1. 3d_viewer
2. about
3. acroread
4. active subclass
5. add arc
6. add circle
7. add connect
8. add fillet
9. add frect
10. add fshape
11. add line
12. add rarc
13. add rect
14. add taper
15. add text
16. add vertex
17. add xshape
18. add_bviaarray
19. add_viaarray
20. aicc
21. aidt
22. alias
23. alias_protect
24. align components
25. align modules
26. altsubclass
27. angle
28. annotation in
29. annotation out
30. aperture
31. apick
32. apick_to_grid
33. artwork
34. assign color
35. assign refdes
36. assign region
37. auto define bbvia
38. auto_route
39. autobundle
40. axlmark
41. back
42. backdrill setup
43. backingstore
44. batch
45. bit ordering
46. blank waived drcs
47. bmpflush
48. bmscheck
49. board keepout
50. board outline
51. board plane
52. bond wire length
53. bond wire location
54. bundle blank
55. bundle blank_all
56. bundle blank_unselected
57. bundle create
58. bundle delete
59. bundle edit
60. bundle import
61. bundle properties
62. bundle restore
63. bundle show
64. bundle show_all
65. bundle show_unplanned
66. bundle split
67. bundle toggle
68. button
69. cancel
70. capture_search
71. change
72. change circle
73. change class
74. change font
75. change font
76. change layer
77. change radius
78. change shape size
79. change width
80. chg origin
81. class
82. clear color
83. clpcopy
84. clppaste
85. cmgr
86. cmgr_elec
87. cmgr_phys
88. cmgr_snspac
89. cmgr_spac
90. cmgr_xprobe
91. cns cmmodes
92. cns design
93. cns electrical
94. cns onlinedrc
95. cns show
96. cns_dummy_net
97. color
98. color_dummy_net
99. color192
100. colorview create
101. colorview load
102. colorview restore
103. comp
104. complete
105. compose shape
106. confirm
107. copy
108. copy fanout
109. cputime
110. create coupons
111. create detail
112. create fanout
113. create module
114. create nets
115. create plot
116. create plotunix
117. ctab
118. custom datatips
119. custom smooth
120. custom_route
121. cut marks
122. datatips toggle
123. db diary
124. dbdoctor
125. dbdump
126. dbgroup
127. dbl_pick
128. decompose shape
129. define bbvia
130. define embedded layer
131. define grid
132. define layersets
133. dfine list
134. define lyrstack
135. define materials
136. define property
137. define subclass
138. define text
139. define via structure
140. define xsection
141. dehilight
142. dehilight sym net
143. del_viaarray
144. delay tune
145. delete
146. delete fillet
147. delete taper
148. delete vertex
149. delete_via_structure
150. derive connectivity
151. derive connectivity all
152. derive connectivity figures
153. derive connectivity lines
154. derive connectivity pins
155. design compare
156. devsym
157. devtype
158. dfa
159. dfa_run
160. dfa_spreadsheet
161. diff Pairs
162. dimension edit
163. disband group
164. dlib
165. done
166. downrev
167. downrev2
168. draft chamfer
169. draft fillet
170. drag_start
171. drag_stop
172. drawing select
173. drc update
174. drc window
175. drcupdate
176. dxf in
177. dxf out
178. dynetch
179. echo
180. ecl param
181. ecl terminator
182. editpad boundary
183. editpad restore
184. editpad restore all
185. elong_by_pick
186. embed prop
187. EMC audit
188. emc auditrep
189. emc autoprop
190. emc execrep
191. emc execute
192. emc init
193. emc manprop
194. emc results
195. emc rulesel
196. emcontrol
197. enved
198. esc
199. etch length
200. etchedit
201. excellon processing
202. exit
203. extract_ui
204. fabmaster out
205. fanout_by_pick
206. feedback
207. file_property
208. file_register
209. file_unregister
210. filemgr
211. film area
212. film param
213. find_by_name
214. find_control
215. findfilter
216. findprop
217. fix
218. flipdesign
219. flow copy
220. flow default
221. flow move
222. flow slide
223. flow vertex
224. flow vertex delete
225. flow vertex insert
226. flow vertex move
227. flow via delete
228. flow via insert
229. flow via move
230. form
231. form_next
232. form_prev
233. front
234. func
235. funckey
236. generaledit
237. gerber processing
238. gloss area design
239. gloss area highlight
240. gloss area list
241. gloss area room
242. gloss area window
243. gloss execute
244. gloss param
245. grid toggle
246. group
247. group add
248. groupedit
249. help
250. helpcmd
251. highlight sov
252. hilight
253. hilight sym net
254. history
255. http
256. iangle
257. iapick
258. iapick_to_grid
259. iapick_to_gridunit
260. icm_out
261. identify nets
262. idf in
263. idf out
264. idx in
265. idx out
266. iff in
267. ifnvar
268. ifp
269. ifvar
270. image restore last
271. image restore userdefined
272. image restore v1
273. image restore v2
274. image restore v3
275. image restore v4
276. images
277. imouse_pos
278. import mentor
279. import mentor
280. inteRFace_vis
281. ipc2581 compare
282. ipc2581 in
283. ipc2581 out
284. ipc356 out
285. ipick
286. ipick_to_grid
287. ipick_to_gridunit
288. island_delete
289. journal
290. keepin package
291. keepin photo
292. keepin router
293. keepout gloss
294. keepout package
295. keepout probe
296. keepout router
297. keepout shape
298. keepout via
299. keepout wire
300. layer priority
301. layout wizard
302. license_use
303. line fattening
304. linefont
305. list
306. load gerber
307. load photoplot
308. load plot
309. load stream
310. mail
311. mark fanout
312. mirror
313. miter_by_pick
314. mod padstack
315. modpaste
316. mosaic_cmd
317. mouse_pos
318. move
319. movewindow
320. multpadedit
321. nc drill report
322. ncdrill customization
323. ncdrill legend
324. ncdrill param
325. ncroute
326. nctape_full
327. net
328. net lgic
329. net schedule
330. net_properties
331. netin
332. netout
333. new
334. next
335. noappmode
336. nographic
337. odb_out
338. old_reports
339. oops
340. open
341. opencd
342. opengl report
343. optimize_ts
344. options
345. orcad in
346. osdelete
347. package_height
348. padeditcur
349. padeditdb
350. padeditlib
351. pads in
352. param in
353. param out
354. partedit
355. partlogic
356. pause
357. pcad in
358. pdf out
359. phase_tune
360. pick
361. pick_origin
362. pick_to_grid
363. pin_delay in
364. pin_delay out
365. pipe
366. place area design
367. place area list
368. place area room
369. place area window
370. place auto bottomgrid
371. place auto topgrid
372. place execute
373. place insight
374. place interactive
375. place manual
376. place param
377. place replicate apply
378. place replicate create
379. place replicate update
380. place set bottomgrid
381. place set topgrid
382. placementedit
383. plc chglyr
384. plctxt in
385. plctxt out
386. plot
387. plot preview
388. plot setup
389. plotwint
390. polar
391. pop add
392. pop addrect
393. pop align
394. pop alt module
395. pop alt symbol
396. pop apply
397. pop arc
398. pop autovoid
399. pop bbdrill
400. pop change layer
401. pop controltrace
402. pop cut
403. pop datum
404. pop delete vertex
405. pop delete_all_voids
406. pop dimension value
407. pop drill
408. pop dyn_option_select
409. pop enhanced pad entry
410. pop finish
411. pop fix
412. pop flip
413. pop idx accept
414. pop idx reject
415. pop in
416. pop jinput
417. pop lasso
418. pop mirror
419. pop mirror geometry
420. pop move
421. pop neck
422. pop net list
423. pop net name
424. pop new target
425. pop out
426. pop path
427. pop pickgroup
428. pop poly
429. pop prmed
430. pop properties
431. pop readfile
432. pop refdes list
433. pop refdes name
434. pop region list
435. pop route_from_target
436. pop routespace
437. pop scale
438. pop shape change type
439. pop shape copy
440. pop shape copy layers
441. pop shape defer dyn fill
442. pop shape delete vertex
443. pop shape edit boundary
444. pop shape move
445. pop shape param
446. pop shape raise priority
447. pop shape report
448. pop shape select
449. pop shape update
450. pop show
451. pop singletrace
452. pop skip
453. pop swap
454. pop unfix
455. pop unfixall
456. pop viapattern
457. pop window
458. prepopup
459. print
460. printform
461. prmed
462. prompt
463. property edit
464. pwd
465. quickplace
466. quit
467. ratbundle
468. rats all
469. rats blank
470. rats bundled blank_all
471. rats bundled show_all
472. rats component
473. rats end_inview
474. rats net
475. rats show
476. rats show unplanned
477. rats show_all unplanned
478. rats toggle
479. rats unbundled show_all
480. ratsnest
481. readme
482. readonly
483. record
484. recordmacro
485. redisplay
486. redo
487. redraw
488. refdes
489. refresh padstack
490. refresh symbol
491. refresh syminst
492. reject
493. rename
494. rename area design
495. rename area list
496. rename area room
497. rename area window
498. rename execute
499. rename param
500. rep padstack
501. repeat_again
502. replace padstack
503. replace temp_devices
504. replace temp_symbols
505. replay
506. reports
507. reset dockwindows
508. resize_respace_dp
509. resizewindow
510. restore waived drc
511. restore waived drcs
512. return
513. rfedit_appm
514. ripup etch
515. roam
516. room outline
517. rotate
518. route_by_pick
519. rplan blank
520. rplan blank_all
521. rplan bundled blank
522. rplan bundled blank_all
523. rplan bundled show
524. rplan bundled show_all
525. rplan bundled toggle
526. rplan commit
527. rplan convert
528. rplan delete
529. rplan optimize
530. rplan plan
531. rplan plan accurate
532. rplan plan spatial
533. rplan plan topological
534. rplan progress
535. rplan show
536. rplan show_all
537. rplan status
538. rplan toggle
539. rplan unbundled blank_all
540. rplan unbundled show_all
541. rplan unbundled toggle
542. run
543. save
544. save_as
545. script
546. scriptmode
547. sctab
548. set
549. settoggle
550. setwindow
551. shadow
552. shadow toggle
553. shape
554. shape change type
555. shape defer fill
556. shape global param
557. shape merge shapes
558. shape param
559. shape vertex add
560. shapeupdate
561. shell
562. show allpanes
563. show element
564. show measure
565. show parasitic
566. show property
567. show rlc
568. show waived drcs
569. showhide find
570. whowhide options
571. showhide text
572. showhide view
573. showhide vis
574. si_properties
575. signal 3dmodel
576. signal atimes
577. signal audit
578. signal bus setup
579. signal bus sim
580. signal demiaudit
581. signal demiprefs
582. signal demiprobe
583. signal init
584. signal lib audit
585. signal library
586. signal model
587. signal model refresh
588. signal modeledit
589. signal prefs
590. signal probe
591. signal reprot
592. signal setup
593. signal snrscreen
594. signal stimulus
595. signal topology
596. signal waveform
597. signal xtalktable
598. signalintegrity
599. silkscreen audit
600. silkscreen execute
601. silkscreen param
602. skill
603. slide
604. smi_message_detail
605. sna param
606. snake
607. snap_rat_t
608. source
609. specctra
610. specctra checks
611. specctra_in
612. specctra_out
613. spin
614. split plane create
615. split plane param
616. spread between voids
617. sq_pitch_spread
618. stad
619. status
620. step pkg map
621. stop
622. stopwatch
623. stream out
624. strip_design
625. stroke editor
626. strokefile
627. subclass
628. swap area design
629. swap area list
630. swap area room
631. swap area window
632. swap components
633. swap execute
634. swap functions
635. swap modules
636. swap param
637. swap pins
638. symbol
639. symbol to spreadsheet
640. symbol_check
641. symtype
642. system
643. tab
644. techfile compare
645. techfile in
646. techfile out
647. testprep automatic
648. testprep createfixture
649. testprep density
650. testprep fix
651. testprep manual
652. testprep ncdrill
653. testprep prmed
654. testprep properties
655. testprep resequence
656. text
657. text edit
658. thermal_via
659. thieving
660. tline calculator
661. toggle
662. toolset
663. toolswap
664. topology template
665. trapsize
666. uiresources
667. unalias
668. unbutton
669. undo
670. unfix
671. unmark fanout
672. unmiter_by_pick
673. unplace component
674. unrats all
675. unrats component
676. unrats net
677. unset
678. unused pads
679. use altsym
680. variant assembly
681. variant bom
682. version
683. vertex
684. vi
685. viewlo
686. waive drc
687. world cancel
688. world done
689. world drawing2port
690. world find next
691. world find previous
692. world move
693. world oops
694. world resize
695. write
696. xcomp
697. xdbgroup
698. xdbgrouptype
699. xdehilite
700. xdevsym
701. xdrawing select
702. xfindprop
703. xfunc
704. xhilite
705. xname_flush
706. xnet
707. xratbundle
708. xrefdes
709. xsection
710. xsection_chart
711. xsymbol
712. xsymtype
713. xymode
714. zcopy shape
715. zcore
716. zoom all
717. zoom center
718. zoom fit
719. zoom in
720. zoom out
721. zoom points
722. zoom previous
723. zoom selection
724. zoom world
725. zrouter
这么多命令,大部分不知道是什么作用效果,有那位高手愿意填一填,填一些主要的也可以.以上纯手工输入,难免有错,请大家原谅.
/1
GMT+8, 2025-10-26 02:38 , Processed in 0.171875 second(s), 21 queries , Gzip On.
