请教一下各位大师,我用同一个板子出gerber时,用16.3版本的出显示successfully completed,但用16.6版本的出就会产生如附件中的警告:请各位大师帮忙看看有什么办法可以解决这个问题。谢谢啦!
. I, q* [: b7 X( m---- Photoplot outline rectangle not found; using drawing extents.
: \; s9 v$ f3 v( w6 U, ^. [& R- Y
9 v% e# O( [3 M8 ^ x3 {3 C0 bResults from parameter file ...
* a: N6 w% `2 z: E4 o DEVICE-TYPE GERBER_RS274X' r2 U( \3 S/ I4 w3 h8 m
OUTPUT-UNITS INCHES9 ^* e% b+ I+ j4 ^% w" Q( W; l/ ]
FILM-SIZE 2400000 1600000
8 P+ { n/ g# D" d- w8 c4 \. M3 a FORMAT 2.5
7 b8 }6 J& M) H& }, ~0 [+ J ABORT-ON-ERROR NO
1 S8 S( U* w0 ?8 [2 {, E; `, _ SCALE 1+ X5 S' w, R5 ?# t
SUPPRESS-LEAD-ZEROES YES
; K. l7 [0 Q& N: P4 b# N SUPPRESS-TRAIL-ZEROES NO) Y a9 j. e- {% F3 F
SUPPRESS-EQUAL YES
& U D$ W* b1 l% y$ Y5 I4 {2 P, I6 w6 } UNDEF-APT-CONT NO* d V0 z Z4 R1 N
+ I: a0 ^7 w( }/ a# O================================================================, d- a$ g0 Q9 V! u6 l) d
PROCESSING FILM < PASTEMASK_TOP >) T) U/ o# h5 L, x& S1 R* B8 {
TO FILE < F:/ZHWS/gerber/PASTEMASK_TOP.art > ...' \( T% C4 X& k" z- [- C
0 W& m0 {! z& K7 R; P FILM PARAMETERS :; I, P6 A6 S! A. R# o9 }5 `8 x9 B
---------------------------------------------------------; x6 j6 u/ |& b! t9 E& w
Undefined line width 6.00% i F- p" a6 _7 V4 W
Mirror code NONE( {5 E7 M# w) o
Rotate angle NONE4 i. o7 {" {6 c. p9 L
Offset x: 0.00
/ e- B* J; P, ?# v8 r" l3 t& v ~% ]/ s Offset y: 0.00
) m3 f0 @8 X3 e) S2 V. q/ o1 o Plot negative NO
4 x' O4 p" \$ n" O: y( B: R Suppress unconnected internal pads NO. i5 e7 b2 N* j6 \/ F
Draw holes only NO
1 i, i$ |, P. |9 j; Q( Z5 l# S" @7 l) s- E5 d
APERTURES USED:7 [; o, ~- Y' z: a6 n: d
--------------------------------------------------------- ]0 c& {/ x' { s
TYPE SIZE/NAME ROT MIRROR MODE " N% w+ v4 N3 ^+ h4 p) O) p7 Z
---------------------------------------------------------2 v6 D" V) n3 O+ D+ i! O: T
CIRCLE 0.00500 DARK 0 ]( ^& F* L: U4 p3 t6 m
CIRCLE 0.01200 DARK 1 I' ?& P* Q6 T
CIRCLE 0.01400 DARK ; @3 [ G& n# D# o
CIRCLE 0.02126 DARK
) f5 D0 i) r* f/ z SQUARE 0.02000 0.000 NO DARK * P& D7 g3 X+ Q" c& D) z
SQUARE 0.03900 0.000 NO DARK
+ g; C. X5 g8 n SQUARE 0.13110 0.000 NO DARK 3 A+ @2 _- G1 p; J' q# f
RECTANGLE 0.00787 x 0.02677 0.000 NO DARK
4 l1 N( n8 e! |3 L5 s l$ ^, `) R/ @ RECTANGLE 0.01000 x 0.02800 0.000 NO DARK ! R9 @1 W* R: ^& i- X
RECTANGLE 0.01100 x 0.02100 0.000 NO DARK % a" G+ i% K/ ]% o( p1 d9 U
RECTANGLE 0.01575 x 0.06102 0.000 NO DARK ) a' _. r8 M! q( v9 n1 x5 ~2 @5 Z
RECTANGLE 0.01968 x 0.02362 45.000 NO DARK + j+ o2 ~1 L+ }) h# k- Y1 u& j ~
RECTANGLE 0.01968 x 0.02362 90.000 NO DARK
' X4 K$ P) P2 _+ G2 [7 h RECTANGLE 0.01968 x 0.02362 135.000 NO DARK 0 h% s) v5 s$ v' f6 a5 [
RECTANGLE 0.01969 x 0.06299 0.000 NO DARK % n" I5 ~; c- k# d# ^( L
RECTANGLE 0.02000 x 0.02000 0.000 NO DARK 1 |4 k: O0 j8 R* z4 V H; [
RECTANGLE 0.02000 x 0.02000 90.000 NO DARK
' r3 E( j$ H1 ?! w H- c4 k# g RECTANGLE 0.02165 x 0.02362 0.000 NO DARK 3 S9 K( k2 O A) q* I L6 j7 N: S
RECTANGLE 0.02200 x 0.02000 90.000 NO DARK
2 B; ?& O. N- X h RECTANGLE 0.02283 x 0.02087 0.000 NO DARK
4 G5 O4 k6 e- | T* b4 r( M! _ RECTANGLE 0.02362 x 0.02756 45.000 NO DARK 5 s1 [& e1 y+ r" q. c
RECTANGLE 0.02362 x 0.02756 90.000 NO DARK
! Z1 E: M1 }! \! R( } RECTANGLE 0.02362 x 0.02756 135.000 NO DARK % U5 f7 K; ~% }. d* _
RECTANGLE 0.02362 x 0.05512 0.000 NO DARK 3 r; c+ \' ]) N% A
RECTANGLE 0.02362 x 0.05512 90.000 NO DARK ' s; K9 I, \# \: _% Y& {2 t2 t
RECTANGLE 0.02800 x 0.03200 0.000 NO DARK - Z+ h, I) J5 ?# ?4 x, q* l; d
RECTANGLE 0.02800 x 0.03200 90.000 NO DARK ' a1 _ @, Y5 G/ R* S& _7 \2 e
RECTANGLE 0.03000 x 0.03200 90.000 NO DARK 5 p' i# a/ i1 j
RECTANGLE 0.03150 x 0.03543 0.000 NO DARK / l) J" U5 d* i% D" R" G
RECTANGLE 0.03150 x 0.03543 90.000 NO DARK
8 Z; K8 D% i2 W RECTANGLE 0.03543 x 0.03346 0.000 NO DARK
, r1 t- d) s1 K) \9 n RECTANGLE 0.03543 x 0.03346 45.000 NO DARK
( c0 D. X3 E6 c" t. C( F RECTANGLE 0.03543 x 0.03346 90.000 NO DARK ! Y5 Z! ^ ]6 k9 W. y
RECTANGLE 0.03543 x 0.03346 135.000 NO DARK ; ]4 [" H" r( r' s4 T0 c
RECTANGLE 0.03900 x 0.05000 0.000 NO DARK
% d4 F6 O& I7 N! G RECTANGLE 0.03937 x 0.05512 0.000 NO DARK ' q1 E* _6 R) L' U- ~7 V& Q; a% [
RECTANGLE 0.04500 x 0.01102 90.000 NO DARK
4 _% k9 P+ i5 J- s( n& C RECTANGLE 0.04724 x 0.03543 0.000 NO DARK
/ e4 w% ~) ~1 x* Z RECTANGLE 0.04724 x 0.12992 90.000 NO DARK / A4 j* M- W) o7 Y
RECTANGLE 0.05000 x 0.02000 90.000 NO DARK
$ u9 s, X+ O! D. M2 V; y) v5 I RECTANGLE 0.05000 x 0.04500 0.000 NO DARK
6 w6 C9 G; j% [+ S+ w: q) X RECTANGLE 0.05000 x 0.05000 0.000 NO DARK
6 l q F" D- s4 `9 R, I' T$ b# Q RECTANGLE 0.05000 x 0.05000 90.000 NO DARK 4 x: a; }2 Q C4 |
RECTANGLE 0.05100 x 0.06300 90.000 NO DARK ) M" c+ F7 D! ?+ }. c+ G' a
RECTANGLE 0.05100 x 0.06500 0.000 NO DARK ' y- U$ Q4 r0 i
RECTANGLE 0.05100 x 0.06500 90.000 NO DARK
$ Y" ^- `8 c$ u" W4 p3 V1 J RECTANGLE 0.05118 x 0.03150 0.000 NO DARK 1 i6 }& F( y' y4 M
RECTANGLE 0.05118 x 0.03150 90.000 NO DARK
* A! a, Z! b# v4 A RECTANGLE 0.05512 x 0.04724 0.000 NO DARK 8 n Q' J% X- h
RECTANGLE 0.06000 x 0.12800 0.000 NO DARK & R9 I$ b5 g4 o7 Z, {
RECTANGLE 0.06000 x 0.12800 90.000 NO DARK
. L" z( _: W1 i) D RECTANGLE 0.06299 x 0.19685 0.000 NO DARK ) u: {" u4 ]$ E- T+ M/ Q2 W$ x5 q
RECTANGLE 0.07087 x 0.09055 0.000 NO DARK * q+ z- `6 N' m+ F/ {1 ]; D
RECTANGLE 0.07087 x 0.09055 90.000 NO DARK
5 J' y2 @7 J7 i2 M- D RECTANGLE 0.08000 x 0.07000 90.000 NO DARK , y/ z6 {2 Y# B& m9 E) {# p s
RECTANGLE 0.11811 x 0.17717 90.000 NO DARK
* ?& F3 m8 k- ^5 i RECTANGLE 0.13000 x 0.06000 0.000 NO DARK 6 r6 b, z4 ^ M! k
RECTANGLE 0.14000 x 0.06000 90.000 NO DARK 5 q* Q) E) I- Z0 @
RECTANGLE 0.16000 x 0.06000 0.000 NO DARK / K. r$ C7 ^# {" W- ~5 `0 }' |) P9 t
RECTANGLE 0.16000 x 0.06000 90.000 NO DARK
7 J4 A+ K; `0 i4 ?+ x RECTANGLE 0.17700 x 0.07100 0.000 NO DARK 6 L- C+ X1 O! s4 h! W; T
OBLONG 0.01100 x 0.04000 0.000 NO DARK
4 x! @2 }: P0 I$ i/ A OBLONG 0.01100 x 0.04000 90.000 NO DARK
! v, v- O$ N! S8 [3 F4 ~& m OBLONG 0.01102 x 0.04500 90.000 NO DARK E. ~3 w& w+ E/ g3 }5 L) [
OBLONG 0.01969 x 0.06299 0.000 NO DARK 5 h9 ~' }3 x3 y* R# y
OBLONG 0.02500 x 0.06400 0.000 NO DARK
! p% q: w9 ^' I$ ~% l; R1 ^ OBLONG 0.02500 x 0.06400 90.000 NO DARK " P. k. k8 G4 D/ C/ ~, K
OBLONG 0.02500 x 0.07000 0.000 NO DARK + C. n6 m0 ^. u: R7 {$ d
OBLONG 0.02500 x 0.07000 90.000 NO DARK + E5 C; }( @& W- A+ I( F. ]% a
OBLONG 0.04500 x 0.01102 90.000 NO DARK 6 F! q" a# _) N9 z
PAD SHAPE C1005_PAD_C 0.000 NO DARK # J, N7 S! y b$ C, f3 [0 f
PAD SHAPE C1005_PAD_C 45.000 NO DARK 1 v& B' I& ]* Q! S% r+ H
PAD SHAPE C1005_PAD_C 90.000 NO DARK
. F6 x1 N( P" } PAD SHAPE C1005_PAD_C 135.000 NO DARK ( N% z2 R! D* R+ N4 ` z2 K8 ~
PAD SHAPE SRX4_65Y6_20R0_10 180.000 NO DARK & j% o5 e" {+ w U3 N1 o
PAD SHAPE C1005_PAD_C 180.000 NO DARK
+ _, Q$ ?. E6 c PAD SHAPE C1005_PAD_C 225.000 NO DARK
i s3 [; G; _$ L. _% Q PAD SHAPE C1005_PAD_C 270.000 NO DARK
# v+ o. X2 r! |' C PAD SHAPE C1005_PAD_C 315.000 NO DARK # I3 t, Y z r4 u0 e
PASTEMASK_TOP created.
" l9 a) M! I' d5 s9 K Y4 U# _- T/ G: d2 p
# F* G8 p; U1 a x4 G1 E PROCESSING FILM < DILL >
6 `, W, o3 Z6 M1 z' u7 v! L' H- P TO FILE < F:/ZHWS/gerber/DILL.art > ...
& O4 e, s$ n' U, n' d+ _9 m: T- t6 D) V================================================================
) l# \/ z4 W, s FILM PARAMETERS :4 ~% M' E! r: g
/ S z7 m8 i. k Undefined line width 6.003 L$ k' ~* ~9 ^ i
Mirror code NONE
1 G8 F0 g; J$ d8 H; A$ T& E Rotate angle NONE
( A$ G/ J0 y+ k a; U* t Offset x: 0.00
/ o0 W0 L' F7 V- Y Offset y: 0.001 s9 ~- }2 Z0 {& _! `
Plot negative NO% F- a& x& K' N0 y9 Z
& J+ |3 q$ t! F Draw holes only NO
1 B0 x2 \& u: ^# W! g WARNING: 0 width line found at (5983.28 -5217.99)2 i' f+ d3 L5 E
... using undefined line width of 6.00
- P; T/ X5 b c6 _, H WARNING: Multiple 0 width lines; all will be treated the same as the first.
( K" I4 N* h& T, `; M0 a ... using undefined line width of 6.00
, B" |/ ~# p5 }0 o+ D( v% _/ ?! {& i6 c4 b5 Y7 h7 l
APERTURES USED:9 c$ @2 _! {& {' R% f( N3 H
---------------------------------------------------------8 H7 F F" N' k) Q. p T
TYPE SIZE/NAME ROT MIRROR MODE 5 j6 Q" j" C# n+ i& S/ E4 K
7 ]0 |. }! u# c- g% V( E$ b5 @+ g CIRCLE 0.00500 DARK
& }+ D* a+ I) e: B CIRCLE 0.00600 DARK
2 a: f7 G7 @( l/ E) l CIRCLE 0.01000 DARK ! H, g' f) E" |7 T
DILL created with warnings
# A# ~; y) |$ E- K6 J$ u
( ?; f* ^# f* z. A2 ]" n2 Q6 ~, E================================================================
$ c9 `' Q H; |) z( u9 ~& b PROCESSING FILM < PASTEMASK_BOT >+ Q* s% o2 v' L* u$ W6 ?
TO FILE < F:/ZHWS/gerber/PASTEMASK_BOT.art > ...
5 p8 C7 A6 L; B) Z, v+ y, T================================================================. a# f5 Z$ ]& y, R2 L5 q9 B
FILM PARAMETERS :" e$ p& q; {6 h3 C! h3 O. ^
---------------------------------------------------------# m/ I% }- q6 ~4 ~: f
Undefined line width 6.00$ `0 k; R) G: V& i0 [- X8 [
Mirror code NONE- L9 H3 u4 @5 d# f0 b+ G
Rotate angle NONE
! Y+ e9 V; C6 ^& ]( G' b9 ` Offset x: 0.00
' g& `- g9 R3 L7 _( f Offset y: 0.00
( j: u7 N9 m! X5 J2 L4 E Plot negative NO
0 q% |, }2 R: P6 L0 a& u Suppress unconnected internal pads NO
6 R; T* K& f3 c& }* y Draw holes only NO$ Z9 f- r* N7 [8 g& R' {
8 f0 W! ]: t( H: s% c' z APERTURES USED:2 j; M3 ?9 H: o+ n# A3 o+ v9 T9 Q
5 b, Q- i$ O0 R0 j1 c TYPE SIZE/NAME ROT MIRROR MODE 9 Q, P* s6 B" Z, L Y' s9 j
0 c; M7 B3 ]( e' ^0 I5 h CIRCLE 0.00500 DARK
% K( G; f) h% S" r9 q+ {: i SQUARE 0.02000 0.000 NO DARK
+ ~* _# j5 c( z SQUARE 0.03900 0.000 NO DARK
' c! P2 W) C. ?5 C! w SQUARE 0.04700 0.000 NO DARK
$ m, k4 T" ?9 Q9 _- Y, j: p4 V RECTANGLE 0.01000 x 0.05800 90.000 NO DARK 9 M& C1 z8 C% b* C. b' [: q1 |4 \7 ]
$ B3 s7 v M9 b0 ?2 }7 t1 u RECTANGLE 0.02000 x 0.02000 0.000 NO DARK
3 F' [! ^+ I$ e5 f. h6 |) H RECTANGLE 0.02000 x 0.02000 90.000 NO DARK
* v8 H, K' L. ^) W: k5 M RECTANGLE 0.02000 x 0.06000 0.000 NO DARK . }& U- f! c F# ]+ S
RECTANGLE 0.02165 x 0.02362 90.000 NO DARK 5 n& H& b; Y# }+ O/ P+ ~( Q C
7 H0 l: r+ l$ w+ Y' i6 { RECTANGLE 0.02283 x 0.02087 90.000 NO DARK ( Z. s. V1 L1 ^" T' X. C) L2 }
RECTANGLE 0.02362 x 0.02756 90.000 NO DARK ( D# A& G( z$ K8 @( j
RECTANGLE 0.02800 x 0.03200 0.000 NO DARK 4 C* D3 v( I# w! n: u
% U- a0 K+ t; ]( {5 A- m+ c% s8 g. N RECTANGLE 0.03000 x 0.03200 0.000 NO DARK
# {" ~1 P8 Y) l9 M0 O) L RECTANGLE 0.03000 x 0.03200 90.000 NO DARK $ }0 T8 M% p7 Q! U% |5 o0 _9 ^4 \1 b
7 y3 v: p+ X' Q& N2 D, u% o7 N4 u RECTANGLE 0.03543 x 0.03346 90.000 NO DARK - J: Y9 p6 c. A0 Z* m) d
( @; e2 \ ^) ~8 R u RECTANGLE 0.03900 x 0.05000 90.000 NO DARK
9 W5 `/ o8 f& {% x8 z6 ~ RECTANGLE 0.03937 x 0.05512 0.000 NO DARK ' g3 \+ z, S- ]5 Q
RECTANGLE 0.03937 x 0.05512 90.000 NO DARK
+ H* T9 T }% e6 C RECTANGLE 0.04000 x 0.05000 0.000 NO DARK % G) C7 n8 p; f9 Q7 v- t
RECTANGLE 0.04000 x 0.05000 90.000 NO DARK 5 N" H& }' S8 ? H7 {
J" X7 d2 x. h6 q. b& l RECTANGLE 0.05000 x 0.05000 0.000 NO DARK ; V) ~* l0 m( v
* F/ d/ z4 I& [* A. c( s RECTANGLE 0.05100 x 0.06500 90.000 NO DARK % W( \( e2 ]0 f4 n( n+ a
RECTANGLE 0.06800 x 0.09000 90.000 NO DARK
5 d0 H6 _& G: I) e' ~ RECTANGLE 0.08700 x 0.02400 0.000 NO DARK
5 f7 ?6 w# {* I1 W2 C5 n o RECTANGLE 0.09055 x 0.09843 90.000 NO DARK
5 J& t9 t5 Q' c" J OBLONG 0.03200 x 0.04700 0.000 NO DARK ' d" {. d) K+ H
OBLONG 0.08700 x 0.02400 0.000 NO DARK
/ l' @0 {$ g- z0 I PAD SHAPE SH19_20LNO_T 0.000 YES DARK
% V g3 f6 }3 H) c, ~2 n PAD SHAPE SHAPE72X180 0.000 YES DARK / w# W: A# v5 V- w7 L1 @
PAD SHAPE SH19_20RNO_T 0.000 YES DARK
! ]( X' e$ R( o1 f+ O1 L PAD SHAPE C1005_PAD_C 0.000 YES DARK
% v* s3 L/ H. V8 N/ } PAD SHAPE C1005_PAD_C 90.000 YES DARK
% o0 |( H( U, @3 O- c* f# x PAD SHAPE SH19_20LNO_T 90.000 YES DARK * V/ b+ k w0 S
PAD SHAPE SH19_20RNO_T 90.000 YES DARK ; x6 s' u8 z' a& N. ^
PAD SHAPE SH19_20LNO_T 180.000 YES DARK
, Y* L3 ]& F, O- G+ n( ]3 z PAD SHAPE C1005_PAD_C 180.000 YES DARK
8 l) `0 D) L1 ?, ~1 T( K PAD SHAPE SH19_20RNO_T 180.000 YES DARK
2 P/ \& p9 A, F; g& b9 ^; ` PAD SHAPE C1005_PAD_C 270.000 YES DARK
& |2 v! i7 Z- {. D; {# x, T% q PAD SHAPE SH19_20RNO_T 270.000 YES DARK
1 G& o7 M4 H& b+ Z: O3 ?+ w0 a PAD SHAPE SH19_20LNO_T 270.000 YES DARK 0 |) D) O) ~2 B- J
PASTEMASK_BOT created.) Q" U0 G2 j, T) O( Q* k/ S) ?( b$ D
