Cadence Design Systems, Inc. netrev 15.7 Mon Sep 08 14:06:39 2008
4 L! L' T! U& o. j(C) Copyright 2002 Cadence Design Systems, Inc.
) c$ F4 j0 s2 [- L* }, E4 I3 C, j------ Directives ------7 U; {9 t2 d& T& K; ^
RIPUP_ETCH FALSE;
O1 V' s u o) G/ lRIPUP_SYMBOLS ALWAYS;
/ [4 Z& W4 f8 ~: |MISSING SYMBOL AS ERROR FALSE;6 W1 ]( i* g: ?: \% M+ p. h/ w
SCHEMATIC_DIRECTORY 'C:/project/orcad/forderix';
% d" k! T( ~( v7 T; y/ _1 S: `, w! L2 XBOARD_DIRECTORY '';
3 ?1 g0 ]5 G+ B( Q# YOLD_BOARD_NAME 'F:/Cadence/unnamed.brd';. ^( U6 Q, p) ?1 |% ?: I3 v8 }* C% z
NEW_BOARD_NAME 'F:/Cadence/unnamed.brd';3 _0 g3 x, g1 v/ n+ N% \1 Y; p
CmdLine: netrev -$ -5 -i C:/project/orcad/forderix -u -y 1 -z F:/Cadence/#Taaaaaa03428.tmp' N/ |/ e% d* ]0 _% E) x
------ Preparing to read pst files ------
. p1 h4 o% c+ t) s' e6 U$ C D& b. u
#1 ERROR(24) File not found
( {( ^4 M9 N1 c: m4 \ Packager files not found9 G* k* Z, |3 M6 Y U
#2 ERROR(102) Run stopped because errors were detected
+ |) u8 z! M8 C- }netrev run on Sep 8 14:06:39 2008
1 y" x- d' o3 W4 a COMPILE 'logic'% @6 ~) T) D F. |* E0 b( p
CHECK_PIN_NAMES OFF8 {* l9 v' x/ ]( |( T
CROSS_REFERENCE OFF
' U4 Z% j( L8 J x8 S FEEDBACK OFF
7 A& x- q8 N) b% q! A' \& D INCREMENTAL OFF- N. z: a$ K; M
INTERFACE_TYPE PHYSICAL# c, @7 }" A- g3 h; a/ l7 N x
MAX_ERRORS 500
6 r% k1 @) Q. y: k MERGE_MINIMUM 5" s5 I5 q) _ J/ G
NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'9 z, o* [4 _2 G/ B
NET_NAME_LENGTH 241 ]4 r5 a' ~" R X- `) {# L
OVERSIGHTS ON g4 m$ d2 f( u0 T& Z2 \
REPLACE_CHECK OFF
0 R5 U0 G" v1 T0 d SINGLE_NODE_NETS ON
$ w7 v5 r% Y- ^. m SPLIT_MINIMUM 06 I# p* C4 c, |/ G' J1 k
SUPPRESS 200 L; w5 [1 P/ I1 Z3 ~
WARNINGS ON# `2 r# S* x/ @/ P' T! [: e$ t5 j; \6 X
2 errors detected
% J9 P! v3 E$ b+ X: x# j$ @. D' p No oversight detected9 v3 Q9 N0 N; }
No warning detected
c4 C3 ]/ H0 ecpu time 0:00:03
- O+ A" u7 \; ?3 Aelapsed time 0:00:00
7 T2 S& W* r& `$ e- h: B' [0 d% X7 W, N: }( f5 B/ v, u8 ]/ D
导入网表有以上错误,第一个错误我知道是没有封装,可哪个零件没封装怎么查找?
1 T9 q0 Y2 }& W) X b 第二个错误又是什么呢?" J+ p. W' e8 C+ _
还有netlist.txt又在什么路径下面? |
