allegro导入元件进去了,里面也有这个元件了,可是当我放进PCB中时就放不进来,提示这样的$ A8 U1 \& d4 a: N+ P
No element found.
. a! l( B9 l( P3 i, BPlacing SW3 / SW_PUSH_1_SMD-TS01H-2PL_POWER / SMD-TS01H-2PL on Top.
8 X. o3 \+ _/ p' x ~last pick: 674.0 712.0$ C$ |; h9 Z( m$ r; O/ p& r% b
5 Z% A' ^5 g3 p9 x6 R2 jE- (SPMHGE-82):
, l$ {, q/ Y3 zCan not select unplaced component SW2.* `2 _7 k% ^- p7 D
* A/ s6 Y! H* F3 tNo element found.
; a9 i/ l/ n5 ~$ s, O4 {W- Save Pending
- l; h; P' I7 G3 `2 ?7 v! m3 {Command > ooEsc
O5 @) R) f$ e1 v/ ~是什么意思啊。& Z& l& s7 V6 D
6 w! ?8 o* H, ?- A9 q
