TA的每日心情 | 开心 2025-7-30 15:24 |
签到天数: 4 天 [LV.2]偶尔看看I
- k9 P) U8 k: R& R& oSPB16.60.033, Version: SPB:Hotfix:16.60.033~wint
0 D5 J. ~. a2 L0 O还没时间下!
; u$ k' W+ t# e* [( q; @/ ]
8 T) A4 e8 Y& H% R' d g; N$ D6 d) ^5 t1 h' { f2 w& e4 m
DATE: 08-7-2014 HOTFIX VERSION: 033
2 u6 M$ m! M9 C* R" ^1 ]===================================================================================================================================# y5 n& p }0 j
CCRID PRODUCT PRODUCTLEVEL2 TITLE2 N0 a: u# {# A7 h* N2 @
===================================================================================================================================: |! C3 C, L% t1 `+ g
1265152 CONSTRAINT_MGR OTHER In CM, for a new worksheet, the Actuals are not seen for Class-Class Objects.
( f7 Q/ a9 s: O2 M2 B# R4 |1269155 CONSTRAINT_MGR INTERACTIV Constraint manager does not evaluate the formulas if the min value is more than the max value( ^* ^- e" F& E- Y3 d
1279589 APD NC Duplicated Drills' Y! u" G( O5 Z$ t
1280288 CONSTRAINT_MGR OTHER The option "rename existing refdes" is hidden while doing File>import>logic* z0 K, ?# x- j8 K- y
1285122 CONSTRAINT_MGR UI_FORMS Analysis Settings does not appear in constraint Manager Sigrity SI- N- b- `/ W: Q* k& M
1291054 concept_HDL ARCHIVER archiver fails to create the cds.lib & cpm files when the -views switch is used in the command line
6 ^, G6 [- S: k) m1291186 SIP_LAYOUT DXF_IF Export DXF is incorrectly exporting the top layer pins when they aren?t specified in the output.
( t$ D+ m4 ~( e) @) d m1292595 CONSTRAINT_MGR SCHEM_FTB Revision number reset in dcf when running Import Physical
" N+ h7 y4 w, g& u- H% H1293346 allegro_EDITOR GRAPHICS smd symbols with Step model not correctly shown in 3D Viewer
/ s8 B v$ `) q, n7 \1 f) B/ ]1293579 ADW PCBCACHE ERROR(SPCOCD-553): Connectivity Server Error: Failed to load component cell 'ti_template.ets600_pogp_143p:sym_1'1 T: v' g _" I- |
1293733 SIG_EXPLORER EXTRACTTOP SigXP extraction: Bad memory usage in logicalop Head! message is output on Linux1 q+ J& ^/ h$ X0 E8 ?3 X
1293911 ALLEGRO_EDITOR EDIT_ETCH Using AiPT on this design causes an unrelated via to be deleted
/ |- F. F: I5 e, {2 n/ |) |1296433 CONCEPT_HDL CORE DEHDL crashes when saving hierarchy1 w& i! M: U& m
1296735 ALLEGRO_EDITOR NC Customer want to know why we change the description in SPB166, it causes CAM350 can`t import drill file.
: z* O, \' L# \5 Y1296743 APD DEGASSING Degassing creates wrong voids for second and subsequent shapes when multiple shapes are selected% {; f' S/ l1 E- V0 b
1296803 ALLEGRO_EDITOR OTHER Can no longer access some drawing subclasses in 16.6
2 a6 m \( i- m, m0 {8 a1 E+ p1298421 ADW LRM Artesyn: LRM cannot update the part.
/ v& Z1 \. D7 z* b1299871 APD WIREBOND The axlSetAllProfilesVisible return all "nill"
% x7 H2 K0 u# Z4 c1 ]9 U/ c9 s1300186 ALLEGRO_EDITOR DATABASE Deleted NetGroups in DEHDL appear in the Allegro PCB CM" |# a" C% \* V5 M, m
1300961 CONSTRAINT_MGR CONCEPT_HDL cmdfeedback.exe crashes during import physical' {' }' A: Y Q4 V9 B: ]- A
1301180 ALLEGRO_EDITOR GRAPHICS 3D Viewer for SMD footprint shows top pads on bottom layer and place bound wrongly |
