查看: 9862|回复: 46
[Cadence Sigrity] Base_ASI16.64.000-32&64_wint_1of1
发表于 2014-9-26 01:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
游客,如果您要查看本帖隐藏内容请回复
! `. t* f5 H* x; W+ E& w; S$ m, X
; k* I  R& ?, W' D: S2 T2 T
DATE: 9-19-2014    HOTFIX VERSION: 002
0 w8 R4 r; b6 h===================================================================================================================================                        0 i3 b/ R' b% e/ L0 A1 o  L$ Q( l
CCRID          PRODUCT           PRODUCTLEVEL2           TITLE* m7 Z, q+ K" S: P5 W8 \
2 `1 Z6 {' Y" _* N7 d# D' E1310730          3D_EM                   ENG                        Generate 3D mesh crash
$ h6 E" |: d, ^- [+ {1313431          3D_EM                   GUI                        Cut and stitch option of 3DEM& m; E1 h/ a' y, ?' E% F
1307785          ASI_PI           GUI                        Decap Configuration GUI does not update until you deselect then select GND
# R- B( z4 Z3 Q6 g% }1278238          POWERDC           ENG_ELECTRICAL        PowerDC report Block diagram1 q% J: r' Z0 U! Y
1304038          POWERDC           ENG_ELECTRICAL        Vias with overlapping copper - wrong via current result
! v' g$ Q. X% n3 h3 Y# q, [1308838          POWERDC           ENG_ELECTRICAL        PowerDC simulation hang on 100%7 }3 f, D2 j" X5 `, b/ z: [8 M# I9 y# R
1312736          POWERDC           ENG_THERMAL                PowerDC ET cosim fails                        % }& I* ?' I/ [. n
1238318          POWERSI           OTHER                S-parameter plots can be varied depending on PSI version
% Q; C1 O) J! @2 d7 q1279123          POWERSI           OTHER                PowerSI batch mode command
/ [4 F  i6 r: s4 X1305312          POWERSI           GUI                        Setup port pane takes 18 sec too long compare to previous version
2 ~, i. a- p, _$ y1306252          POWERSI           ENG                        4 Different Inductances (Impedances) are obtained from PSI version 12.0, 12.1, 13.0 and 14.0
" D: i$ g% G- k) h3 @1307368          POWERSI           ENG                        Error in PowerSI for DC calculation with PowerDC* h8 v# L  `' ^* s, F; Z
1308785          POWERSI           ENG                        PowerSI - Internal Warning E3302 Undefined error
8 O6 {  \! J7 y3 H% B+ n7 [0 [. k1308839          POWERSI           OTHER                Option to wait for license in a queue based batch mode running of PSI PDC BBS8 R4 J; A! b8 r7 o( i% C
1309711          POWERSI           ENG                        Significant difference in impedance value in PowerSI version 16.63 and 16.62
4 a5 z, [1 p# W  P1313257          POWERSI           GUI                        PowerSI Impedance Plot Display
% W0 l" I% N  l' I' [$ V3 j1313994          POWERSI           ENG                        Mismatched Z results in PowerSI V16.63 VS V16.64
% H+ ^: Q4 `  q1314038          POWERSI           GUI                        Vias are created after saving spd file
6 @8 R: X+ X! [) y# q1314144          POWERSI           ENG                        Multi Structure simulation is not progressing by v14.0.2.08141
" S3 T4 o0 O: u5 F$ S9 k$ @) t1297035          SPEED2000           GUI_SPDGEN                SystemSI PBA Layout will not extract using SPDGEN
- f3 ?# n) b& h' v2 P3 t- O+ Y1308141          SPEED2000           GUI_SPDGEN                SI Metrics Result Display Not updating: T; N& y, W6 ^' G2 w- h9 S
1309133          SPEED2000           GUI_SPDGEN                Defining stimulus pattern0 o; g$ f& B: l. ?3 r0 C0 U2 i
1311897          SPEED2000           GUI_SPDSIM                DDR threshold value issue
3 {2 L' q# A$ F1312583          SPEED2000           ENG_SPDSIM                Inconsistent RX results from 2 simulation engines                        : E; q3 S* U6 g; M' T* n. B7 R# h
1306950          SYSTEMSI           GUI_TESTBENCH        Please lift restriction that at least one Rx IBIS model is required
4 z" w/ ]# _7 i; m" j1287152          T2B                   OTHER                T2B gets abnormal end at IBIS Plus setting; B6 l6 p! T/ \+ G
1292309          T2B                   DOC                        Please update .t2b File Format Reference Guide
' M% H) G( ]3 S+ n9 o5 H9 Z/ H, T1308023          T2B                   OTHER                T2B crashed when generate PLUS model at v14.0.2.07181
  o  v* N) }7 I' A# @1 K1301045          TRANSLATOR           SPDLINKS                Missing PWR plane when translating a BRD file
# u/ G$ O8 U* o1314747          TRANSLATOR           CR5K2SPD                Support "Remove Non Functional pads" option
3 \4 z  p) c# I; G6 u1316045          TRANSLATOR           SPDLINKS                Open nets created when translating an MCM file
! r: M0 b$ p+ [- k: w6 k" @1316212          TRANSLATOR           SPDLINKS                Anti-pads not in the original mcm file were created when translating an MCM file
) m% B  c' i9 C2 S# c/ s1300351          XTRACTIM           OTHER                XtractIM-EPA: Issue about Pin Groups area in Grouped Pins Property! D0 }6 D& u4 `( @& f" K* x9 u: f
1302576          XTRACTIM           ENG                        Linux hangs when running EPA in XtractIM
  u7 Q/ ^. t+ b' D! z. X1 p: T% n4 S
/ O/ D6 q+ @" e) G( {& b
6 }& b) Y& K4 ^, K& E$ b1 `  f2 z' E7 J5 a7 a) E
1 r; O) ~: p+ ]$ W: N( U+ X' v/ U8 G( z. b. r/ d
DATE: 8-22-2014    HOTFIX VERSION: 001
+ s% ^' D+ q" c# R===================================================================================================================================
  X$ w  U/ [6 w/ U) q, |& N6 D; F% ~CCRID          PRODUCT           PRODUCTLEVEL2           TITLE$ Z# i* k7 _+ T! Y2 l  p6 {& [8 S
7 a5 N$ P/ l- n! r5 W) `$ J+ t1292437          ASI_SI           GUI                        Topology about DDR_CLK0_P and _N can not be extracted in APSI; e6 H" ~' K, V( V5 r! u; t# ~
1295310          ASI_SI           GUI                        DecapGenerator.exe GUI misspelled Manufacturer
1 [- L5 q+ W( j7 W+ s) p7 s1306879          ASI_SI           OTHER                Opening all xxx.sim after sweep simulation does not work correctly with allegro Sigrity SI Base.
1 {4 r1 }( D  F' j1294854   OPTIMIZEPI           ENG                        Script error message while creating sign-off Report                        . l0 \' K0 ~3 E! h
1289946          POWERDC           ENG_ELECTRICAL        Display results for the components in result table " ^% J; `% |' {1 k
1293076          POWERDC           GUI_THERMAL                Export thermal setting of components into CSV file for reuse
" R: ]5 e3 a6 {6 |, v% E/ `. E1305641          POWERDC           OTHER                Fix a bug related to generate block diagram in sign-off report                        , R) L& _0 A- k
1293285          POWERSI           GUI                        Turned pad after shape processing3 T! A. z+ c% _9 @* I' D: Y( o
1294605          POWERSI           ENG                        PowerSI crashes while extracting the DC point through PowerDC
( o- t: W8 Y' Q# q0 o1302465          POWERSI           ELECTRICAL_CHECKS        Impedance Overlay in Layout does not work properly                        ) G( N& O0 K5 ~- O% w9 I3 L
1277963          SPEED2000           GUI_SPDGEN                Support different simulation frequency for different net  in a simulation
" ?" G: _1 b2 `5 ?0 Q% ~5 p% _7 X% O1290038          SPEED2000           GUI_SPDGEN                The data pattern only support maximum 64 bit in S2K.
/ d- k7 F! c  U8 `1303503          SPEED2000           ENG_SPDGEN                SPEED2000 sim waveform difference between 12.1.2 and 14.0.2                        % c" ]9 l5 L/ J4 P( h
1297281          SYSTEMSI           GUI_SLA                Multiple Tx driver produces different results between SPDSIM and HSPICE4 y! v; V2 {  ?# p/ g( M: M
1306953          SYSTEMSI           GUI_TESTBENCH        Support 3-STATE IBIS models in Testbench
$ J  R1 a# w' `1295295          TRANSLATOR           BRD2SPD                When load a brd file into PowerSI, some pads were incorrectly rotated                        ) n! k/ [% D7 H, C3 n, R0 `& |
          XTRACTIM           ENG                        By default, coupled line parameter criteria of 2% coupling and 100ps Rise Time are now applied for all nets in new simulation. o  i6 W- n7 E& d- ]
/ b, @6 K; Z4 y# i3 s8 V! _& ]! L7 J7 w; ~0 \/ I2 l/ S/ l/ k. I
( Q. T# K5 S7 X2 l9 l
0 W$ ?, F. H3 f0 C: R1 A/ h2 W, X$ P: p+ @
DATE: 7-25-2014    UPDATE VERSION: 004                        5 F/ k, t3 D1 {6 \
===================================================================================================================================                        $ p+ @8 j! h4 R
' X' ?3 |% R6 V5 g$ w===================================================================================================================================                        - O* L5 g% }! t% u/ C' _6 v
1179055          3D_EM                   GUI                        RLGC plot legend is showing wrong information for diff pairs                0 ~1 z3 }  z6 Q* _
1272892          ASI_SI           SPDIF                SI/PI-Base: Some items in SPDLinks Preference page do not work
) S0 d6 p( Q8 w( d1287995          ASI_SI           SPDIF                PowerSI crashed when open an mcm file directly
5 a0 e0 K5 A! D1291813          BROADBAND_SPICE  ENG                        BroadbanDSPice 13.0.2.03301 does not save license tick                        : s. T) w% ?' K3 _
1227079          POWERDC           ENG_ELECTRICAL        Low CPU usage rate in PowerDC
9 w# m; t: n" D& M+ S9 r5 k8 P$ K1278731          POWERDC           OTHER                Enhancement request for new TCL to select resistance measurement mode5 M  P0 Q/ E9 n* r) e- ^
1283153          POWERDC           GUI_THERMAL                PowerDC Workflow Steps Disabled
% @" s6 x2 m; U( r1285935          POWERDC           GUI_THERMAL                Incorrect ambient temperature reported in PowerDC report        . X; }6 F9 \. J6 O& J
1132375          POWERSI           GUI                        Export to Image File does not work on zoomed images7 b& C  F: q, ?% C5 }
1152594          POWERSI           GUI                        Transform stackup by nodes function --- NG, y. d3 X/ y' }5 I
1155234          POWERSI           GUI                        Network Parameter Display: "Export to Image File" doesn't be saved zoomed images
% N! v- l( m2 @3 ^/ z2 w; e1188062          POWERSI           OTHER                Default setup/workflow required to generate the S-Parameter from PowerSI
1 d2 C: {% x  Y. s) q1218546          POWERSI           OTHER                New TCL command for closing S-parameter file in display( A# @+ D3 j' Y- k: @
1219500          POWERSI           ENG                        convert the narrow shape to trace automatically
/ b6 h9 A' l- C& M1225367          POWERSI           ENG                        The issue about the additional negative node effect in the PowerSI
# p# j* z, O$ Q" t/ B/ L1256030          POWERSI           GUI                        Multiple value field error in a stackup menu+ B: ]: j) V. E1 T* t# m  g
1260657          POWERSI           GUI                        Merge layout issue
7 M# q/ N+ |1 ]# _1277866          POWERSI           ENG                        Port setup error (E2032) when extracting diff pairs9 x; ]2 A+ q8 J$ s
1278918          POWERSI           OTHER                TCL command for Enabling "PowerDC Option" in PowerSI" T) t, e2 p  U* C: m( }* h5 e
1284646          POWERSI           ENG                        PowerSI (13.0.2.04241) crash issue on Windows: V3 b! C5 H8 Q  B3 C! X+ I
1286211          POWERSI           GUI                        Antipad cannot get correctly result in both PowerSI&SPEED2000
9 a6 x6 R+ V& b- m; r4 W1290101          POWERSI           ENG                        PowerSI Mesh error E1201
1 @- f& @( @* f% A1290361          POWERSI           ELECTRICAL_CHECKS        Impedance/Coupling data is not displayed in the window
! _1 o' q2 E! ?0 k1 W  }$ K1290885          POWERSI           ELECTRICAL_CHECKS        Supporting multiple passive components for Trace Coupling calculation( k* B3 M! _7 A! o! ~: s7 L# }: Y
1294165          POWERSI           OTHER                Decap model assignment through a 12.x TCL script creates a extra node in circuit. T4 g$ {7 h  \# X1 l% @9 {
1264081          POWERSI           ENG                        The different results on reverse the pin linkage number in PowerSI
$ r7 A$ }% s8 T+ z. y1 ~1287496          POWERSI           ENG                        PowerSI simulation error                - ]0 y% A6 |2 Y! V% m$ v: l9 P
1090299          SPEED2000           GUI_SPDGEN                Missing TX direction from U4D1 to J4A3
% U$ r7 ]" Y9 s" _5 L1 }1225972          SPEED2000           GUI_SPDGEN                Enhancement - Impedance Check Report - min/max impedance percentage+ i4 u+ u- ]  P/ |5 w
1245196          SPEED2000           GUI_SPDGEN                The bug of impedance plot in PowerSI
4 G: ]% b; i  A6 G# V1263920          SPEED2000           ENG_SPDGEN                Metric Check got flatten waveforms2 s8 F* c& u" d* S9 q9 ]
1264030          SPEED2000           ENG_SPDSIM                SPEED2000 SI Metric Module takes much longer time to sim
* {) I( y3 y2 x5 I1265801          SPEED2000           ENG_SPDGEN                Simulation result was wrong when we chose the driver package model& E( H1 O3 E3 H" ^
1286609          SPEED2000           ENG_SPDSIM                Lack reference plane$ v/ U* g7 w6 B/ `
1288573          SPEED2000           ELECTRICAL_CHECKS        Impedance Checking failed to detect CPW structure/ K0 \3 u6 x* z
1289109          SPEED2000           GUI_SPDGEN                Shorts in the layout when Import in to Sigrity Tools/ L2 J, `9 M# m; m! C
1275268          SPEED2000           ENG_SPDSIM                SPEED2000 crashes in power noise simulation5 I+ n& y/ y  y& ~3 `) I. c
                                                Improve file reading efficiency in spice mode                , A! a( x) ]0 J$ _
1209374          T2B                   GUI                        Support tr0 waveform display
; T5 b) Y# E% h6 e- m) E3 k6 q1216190          T2B                   ENG                        Voltage range for I-V tables in IBIS by T2B& Y8 A& V8 ?' N& I
1265456          T2B                   ENG                        C_Comp ratio b/w Pullup and Pulldown
0 d$ Q& y" }6 ?( I6 t1284945          T2B                   ENG                        [Derate ramp] parameter usage+ X, \" r/ C+ e# J7 B7 J
1285574          T2B                   ENG                        [C_Comp View] does not create the plot file
+ ~% u5 M) w2 K. o# B/ i# Q5 R1287130          T2B                   ENG                        Calculation of T2B Minimum (Vhigh-Vlow)/voltage_range5 J3 }6 m  s6 `0 @0 `
0 y1 d2 [( y# q( l1288011          T2B                   ENG                        T2B will be crashed with "Combine package model" operation* _+ i8 y8 J( e4 y+ F- F6 S
1292415          T2B                   DOC                        T2B: about [By Transient] Keyword! i+ {! y" N% [) M
                                                Disable Spectre call on Windows platform, error message will output% t1 |! L$ {9 a& S! u
1294546          TRANSLATOR           SPDLINKS                Translation of one mcm file created short/open circuits" |1 u' w. o" K% d0 S: S$ m
1292253          XTRACTIM           ENG                        Linux_XIM_13.0.2.04181 taking 1e6-cpusec_runtime
- r( r" C- B* _: d; A                        # R5 k$ p2 i, L) g8 X0 \
7 ?* Q/ z2 y4 W: f" ]: I
- K% D  `2 E0 t9 `  t. }; X! J3 {0 t# y- I; Y( ?
- h$ e2 I6 ]" D! N, X' s0 I* k2 G3 b
推荐
 楼主| 发表于 2015-8-2 22:31 | 只看该作者
chama 发表于 2015-7-30 23:45
0 N; f3 t2 p/ V, b' Spzt648485640,你好。你有ASI16.60.000吗?有的话能再发下百度云盘吗?
* {+ ?  v  ~- e  Y6 {, g官方还有;你可以注册个账户自己可以直接下载;如不行的话回帖;我帮你转运到度娘那里。。。, m: b$ C) B7 `4 K: h/ L& \0 y
推荐
发表于 2014-10-8 10:40 | 只看该作者
pzt648485640 发表于 2014-10-8 09:11
4 r: a! I. @7 C3 P8 q! r) i+ A占时不会提供破解版;毕竟我是从官方下载过来的。
! G9 W  P$ Z; j+ W- k+ L4 g
& R' G0 y" h0 K- Y2 z此论坛有破解的方法;请搜索下贴
' L* [( s8 d6 M9 f$ r0 [4 k谢谢  f, v$ _2 M- G# W$ p' v& h9 r6 V% V+ T
推荐
 楼主| 发表于 2014-10-8 09:11 | 只看该作者
rongzhai 发表于 2014-10-8 01:457 r1 r! ]- ?& W% V3 n
有破解吗?
' D! b  z8 `$ d1 C% L占时不会提供破解版;毕竟我是从官方下载过来的。2 P6 X  Y2 l: I# K4 @
, q; a* F) y: @+ o
此论坛有破解的方法;请搜索下贴
发表于 2014-9-26 08:56 | 只看该作者
这么快?可以用吗?
发表于 2014-9-30 16:01 | 只看该作者
好东西,感谢。
发表于 2014-12-22 08:26 | 只看该作者
好东西,谢谢分享!
发表于 2015-1-15 14:02 | 只看该作者
谢谢楼主无私的共享,非常谢谢!
发表于 2015-3-12 16:17 | 只看该作者
破解文件呢?
    郁闷
    2024-11-20 15:04
  • 签到天数: 3 天
    [LV.2]偶尔看看I
    13#
    发表于 2015-7-30 23:45 | 只看该作者
    官方还有;你可以注册个账户自己可以直接下载;如不行的话回帖;我帮你转运到度娘那里。。。  详情 回复 发表于 2015-8-2 22:31
    郁闷
    2024-11-20 15:04
  • 签到天数: 3 天
    [LV.2]偶尔看看I
    15#
    发表于 2015-8-3 09:30 | 只看该作者
    谢谢。我试下看。
    GMT+8, 2025-7-20 15:07 , Processed in 0.156250 second(s), 27 queries , Gzip On.
