楼主: lixing865
一些画的很好的PADS参考PCB
106#
发表于 2008-2-22 10:21 | 只看该作者
确实很好
107#
发表于 2008-2-23 13:49 | 只看该作者
看看
头像被屏蔽
108#
发表于 2008-2-23 14:35 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
头像被屏蔽
109#
发表于 2008-2-23 14:37 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
    2019-11-18 15:02
    110#
    发表于 2008-2-23 16:57 | 只看该作者
    111#
    发表于 2008-2-23 18:22 | 只看该作者
    asdddd
    aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    112#
    发表于 2008-2-24 12:01 | 只看该作者
    找了好久, 谢谢!!
    113#
    发表于 2008-2-24 16:26 | 只看该作者
    哈东西?
    114#
    发表于 2008-2-25 15:52 | 只看该作者
    学习一下.谢谢!
    115#
    发表于 2008-2-25 16:21 | 只看该作者
    怎么个好法?
    116#
    发表于 2008-2-28 16:59 | 只看该作者
    很期待。。
    117#
    发表于 2008-2-28 23:17 | 只看该作者
    *** CuteFTP 7.0 - build Jun 7 2005 ***
      m" F( x+ ~8 X* w. m4 \# i7 J  W6 H
    STATUS:>          Getting listing ""...
    + w. I: ]; Z6 Y( u1 Y' Y; sSTATUS:>          Resolving host name ftp.pcbtech.net.... }# ]6 W6 Q  h
    STATUS:>          Host name ftp.pcbtech.net resolved: ip = 221.130.202.73.
    ' n+ r: [$ z: S+ YSTATUS:>          Connecting to FTP server ftp.pcbtech.net:2006 (ip = 221.130.202.73)...
    8 R6 v( G. D9 r! bERROR:>           The connection failed due to an error or timeout.( F0 f$ E; W7 s
                    1) Verify that the destination IP address is correct.
    % d3 g  z% K; U0 x7 q9 j. c" O                2) Increase the connection timeout threshold under Global Settings | Connection.
    7 E: V; [8 e8 K* X2 p                3) Switch to the opposite data connection type (PASV or PORT) under Site Settings | Type tab.
    & B* b# x4 s$ B8 N2 s                4) Verify that the problem is not local by trying to connect to an alternate server.
    & g+ v/ T8 K0 h' G. c; s4 _                5) If a server name was used, verify it resolves to the correct address.8 m+ z& f: C$ J2 f) c
                    6) If using a local server table for server name resolution, check to see that it doesn't resolve to an obsolete address.6 L- h7 U. T. J1 J8 m2 h
                    7) Try pinging the address.
    + O! b+ e# f, m, R                8) If you are using a router, verify the router is up and running (check by pinging it and then ping an address outside of the router).
    # b6 y8 v% n6 `* e                9) Do a traceroute to the destination to verify all routers along the connection path are operational.
    $ o) i& e& P/ U, d                10) Verify that your subnet mask is setup properly.
    & _5 h" C' S" j* H. L, S                11) Verify that your local software or hardware firewall is not blocking outbound connections originating from CuteFTP.) @% m4 i5 \9 G
                    12) Verify that your anti-virus software is not at fault (try disabling it).
    118#
    发表于 2008-2-28 23:30 | 只看该作者
    dfvdsfsdf
    119#
    发表于 2008-2-29 08:14 | 只看该作者
    学习学习!
    120#
    发表于 2008-2-29 17:16 | 只看该作者
    学习下
    GMT+8, 2025-10-10 15:55 , Processed in 0.140625 second(s), 20 queries , Gzip On.
