查看: 1493|回复: 3
出GERBER时出的错误,请大家帮忙
发表于 2008-9-3 11:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TYPE: GERBER6x002 i, [3 V' j& _" i2 _6 B
* W2 [+ M& ?/ H" gPROCESSING FILM < ART01.art > ...
+ d8 \& R4 _/ g, x$ k( e+ J  ----------------------------------------; V+ [- \  a  K$ T3 u  F5 {
; E1 ?" z" n( P    Film Parameters :$ p6 r, W0 _; m* r
      undefined line width ... 5.00! [( M/ c& c' ]( t# N
      plot wheels allowed .... 1  2  3  4  5  6  7  8  9  10  * H) a: J" `' T' O1 l% @/ u6 k
      mirror code ..... NONE
( V- |7 F. d0 J& V0 p      rotate angle .... NONE
3 F7 j! l4 d2 y      offset X: 0.00     Y: 0.004 |3 s8 `. |" B* z- Q/ l8 x' c
      plot negative ... NO1 j7 r6 H+ x, A3 S% Q
      draw (fill) pads lacking apertures .. NO4 [5 [" u9 ^& W& r- j$ T
      suppress unconnected internal pads .. NO5 W9 C* C$ @4 L8 y( U% ~& k1 O
      make use of rotated apertures ....... NO  O- W$ h" R0 h
  C, v' v3 P0 Z% ^. Z4 D5 _! V+ u  H ERROR: No aperture for RECTANGLE - 20.00 X 25.00 at (3560.00 2580.00) Rotation:   0.073
, l7 g4 `9 `/ y. I7 C ERROR: No aperture for RECTANGLE - 20.00 X 25.00 at (3560.00 2620.00) Rotation:   0.073& w7 @# x' v, y/ Y: p) u& n$ S
ERROR: No aperture for RECTANGLE - 20.00 X 25.00 at (3600.00 2580.00) Rotation:   0.073
" [: r2 {9 G* h2 u+ ~9 O ERROR: No aperture for RECTANGLE - 20.00 X 25.00 at (3600.00 2620.00) Rotation:   0.073
  J$ ~- V1 p$ e* ^  k6 L  C! B6 ] ERROR: No aperture for RECTANGLE - 25.00 X 20.00 at (3640.00 2580.00) Rotation:  89.885* w" H! I) e# i$ ?& `% R9 w9 v+ T
ERROR: No aperture for RECTANGLE - 25.00 X 20.00 at (3640.00 2620.00) Rotation:  89.8858 m8 l3 D6 V( S% B& O( y$ i
ERROR: No aperture for RECTANGLE - 20.00 X 25.00 at (3600.00 2680.00) Rotation:  89.8857 l' C5 j; h; @/ Y, F8 c
ERROR: No aperture for RECTANGLE - 20.00 X 25.00 at (3560.00 2680.00) Rotation:  89.885+ _$ o: ~: A. F, ]) D5 D
+ ~, ?4 R/ ^4 ~& _% x  ERROR: Artwork can't use standard geometries to flash
8 e! u8 O# G: t( l         these odd-rotated (not 0,90,270,180) pads.  This
, d% d, g" u0 P9 e         design requires the use of ROTATED APERTURES.* I$ ^) q/ p$ P- b6 G+ u
(PADSTACK NAME)        (ROTATION)% @; O4 S8 a, B& @+ [7 z) n3 r
SMD20X25                  179.8858 n, q& D1 b2 U* E% ?5 F5 S
SMD20X25                  180.073
/ r7 m( o; s6 d8 b: a- _/ \$ O& C" S) g SMD20X25                  269.885
. Q/ |' Q/ ]; S5 D2 S' h- K. c* K0 E# n& @8 ]& l! Y
  SUMMARY OF MISSING APERTURES:$ c$ L* |1 Z7 `& T9 F
    RECTANGLE         20     25          89.885    (2)                 , ?6 L$ l7 r7 e, P
    RECTANGLE         25     20          89.885    (2)
* U, I1 r9 Z& ]! {6 t    RECTANGLE         20     25           0.073    (4)
- ^6 _( U& e; I: x, K( A# o, U, D, E) U3 c, k
... error in film, proceed to next!
- X$ }/ h( e1 u/ m3 O *** ERROR with ART01.art
 楼主| 发表于 2008-9-3 11:30 | 只看该作者
用GERBER RS274X出就没问题,为何?
发表于 2008-9-3 14:10 | 只看该作者
把产生错误的层,draw missing pad apertures 钩上试一下。
 楼主| 发表于 2008-9-3 14:47 | 只看该作者
你说的我试过,但出的GERBER在CAM350里还是报错
GMT+8, 2025-11-1 21:23 , Processed in 0.140625 second(s), 24 queries , Gzip On.
