TA的每日心情 | 奋斗 2020-7-15 15:35 |
签到天数: 1 天 [LV.1]初来乍到
# F1 is normally reserved by the system for Help so we don't use it
: l5 r+ b7 y+ c g$ \alias F2 zoom fit
6 C. ?: I1 y2 oalias F3 move% l& w0 m- `5 l+ H) ~: U
alias F4 slide 4 c2 ]; ?' X% G
alias F5 show element
# d) r+ x- Z& E6 Q. T: u walias F6 add connect
! K' V" H) b, o5 aalias F7 Toggle8 D. {2 N* x u4 o
alias F8 measure
! ~$ d0 l+ E7 h u6 Balias F12 status
6 u- i- Q) A; _alias Esc done. Q, A' M' E" F+ I+ w. |
alias Del delete
! F: V( h1 A" e: y& v% Qalias ~@ cancel
3 G4 k% e9 _: e3 L" \5 Q. V) p4 Galias ~Z undo! {- V7 g, P2 _
alias wi clppaste' V# x* ?& F- t% w+ R& d8 d
alias wb clpcopy
) Q* b! E; X: K; V9 Ralias ~E scalpel
% S. s# N( u( ^3 D# V, Nalias ~S save/ j+ A; O( j. V
alias F8 Show measure, J! A1 m# L; c) J# s
alias ~Q place manual: ^1 T+ S5 {/ Q. |9 h, n2 s
alias ~D shape select
& O3 ^# y& [, z+ |. oalias ~M mirror
) D( E+ S5 Z' c8 Z7 {% h( t7 nalias ~W swap components W; R% |7 D$ n$ o% h
alias ~A copy
3 H1 I) N' v1 ?6 p: m4 y) Jalias ~N new3 l( i! N( |) r3 |6 n
alias ~O open
" W0 R; [) n6 J: m% {9 [alias ~S save
6 o0 x9 _3 s1 Q: X2 h. ealias ~Z undo
6 D5 S6 ^: m( g2 y* U. P- x. Y5 lalias Pgup window in
! `; E g6 {1 y) F/ G5 ] }alias Pgdown window out; B. e" }. Y4 f. E' H( G, z$ i
alias ch change
$ a; V# y0 [/ a6 L; |7 q8 Kalias rn rats net3 }- j, w% D D
alias un unrats net& N6 B) m3 }; _5 o- E( W( g1 Y" U
alias rk replay rk
1 N( M2 }2 T! |" Aalias rka replay rka. z8 g5 i: l' ~
alias mf mark fanout, U. k2 m. u% x# J) J" Z
alias uf unmark fanout
* M& ] w3 c! K) xalias cf create fanout
9 v% P9 ^" z4 z% y }1 Tfunckey + subclass -+5 V7 y/ g9 c! m' n/ ~3 T
funckey - subclass --/ U9 |/ Z, f' k, w
alias st 'color -globvis off;color -toggle " ackage Geometry/Silkscreen_Top";color -toggle "Ref Des/Silkscreen_Top";color -toggle "Via Class/Top";color -toggle " in/Top";color -toggle "Board Geometry/Outline";color -toggle "Board Geometry/Silkscreen_Top"'
. k8 H: r3 J. z& L4 S* ~. E1 K0 I7 Zalias sb 'color -globvis off;color -toggle " ackage Geometry/Silkscreen_Bottom";color -toggle "Ref Des/Silkscreen_Bottom";color -toggle "Via Class/Bottom";color -toggle "Pin/Bottom";color -toggle "Board Geometry/Outline";color -toggle "Board Geometry/Silkscreen_Bottom"'6 q6 Y4 T+ D: R# l1 f
alias 1 'color -globvis off;color -toggle "Via Class/Top";color -toggle "Pin/Top";color -toggle "Etch/Top";color -toggle "Package Geometry/Silkscreen_Top";color -toggle "Board Geometry/Outline";color -toggle "Board Geometry/Silkscreen_Top";color -toggle "Drc Error Class/Top"'
$ {9 @+ I* T. M \! galias b 'color -globvis off;color -toggle "Via Class/BOTTOM";color -toggle "Pin/BOTTOM";color -toggle "Etch/BOTTOM";color -toggle "Package Geometry/Silkscreen_Bottom";color -toggle "Board Geometry/Outline";color -toggle "Board Geometry/Silkscreen_Bottom";color -toggle "Drc Error Class/Bottom"') ?' {- M7 G+ [8 C5 a! A
alias sa 'color -globvis on'; I: I- M- {% V- \0 S% ]7 k; V; K
alias ba 'color -globvis off'0 t6 J; M1 T5 u. h9 y" E
0 D) J( N" V2 j' u+ R6 s$ d我自己的快捷键设置,自己感觉很好用,分享下,这个看个人习惯,自己设置,用熟了能很大程度上提高效率
7 H! y1 [) ?. I! w2 Q/ m& k) g" i$ c; A表层和丝印等层可以通过输入定义的命令来调,内层暂时没办法通过命令来调,因为名字不是很固定,如:
8 ?9 ~0 f8 z2 P# }& w4 c' C- @alias 2 'color -globvis off;color -toggle "Via Class/L02_*";color -toggle "Etch/L02_*";color -toggle "Board Geometry/Outline"'
2 |" q) c5 v2 T# ~* V2 l* P但是*没办法识别,所以这个命令没法调用
# G9 q) d" I4 N如果哪位大神研究出来了,别忘了分享下哈 2 @/ v$ a7 K# ?( p
4 n+ @+ D8 m9 K4 r: K
9 I0 G( c3 _( u& W# T1 e |
