查看: 2197|回复: 5
ALLEGRO 出 NC ROUTE 时有这些WARNING
发表于 2014-8-6 10:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
哪位大仙给看下这是什么问题?
! }/ s% T6 W$ i# w! ~0 S
) k4 A. Z% w% O7 u, }(------------------------------------------------------------)
7 R# _0 t* F) M# ~6 I (                                                            )9 A, w  H! x2 \1 `8 L; `$ L: V
(                    NC ROUTE LOG FILE                       )
) A# p+ U! B/ E( } (                                                            )) i' k7 l7 P+ a! W5 }5 d8 I
(        Drawing    : 20140803mm.brd                         )
$ y" g+ M# c2 M (        Date/Time  : Mon Aug 04 13:57:22 2014               )
( i" @9 Z6 W6 Y; o (                                                            )
+ e: m9 x5 a$ S, K" z  q (------------------------------------------------------------)  z' Z( w  @4 x' v" D6 G
( D2 O, Q8 M$ e  f+ `+ V- x
1 D+ m' u; B! z# q6 @& z
' z$ P) k+ m7 O3 p+ B% d
Processing NC Parameters file ...$ {- E" Q& E4 p5 j! g+ Z8 N5 W
5 s: V! a8 R' C- q; G4 Z5 D7 ?; zNC PARAMETERS; b- V& `: B" _& v
2 h# [8 O& |+ b- [  g - t0 l+ k) G% u, p
FORMAT                   3.5
4 b* V7 H" m* R8 d& x3 p' w MACHINE-OFFSET                x:0.000000        y:0.000000
1 [- b0 t7 G: P, _' _( ^3 G6 `# Q2 y FEEDRATE                17 x: j3 f5 a9 _- T5 f; e
COORDINATES                ABSOLUTE
! s' C  ~) d. T+ S, G OUTPUT-UNITS                ENGLISH2 A' K' a* x: L( W5 ?
TOOL-ORDER                INCREASING. @  N& j/ U" O; ]9 `
REPEAT-CODES                YES9 Y  t9 g/ B7 W4 \3 j0 r- R5 t4 ]
SUPPRESS-LEAD-ZEROES        NO
* H  X" A8 T7 ?+ H$ C* ] SUPPRESS-TRAIL-ZEROES        NO
4 o  T- T# ^( ~# T SUPPRESS-EQUAL                NO
( b5 d( W( P; E! c# ~: j TOOL-SELECT                NO! L7 c! A8 L, \# j, |
HEADER                        none
/ Z  @; C( P# W9 B8 @0 D LEADER                        12' K5 T9 E: w( Z5 ^. V5 O0 o) K6 r: b
CODE                        ASCII# k5 ]0 h, W9 R( O6 ~
SEPARATE                NO
* g& l, X/ u; n/ m OPTIMIZE_DRILLING        NO
' a; r/ t7 A$ |7 ], q0 z; w; @9 T8 u ENHANCED_EXCELLON        NO1 o' b' j; W. C9 x! h6 B: I4 `
SCALE                        1.000000
3 X* L) v% Z7 k
5 \# F1 U. s# l" `-------------------------------------------------------------' }7 G' ^+ ^$ s) I2 \. ]7 R" I
7 g; ^( ]! M$ J- n+ F  kProcessing route path data ...
2 ]+ G5 s" m4 _+ g  n& G4 O$ c
" @7 q# ]! \( E$ wWARNING: No route path data was found for processing.  g6 w  ]. Q% O2 Y
* L$ n  t9 I' N' M1 o: C. i; {* d8 L-------------------------------------------------------------
4 K% Y8 b7 J; y7 w % }1 \; `% V8 D) s$ x! N5 F6 I
Processing slot hole data ..." H8 _; O- X/ D& j2 Z6 y$ a
  T# [* Q) D# OWARNING: Can't find NC Route bit file (ncroutebits.txt)!
: L2 ?# b3 H) y" J; E, u9 a; O( I           Using T01 to route ALL route cuts.
9 O+ t( `  \, s
, Q! U9 h) [4 {WARNING: No slot holes were found for processing!
( \% @$ A3 v3 @6 f- D0 `5 B . n0 c5 f4 t5 T+ X4 L
-------------------------------------------------------------% Z7 O; ^4 R7 w
, S9 Y7 |8 w0 s( w2 p' T( B
NC Route file 20140803mm.rou created ... Program completed.
发表于 2014-8-6 10:40 | 只看该作者
你最好是发截图。。。。。
 楼主| 发表于 2014-8-6 10:52 | 只看该作者
bin6405404 发表于 2014-8-6 10:40" G5 q& E, H. u0 t  T- P7 D+ _
你最好是发截图。。。。。
4 D( F/ ^, P$ a# z& T  _0 G  G( `
就是个TXT档,里面内容就是这些,都COPY过来了。
发表于 2014-8-6 11:27 | 只看该作者
这个是不是孔做的有问题还是什么原因我也不怎么知道。你可以用谷歌翻译一下
    2020-7-21 15:38
  • 签到天数: 21 天
    [LV.4]偶尔看看III
    发表于 2014-8-6 13:06 | 只看该作者
    意思就是你板子上根本没route的孔,你这个不是自动弹出的报警吧?没有必须就别出route了
     楼主| 发表于 2014-8-6 14:41 | 只看该作者
    kinglangji 发表于 2014-8-6 13:06
      ^1 W- F& A, e3 R  Q  B% q意思就是你板子上根本没route的孔,你这个不是自动弹出的报警吧?没有必须就别出route了
    ( [! F! G9 [% e2 }" e$ Z
    是的,明白了,谢谢!
    GMT+8, 2025-7-26 20:03 , Processed in 0.125000 second(s), 23 queries , Gzip On.
