查看: 1628|回复: 13
出光绘有疑问
    2020-3-22 15:19
    发表于 2014-12-10 16:32 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
    出GB时有警报: WARNING: Segment with same start and end points at
    0 l2 `$ m2 [: ^$ B" Q; Z        (-398.150 -711.208) will be ignored. Increasing output- Y" ]* G# k: X( l" ]- x/ D
            accuracy may allow segment to be generated.
    2 T7 S* n- H, z! V后按照所提示的坐标有修改走线,发现原走线在所示坐标处有结点(删除cline segs可以发现,删除clines则发现不了此结点),删除后重新出GB,还是有警告出现,但是什么坐标什么原因都没有显示,如下图 WARNING: Film contains DRC error(s).2 g0 {/ B, Y5 n( d* @% R, h
    $ Z1 X( n. V. e- b$ ]/ j
    7 e) |, \+ N& a  s$ q. e4 `
      APERTURES USED:
    ) V3 U/ P6 `) J: W  ---------------------------------------------------------
    7 ~2 W0 u/ [, H! ~  TYPE       SIZE/NAME                   ROT   MIRROR MODE * _% j! @* U' ?
    1 T9 p& G* z2 d- A; j- [" D) N& @  CIRCLE     0.00000                                  DARK
    ) F+ I% j6 i# g( W1 g  CIRCLE     0.00400                                  DARK , g: i6 t4 m3 X! t6 `
      CIRCLE     0.00450                                  DARK ! r5 ]4 D7 y# `2 c
      CIRCLE     0.00500                                  DARK
    5 m9 |2 C7 W4 |* [  CIRCLE     0.00600                                  DARK $ a8 k& Z4 B* H: e, a& i
      CIRCLE     0.00611                                  DARK
    " F6 b- g0 j  a( m2 f" H  CIRCLE     0.00800                                  DARK
    ; z6 A2 {+ w- O3 j) m  CIRCLE     0.01000                                  DARK
    3 r# D9 N1 E2 _. N  e' e  CIRCLE     0.01200                                  DARK 2 y6 j6 H6 \8 i! T* H/ n  k
      CIRCLE     0.01500                                  DARK ; i5 [5 b" m$ p& O* W
      CIRCLE     0.02000                                  DARK
    $ K" b/ S" s) Y6 s; y! i, M2 f* g  CIRCLE     0.02500                                  DARK 2 d' e6 o1 F; t
      CIRCLE     0.05000                                  DARK , Y6 a" p8 N) ?5 F" H1 t1 s, R* N
      CIRCLE     0.06500                                  DARK 9 b' @( h! P8 X2 b- L
      CIRCLE     0.07500                                  DARK 6 ^2 C! D' r9 \6 G
      CIRCLE     0.27500                                  DARK
    : A  F. w/ m4 J  A' w  OBLONG     0.10000     x 0.07000       0.000 NO     DARK
    ( n0 V( Z, p: P  OBLONG     0.16500     x 0.08000      90.000 NO     DARK 8 q- v' J$ G1 f& o+ u
    : _1 M0 G/ a& t     L4 created with warnings% y- G; Z0 H- `" \$ s
    4 Y* q% Y0 n9 w2 c4 u$ D* W( l- |3 C
    & l- n# O- X# K* a- I; ?
    / Z" l+ d2 w; l& P- x* F* t/ E SUMMARY:
    - W5 f. P' {7 }' L6 M: Z* N        L4 created with warnings
    & f( r. J+ q0 ^8 V- O$ c& ~7 k( s
    & K; G- ^6 l* j( v; F& z ARTWORK had warnings
    , \- s. L* R% I; G, {6 k% L* A请问各位大神这是什么情况?怎样才能让它不出warnings?所用版本为16.5 52号补丁,谢谢!
    1 e  V- ~# m5 W2 _5 Q3 v
    2024-2-21 15:59
  • 签到天数: 313 天
    [LV.8]以坛为家I
    发表于 2014-12-10 16:38 | 只看该作者
    Tools->DataBase Check一下看; |* [, c5 ~# Z* E0 ^2 w5 I
    一般来说warnings是可以忽略的。
    2020-3-22 15:19
     楼主| 发表于 2014-12-10 17:37 | 只看该作者
    dzkcool 发表于 2014-12-10 16:38
    $ d: |8 c" ~' D' j; tTools->DataBase Check一下看5 l, Q  F3 \# j! ^# I* z( t
    一般来说warnings是可以忽略的。
      R( W4 \5 h. F( Z! w做了几遍Database check还是提示warnings但没有出任何坐标任何项目,我也听很多人说warnings是可以忽略的,但是因为同一个板子在另一台机WIN7,16.3版本的和winxp 16.5(没装补丁)版本中都没有warnings出现,所以有点担心。# p4 P" Y* `* K0 s
    2024-2-21 15:59
  • 签到天数: 313 天
    [LV.8]以坛为家I
    发表于 2014-12-10 19:11 | 只看该作者
    你用的什么版本?补丁跟其他电脑的也一样吗?
    2020-3-22 15:19
     楼主| 发表于 2014-12-11 08:49 | 只看该作者
    dzkcool 发表于 2014-12-10 19:11, X  i) p" p! F" t4 N0 ~7 n0 @! u6 m
    - ]/ e+ v: Q% m4 s& x目前是在WIN7 32 16.5 52号补丁,同事的WIN7 32 16.3没装补丁GB不出警告的,但是看那个结点也确实存在,那个点Dangling lines又检查不出来,我记得以前用的15.5,15.7那些版本都是板子上也会有那种情况的,但是出GB从来没出现过警告,不知道为什么这次换16.5就出这种问题。有一台XP下16.5没装补丁前这些警告也不出现。! O4 m) E- j1 u9 P' e
    2020-7-21 15:38
  • 签到天数: 21 天
    [LV.4]偶尔看看III
    发表于 2014-12-11 08:54 | 只看该作者
    WARNING: Film contains DRC error(s).% f3 V; k9 q( ?4 V7 r
    2 N8 \  e, t* `: A/ Q$ q
    警告不就是这个么。。。你这层上是不是有故意留下的drc啊,drc是你故意留的,那这种警告就可以忽略了啊
    2020-3-22 15:19
     楼主| 发表于 2014-12-11 09:38 | 只看该作者
    kinglangji 发表于 2014-12-11 08:54
    . r9 E1 z9 d2 s$ C# kWARNING: Film contains DRC error(s).
      v' Z$ K8 _+ u5 v3 T4 s" W  t2 }1 u
    - l& Y  B: ?# S警告不就是这个么。。。你这层上是不是有故意留下的drc啊,drc是 ...
    % d6 A" w( [0 H
    这层没有DRC啊,我就是想不通为什么同一个板子在我这里出警告,在别人16.3版那就不出,我就担心我是软件没装好或者在哪设定没设好。
    & ^2 A& O+ V# x+ R' ~
    2020-7-21 15:38
  • 签到天数: 21 天
    [LV.4]偶尔看看III
    发表于 2014-12-11 09:48 | 只看该作者
    树苗宝宝 发表于 2014-12-11 09:38$ q+ g9 F' ^- p, O: V7 y4 L
    这层没有DRC啊,我就是想不通为什么同一个板子在我这里出警告,在别人16.3版那就不出,我就担心我是软件 ...
    5 {4 ~2 L7 u: O& e1 g
    你再去找找吧,感觉软件是不会连有没有drc都弄错的。
    * V: |8 f: H8 w) W1 A2 G4 d可能在别人机器上没有drc,在你机器上因为没更新或者dbcheck什么的就有drc了呢。。
    3 K& J' T( c* M/ \1 Y' P
    8 }& l( G+ N, L! S5 i不对勿喷,纯属猜测~~
    7 C) M9 S0 o: B, U
    参与人数 1威望 +1 收起 理由
    树苗宝宝 + 1 谢谢回复
    2024-2-21 15:59
  • 签到天数: 313 天
    [LV.8]以坛为家I
    发表于 2014-12-11 09:49 | 只看该作者
    把photoplot.log文件发上来看下,最好把PCB也发上来。
    参与人数 1威望 +2 收起 理由
    树苗宝宝 + 2 谢谢回复
    2020-3-22 15:19
     楼主| 发表于 2014-12-11 10:26 | 只看该作者
    dzkcool 发表于 2014-12-11 09:49
    ( u4 ~  }& A- S% [把photoplot.log文件发上来看下,最好把PCB也发上来。
    - [6 ?& v0 n. F+ p% q; s# l6 h
    谢谢( }3 _5 _* Q5 C$ x2 F1 m
    test.zip
    1.31 MB, 下载次数: 5, 下载积分: 威望 -5
    2020-3-22 15:19
     楼主| 发表于 2014-12-11 10:32 | 只看该作者
    kinglangji 发表于 2014-12-11 09:48
    & v& n+ z, B0 l  s' {+ R你再去找找吧,感觉软件是不会连有没有drc都弄错的。; ~# f& K$ h" h0 q; {
    可能在别人机器上没有drc,在你机器上因为没更新或 ...
    5 @7 u# E2 B+ @1 ^2 s
    这个层面没错误,但在其它层面有,板子的螺丝孔上有可以忽略的DRC,要是把这些DRC都弄掉,所有的警告都没了,但是真的在16.3版DRC存在也是不出警告的。 谢谢回复
    2020-7-21 15:38
  • 签到天数: 21 天
    [LV.4]偶尔看看III
    发表于 2014-12-11 10:54 | 只看该作者
    放到很大之后发现那里有个缺角,应该是那个焊盘自动避开造成的。。。。
    6 Q) f0 y7 E, G# k把shape到那个焊盘角的距离拉大一点就好了。。。( F1 i0 V# [4 N4 b4 T
    跟精度什么的有关系吧。 。。
    2020-7-21 15:38
  • 签到天数: 21 天
    [LV.4]偶尔看看III
    13#
    发表于 2014-12-11 11:01 | 只看该作者
    本帖最后由 kinglangji 于 2014-12-11 11:03 编辑 ( C$ e3 U+ K2 Z2 u/ V( v0 Q
    0 q7 H4 s0 _5 s! S+ K8 O1 t又试验了下,之前说的你和别人电脑的区别,应该是设计中的小数点的问题,我的小数点mil为单位时也是4位,如果User preference中那个小数点4位的设置没设,那机器可能会自动给变成2位,在2位的情况下出gerber,就是没有warning的。。因为那个小的缺角在2位小数点时,输出不存在。。。。2 U: A) l& p5 L0 D; Z
    * T$ @1 T' h: [' E: u5 }9 I* r) y$ U哎。。。这么较真的孩纸,,很有前途哦~
    2024-2-21 15:59
  • 签到天数: 313 天
    [LV.8]以坛为家I
    14#
    发表于 2014-12-11 11:17 | 只看该作者
    按照楼主的文件会出现kinglangji同学所说的警告,把那个小缺角修一下就可以去掉这个警告。9 Z1 c; e  F# u, u6 S& {! B
    至于WARNING: Film contains DRC error(s).是因为在该层有DRC未消除.+ `" h' v4 f4 `0 W- L
    我用16.3和16.5测试过了,板子的螺丝孔上有可以忽略的DRC,要是把这些DRC都弄掉,这个警告就没了。
    GMT+8, 2025-7-19 15:19 , Processed in 0.156250 second(s), 27 queries , Gzip On.
