' P' {: w# W8 d7 f7 m/ W1 W# l*( ^+ ^% f, v$ j: g
. g( X/ v  t3 }2 r" Z5 J*## A2 T/ g) S% w. Y  N, ?
.SUBCKT PMEG3050EP 1 2
& K. r  z+ v" t7 n" Y% s*
& ^5 v& y8 A& m6 d/ Y6 {( J0 [# X* The resistor R1 does not reflect
5 I( P! n3 p+ K* a physical device. Instead it
; L4 \# L( K; _; \$ W. @* improves modeling in the reverse8 M; [5 C$ q. [( _% o1 }" E  a
* mode of operation.
" |, e9 \% y3 e; U) R- `*: t* H2 V% ^4 q: R! n3 H
R1 1 2 4.936E+7
# X2 |4 D$ O  h1 f; B& l3 a! w4 e0 dD1 1 2 PMEG3050EP
8 @: [9 ^/ r/ @4 U*- d# v& y, t0 [  K: v( x
.MODEL PMEG3050EP D . R! x, U6 `- f
5 @4 _. m4 A; O  Q+ IS = 0.0001624 + _6 |; Z! M& ]* |1 b/ R
+ N = 1.012 ) t. G/ H/ W5 F+ D" K
+ d& z# @2 \! @6 h+ BV = 33 & a8 Z" K0 v$ h
+ IBV = 0.02
% s& q7 C8 a/ Z" s9 I+ RS = 0.00798
' }5 k4 Y; Z% \9 y; G& h+ CJO = 1.496E-009 + o4 F8 n! x2 d0 v" K4 ?
, w* X) S/ |; `( a/ e0 x/ j+ VJ = 0.3243 . u2 `& M4 X! m6 [( J' Y. I5 n3 C
+ M = 0.503 9 N- V+ r) ^! B& c* q2 i  @
( {1 w3 [0 Y2 y/ J* b& k; T
+ FC = 0.5 6 x9 h; J' X( E
* x4 X) X- m1 d3 Z. k$ T
+ TT = 0
) J* s. t* i/ M2 s. s& F5 c- ~" S* F* w, b% y4 w% D
+ EG = 0.69 5 }/ b% I* r, J) A* x% ~) ]
7 ]1 G* \0 m( x( D2 ?9 [+ XTI = 2 6 u7 u; T0 u8 E/ z
.ENDS8 g1 y8 j+ y( [$ ]! a
9 U9 L4 r( g9 X6 S- N4 n7 {这是NXP官网上PMEG3050EP.prm的spice模型( k, K) m/ S5 l$ T/ m4 O0 X6 l# Q
( Q; p  q2 p4 N1 O6 y0 T1 x8 f. g" S2 T+ O
这是仿真电路
& s, T) e# M8 t      这个是仿真结果
+ s4 j( O& c$ k7 O7 Q6 |/ A# [- Y
0 s0 k3 g6 @( F6 ?& L3 W4 i 这是datasheet上的图示
' u2 N% o6 [  M6 o, W0 J! l+ H* v6 G0 Z( Q
PMEG3050EP.pdf (148.8 KB, 下载次数: 3)   这是datasheet" @; P0 U4 S$ @+ O1 h
PMEG3050EP.zip (40.97 KB, 下载次数: 11)   这是官网上spice-model
7 ]. f4 c0 E( b  e4 v- n. d
( m; w2 d. S  ^: U& L+ P0 w1 zNXP官网上的模型,仿真与datasheet上不一致,请大家指点一下% Z0 f8 a0 s3 P2 ~7 F
% I9 J. ?5 V+ N( T+ r6 D& f- ]9 d* z: m- ^+ g
发表于 2015-1-22 23:03 | 只看该作者
0 G: r- @6 I" x  N; N9 k4 |; k* J* K" @4 l* y, N2 m
用DC SWEEP作DC扫描, Y座标LOG Y后显示.
! w5 T- d; ?7 A$ c+ B project.zip (20.21 KB, 下载次数: 7)
" X! c: [+ t- O- o! i  [' e4 N
: ^# P$ E( V4 t4 x
) g' h, S& k8 f' M$ }. [/ H
看来是要导入模型 才可以了  详情 回复 发表于 2018-1-17 16:37
参与人数 1威望 +5 收起 理由
jacklee_47pn + 5 支持! 赞一个!
 楼主| 发表于 2015-1-23 10:08 | 只看该作者
chensi007 发表于 2015-1-22 23:03
; U% y1 ?5 i! z! X用DC SWEEP作DC扫描, Y座标LOG Y后显示.
$ K2 V- z4 T( i
非常谢谢提点,听你一说,我便发现问题所在了。
0 q* O" x* k3 H% m7 s; F- f
发表于 2015-2-25 22:11 | 只看该作者
各位大大功力深厚啊----------------
    2019-12-13 15:20
    发表于 2018-1-17 16:37 | 只看该作者
    chensi007 发表于 2015-1-22 23:03, M4 u1 L( z6 j- [6 P& m, v+ X
    7 C, R- ^) |  o* h$ @2 [
    看来是要导入模型 才可以了9 d% K- I* p/ {, n$ S; W0 p
    GMT+8, 2025-9-30 18:11 , Processed in 0.140625 second(s), 30 queries , Gzip On.
