楼主: NIWO99
[Cadence Sigrity] 关于Allegro转PADS问题?
    2021-12-27 15:33
    16#
    发表于 2019-1-21 16:59 | 只看该作者
      L/ t& e2 \( m( H) @! w  C我也遇到同样的问题。我使用的是16.6和PADS VX.0。我的解决方法是把PCB名字里面的下划线和小数点去掉就可以了。下面是我的报错信息:( \, Y; r* J% [% v* |8 Q( X
    Command > skill load "dfl_main.il"
    + O5 K8 P  ^+ ^, g- t, gCommand > main out
    ' q9 L; P/ M, h1 N' \- NPlease wait...extracting and processing technology file! H, D5 b, _( y$ O
    Converting techfile...
    / k3 P2 I* O6 w+ C  ]3 q) kExecuting command C:/Users/Administrator/Desktop/L_P20 V1.1_MGC/Work\techconv.bat
    8 d8 D9 U. ]$ D5 rError: Techfile conversion failed!
    9 Y# I( ~) Y7 m5 q4 `Deleting Existing Classes File; D. _6 z! W  v& h  Y  X" A1 o$ h+ N
    Deleting Existing Props File
    1 k! f( |$ _$ v; rDeleting Existing Board Items File
    ) S- u' F7 R3 {6 X  DExporting Electrical Constraints...& b6 z8 l# r; ^  V/ {/ P5 q
    extracting device files1 J, ]6 @; e/ w+ L" l
    Error: create_devices command failed!
    2 m( }$ r3 `( J9 Yextracting Net Properties
    1 H5 U* _% l/ c; q: L4 ]Loading axlcore.cxt
    / Q6 p6 k( O3 rE- Cannot open script file; 'C:/Users/Administrator/Desktop/L_P20.scr' does not exist.
    6 _* O$ u+ u( ?; y$ N  h! QE- *Error* get/getq: first arg must be either symbol, list, defstruct or user type - 0
    2020-9-8 15:07
    17#
    发表于 2019-3-27 17:38 | 只看该作者
    我也遇到同样的问题,提示如下:! M; ]: s, A  k" H9 h
    ERROR: Techfile conversion failed!
    7 e, |& R, h2 J2 _) OWARNING:Net(s) have MIN_NECK_WIDTH property set, value will be ignored!0 m. o3 F. O- I5 ?; b& Z2 @
    WARNING: layer BOTTOM not found in layer table.  Check the Allegro cross-section!  P) f9 w9 R: G: n  v
    WARNING: layer TOP not found in layer table.  Check the Allegro cross-section!) `! d- M4 ~  p7 B
    WARNING:  No route border found, bounding box used!  E) l( B5 B# g
    ERROR: no data issued for clearance DEFAULT
    0 ?+ M3 X7 Z, J3 kWARNING: layer SOLDERMASK_TOP not found in layer table.  Check the Allegro cross-section!) @# {, b3 J6 A+ s* y
    WARNING: layer SOLDERMASK_BOTTOM not found in layer table.  Check the Allegro cross-section!
    1 f- f, @. {  [WARNING: layer PASTEMASK_TOP not found in layer table.  Check the Allegro cross-section!
    * p. i1 X$ N  E% W9 E9 B4 ]7 F' SWARNING: layer PASTEMASK_BOTTOM not found in layer table.  Check the Allegro cross-section!" S5 U, y" a! D6 G6 O, w
    WARNING: layer FILMMASKTOP not found in layer table.  Check the Allegro cross-section!2 K% q  {6 @6 h# U& `( e# ^. {; q! W) M
    WARNING: layer FILMMASKBOTTOM not found in layer table.  Check the Allegro cross-section!
    6 O/ w3 L& x5 DERROR: Unable to issue shapes for padstack SMD-RCT-0_81X0_96 - layer problems" k0 ?8 o2 W2 Z
    ERROR: Unable to issue shapes for padstack SMD-RCT-1_2X1_625 - layer problems
    * K/ s3 ^4 k! e, e  ?8 y4 OERROR: Unable to issue shapes for padstack SMD-SQU-0_8 - layer problems7 k3 ~7 E& A9 x) L# V) H( l
    ERROR: Unable to issue shapes for padstack SMD-RCT-0_8X1 - layer problems
    $ K0 P0 R+ \# J5 sERROR: Unable to issue shapes for padstack SMD-RCT-0_5X1_11 - layer problems
    % J7 G( s; U7 G) ^5 d9 P8 ^) xERROR: Unable to issue shapes for padstack SMD-RCT-0_8X1_11 - layer problems
    . J2 T" i5 L# V8 V1 t% H) @6 x' v8 vERROR: Unable to issue shapes for padstack SMD-RCT-0_32X1_8 - layer problems
    + \! G# z! Q4 K& L8 e: e+ KERROR: Unable to issue shapes for padstack PAD-C-0_5 - layer problems; i% G1 G  o/ a! [
    ERROR: Unable to issue shapes for padstack SMD-RCT-1_016X1_27 - layer problems# m) @4 m, }! j
    ERROR: Unable to issue shapes for padstack SMD-SQ1_016 - layer problems& B0 j- f# T- b/ l9 T, V5 _5 C7 k+ ]
    ERROR: Unable to issue shapes for padstack SMD-RCT-0_812X0_965 - layer problems/ B! a: k9 B% W$ o# A
    ERROR: Unable to issue shapes for padstack SMD-RCT-1_8X1_1 - layer problems% h3 p: K. Q+ L0 P
    ERROR: Unable to issue shapes for padstack PAD-C-1_32 - layer problems
    6 w4 u% }# O$ dERROR: Unable to issue shapes for padstack SMD-RCT-2_2X0_7 - layer problems3 H3 W5 q! L) a( r
    ERROR: Unable to issue shapes for padstack SMD-RCT-0_7X2_2 - layer problems
    ( a1 _& ?, l5 n, y# A& W1 A( p7 BERROR: Unable to issue shapes for padstack PAD-C-1_0P3_0S - layer problems4 ?) r0 ]9 H( k9 Q% |
    ERROR: Unable to issue shapes for padstack SMD_RCT_0-5X0-55 - layer problems% q  R2 U. J0 b, j* A- a+ c
    ERROR: Unable to issue shapes for padstack SMD-RCT-0_5X0_55 - layer problems1 p+ i; n% V+ q+ ^. \# ~  \+ b
    ERROR: Unable to issue shapes for padstack PAD-C-0_8NPT_mtg - layer problems0 D6 t% \( g: q1 Q( ?
    ERROR: Unable to issue shapes for padstack PAD-C1_2NPT - layer problems
    ( O2 q$ G3 s' k3 W/ KERROR: Unable to issue shapes for padstack PAD-C2_3P4UP - layer problems9 Q+ }$ s  i8 R( {2 l' ~
    ERROR: Unable to issue shapes for padstack VIA12H22_via - layer problems
    ; a* L5 F* Y7 U; q4 p  oERROR: Unable to issue shapes for padstack VIA16H26_via - layer problems
    7 r; w0 @5 O3 f3 ]3 M5 k7 DERROR: Unable to issue shapes for padstack PAD-OB1_4X4_2 - layer problems
    % ~% j* I( z) i7 n) h1 J4 TERROR: Unable to issue shapes for padstack VIA12H22_via - layer problems( x# r$ v% l* i
    ERROR: Unable to issue shapes for padstack VIA16H26_via - layer problems, d- ^3 g' e0 p; {5 a% g9 k7 z
    WARNING: layer internal_pad_def not found in layer table.  Check the Allegro cross-section!0 ^' c/ g: m, Z/ i
    WARNING: layer ~TSM not found in layer table.  Check the Allegro cross-section!
    ) Z: J, g6 Y1 C% d5 d  m! @7 {1 q- fWARNING: layer ~BSM not found in layer table.  Check the Allegro cross-section!
    # y3 G5 X7 Z4 j6 A; dWARNING: layer ~TPM not found in layer table.  Check the Allegro cross-section!$ M2 x7 I6 p& k) f! ]& R
    WARNING: layer ~BPM not found in layer table.  Check the Allegro cross-section!
    / G; U9 `+ ^! L! q" p1 W- EWARNING: layer ~TFM not found in layer table.  Check the Allegro cross-section!9 r& M, Z0 K: f5 R) `8 v9 b
    WARNING: layer ~BFM not found in layer table.  Check the Allegro cross-section!
    ' C7 ^, B8 x3 Y1 f8 `3 l有没有人知道怎么解决的,感谢!!
    2020-9-8 15:07
    18#
    发表于 2019-3-27 17:39 | 只看该作者
    dzkcool 发表于 2015-3-9 17:36. f# D$ d6 U6 ~
    如果把板子上的东西按照转换程序的要求做好的话,转起来还是很快的。
    ! ?1 l& J, W+ W" k" B* b3 u版主,请问转换程序的要求是要做成什么样的,能否提醒一下,我也遇到同样的问题了,感谢
    * @5 K' Y5 O% _$ I6 E
    2024-2-21 15:59
  • 签到天数: 313 天
    [LV.8]以坛为家I
    19#
    发表于 2019-3-28 07:58 | 只看该作者
    奋斗
    2024-12-19 15:16
  • 签到天数: 94 天
    [LV.6]常住居民II
    20#
    发表于 2020-3-9 15:51 | 只看该作者
    本帖最后由 yahoboy 于 2020-3-9 15:52 编辑 ; X; l  J! E4 W* |/ p
    7 I9 G  s0 v: u
    ERROR: Techfile conversion failed!- ^, ]: v9 o$ }6 b: k
    & [) {3 J8 X7 J& r, I( f2 d8 MWARNING: layer BOTTOM not found in layer table.  Check the Allegro cross-section!8 {/ Y+ \# N. o+ i9 Q1 a9 q4 r
    ERROR: no data issued for clearance DEFAULT8 T2 E" `  O& M8 m6 i1 }$ D& K
    WARNING: layer SOLDERMASK_TOP not found in layer table.  Check the Allegro cross-section!  @3 G. ]1 m" g5 t. n
    7 [3 h3 Q7 p; m9 L/ g( r9 ]* sWARNING: layer PASTEMASK_TOP not found in layer table.  Check the Allegro cross-section!
    ( N) S) V9 V, S6 r( mWARNING: layer PASTEMASK_BOTTOM not found in layer table.  Check the Allegro cross-section!
    3 Z$ O( G; N" ?5 [  B9 x2 hWARNING: layer FILMMASKTOP not found in layer table.  Check the Allegro cross-section!
    6 f" i. E8 C* |4 z# v% a& r) vWARNING: layer FILMMASKBOTTOM not found in layer table.  Check the Allegro cross-section!
    % l. U$ @' u6 Q7 yERROR: Unable to issue shapes for padstack PAD3 - layer problems
    8 {0 F: |1 h- S6 S) FERROR: Unable to issue shapes for padstack PAD1 - layer problems9 ^# R, i/ M! Z* ~4 U
    ERROR: Unable to issue shapes for padstack PAD2 - layer problems- {" k6 q5 W' |5 R7 }
    ERROR: Unable to issue shapes for padstack PAD4 - layer problems
    8 a0 q5 X3 i+ @& ]ERROR: Unable to issue shapes for padstack PAD5 - layer problems
    ( B4 b5 R& Z7 P( y# B; fERROR: Unable to issue shapes for padstack PAD7 - layer problems
    $ m0 X! u- m. j7 OERROR: Unable to issue shapes for padstack PAD6 - layer problems
    ) G1 m; f, T! k: _) d% [- KERROR: Unable to issue shapes for padstack PAD8 - layer problems% |. N: V, X* M1 r8 `. k
    ERROR: Unable to issue shapes for padstack V16X8_via - layer problems
    - M3 s3 M# C$ ^2 H7 h4 }7 f# k$ JERROR: Unable to issue shapes for padstack V15X8_via - layer problems
    , Z2 H' D1 s4 h1 |) pERROR: Unable to issue shapes for padstack S_R3R50X3R00 - layer problems
    6 L+ i' A  o. ]ERROR: Unable to issue shapes for padstack S_S1R00 - layer problems
    1 @/ [0 y$ F; w! E% V! iERROR: Unable to issue shapes for padstack S_R0R95X1R30 - layer problems6 Q  M: }  ?6 }# w
    ERROR: Unable to issue shapes for padstack S_R1R40X1R60 - layer problems& _- I" l% O% q* T
    ERROR: Unable to issue shapes for padstack S_R1R80X2R00 - layer problems
    5 J" ^7 D  m4 pERROR: Unable to issue shapes for padstack SHAPEESD0402_R - layer problems4 g5 s2 q" u! q, ?% i% S
    ERROR: Unable to issue shapes for padstack SHAPEESD0402_L - layer problems. ~# T  @' l7 d% i7 a8 @
    ERROR: Unable to issue shapes for padstack S_R0R965X0R80 - layer problems
    & G, `& \8 {: k$ s6 @( I2 ~' YERROR: Unable to issue shapes for padstack P_O2R00X0R60_O3R50X1R50 - layer problems3 a8 r) O: {" [# ^$ Q: i, T0 f9 h9 W! J
    ERROR: Unable to issue shapes for padstack P_C2R20_C2R20_NP - layer problems; {$ g; Y9 T; A4 f
    ERROR: Unable to issue shapes for padstack P_O2R00X0R80_3R50X1R80 - layer problems2 K+ E* `; C+ X5 q0 G
    ERROR: Unable to issue shapes for padstack P_O1R10X0R45_O2R10X1R45 - layer problems
    & {( u  [$ y$ ^8 s) Z$ GERROR: Unable to issue shapes for padstack P_C0R65_O1R40X1R25 - layer problems
    ' ?( l0 Y* l( o* b; CERROR: Unable to issue shapes for padstack S_R1R40X0R40 - layer problems
    & F6 w" s0 Y' z7 C7 b" ]. r" |7 F% TERROR: Unable to issue shapes for padstack P_C0R80_C0R80_NP - layer problems
    , \" h. q+ B2 ^: ^" z' L0 e% x5 }ERROR: Unable to issue shapes for padstack S_R1R50X4R00 - layer problems( ]" @) _0 z6 _9 }4 x
    ERROR: Unable to issue shapes for padstack S_R3R40X1R30 - layer problems
    * `" m1 N  W* d5 }ERROR: Unable to issue shapes for padstack S_R0R70X2R00 - layer problems
    4 m' i" }% v. k2 |ERROR: Unable to issue shapes for padstack S_R1R00X1R20 - layer problems9 v$ ~( ]4 y" t" y& K: ]
    ERROR: Unable to issue shapes for padstack MARK_C1R00_C2R30NP - layer problems0 Q1 f+ w# N5 W
    ERROR: Unable to issue shapes for padstack S_R0R80X1R10 - layer problems4 M9 f2 {" i" v% p) s* s% [% y
    ERROR: Unable to issue shapes for padstack S_R0R65X0R80 - layer problems
    . ^7 y. o- M; _2 _7 Y* H& @* hERROR: Unable to issue shapes for padstack S_C0R70 - layer problems( s8 M$ _4 _, K0 s! R3 m" E
    ERROR: Unable to issue shapes for padstack S_C1R00 - layer problems' U1 Y- ^& U, F3 X
    ERROR: Unable to issue shapes for padstack S_R0R70X1R00 - layer problems
    / J$ J( U# d) t% a& T3 H5 oERROR: Unable to issue shapes for padstack S_O0R70X1R00 - layer problems, V' g# ^) k5 V
    ERROR: Unable to issue shapes for padstack S_R1R10X0R60 - layer problems
    5 ^, F6 t. Q; b& J( bERROR: Unable to issue shapes for padstack S_O1R10X0R60 - layer problems
    ; c" b7 g. p" H# D5 bERROR: Unable to issue shapes for padstack S_C0R38 - layer problems
    - i/ h% w$ E, Y  F1 }ERROR: Unable to issue shapes for padstack S_R0R30X1R80 - layer problems
    # g- d, C, m4 r# x8 _ERROR: Unable to issue shapes for padstack S_R1R40X1R20 - layer problems& Q1 u/ x' [2 b8 o0 t
    ERROR: Unable to issue shapes for padstack S_C0R35 - layer problems* i7 W: b# V% Z
    ERROR: Unable to issue shapes for padstack S_R0R80X0R90 - layer problems4 t, ?4 f2 v2 {4 l& m, }) I/ ]
    ERROR: Unable to issue shapes for padstack S_S0R55 - layer problems( \3 F3 k: i3 N- ]" C3 e: }
    ERROR: Unable to issue shapes for padstack S_S0R50 - layer problems
    ; G+ F! {4 t, M/ e; gERROR: Unable to issue shapes for padstack 0402_via - layer problems9 j4 O3 {6 Y2 y
    ERROR: Unable to issue shapes for padstack 0503_via - layer problems9 P7 ^2 J- d5 Q# ~/ A3 X+ c
    ERROR: Unable to issue shapes for padstack 03502 - layer problems% \5 K$ s- r* Q
    ERROR: Unable to issue shapes for padstack S_R0R80X2R90 - layer problems% n& D* `" L& P9 \
    ERROR: Unable to issue shapes for padstack P_C0R85_R1R45_P - layer problems! L9 A8 s. R! N
    ERROR: Unable to issue shapes for padstack P_C0R85_C1R45_P - layer problems0 z4 U8 R+ P+ e, c& p) d- R/ F" u
    ERROR: Unable to issue shapes for padstack S_R2R20X6R00 - layer problems. M7 r: B& f3 o2 G1 H  d. a( t
    ERROR: Unable to issue shapes for padstack S_R1R80X0R75 - layer problems
    * y  L( J0 ?& w5 A* n, |- _ERROR: Unable to issue shapes for padstack S_R1R70X1R00 - layer problems2 K+ ~  J/ G) H# e2 Y1 T, M
    ERROR: Unable to issue shapes for padstack S_R0R72X0R52 - layer problems* P$ b! ~. H; @! F
    ERROR: Unable to issue shapes for padstack SHAPE_C1R025_C1R625 - layer problems
    5 V! C2 m9 j5 }2 ?! O% z% YERROR: Unable to issue shapes for padstack S_S4R15 - layer problems( R% S" X2 k. m/ y$ q! w8 F
    ERROR: Unable to issue shapes for padstack S_R0R20X0R50 - layer problems
    & X, o. P. i0 j. z5 uERROR: Unable to issue shapes for padstack S_0R50X0R20 - layer problems
    1 K  k* p2 a# N& K# H* ?- P0 s4 QERROR: Unable to issue shapes for padstack S_R1R00X0R25 - layer problems. \. `0 ]5 O- I) ^0 ~
    ERROR: Unable to issue shapes for padstack S_R3R60X6R40 - layer problems
    & C" p" P1 {7 [8 ~ERROR: Unable to issue shapes for padstack 0402PAD - layer problems
    ; e: v0 _% ?- W9 uERROR: Unable to issue shapes for padstack S_R0R50X1R00 - layer problems. u! ^6 X) I& G3 ^5 `
    ERROR: Unable to issue shapes for padstack S_S1R90 - layer problems
    . a7 e2 b8 R. @/ I4 `7 `$ i+ @6 zERROR: Unable to issue shapes for padstack S_R1R80X0R95 - layer problems
    ' B5 {9 ^) s' ?* V% JERROR: Unable to issue shapes for padstack S_R0R90X0R80 - layer problems) ^! C8 w( ?5 I6 W
    ERROR: Unable to issue shapes for padstack P_O1R10X0R65_O2R10X1R45 - layer problems9 Z( c) X6 O0 I7 Q
    ERROR: Unable to issue shapes for padstack P_C0R65_O1R50X1R25 - layer problems
    , o/ s; c! n( J0 h, |) E7 zERROR: Unable to issue shapes for padstack S_R1R00X1R27 - layer problems0 V9 U  ~7 c- L9 i" J$ I$ F8 w1 e$ x
    ERROR: Unable to issue shapes for padstack P_C1R05_C1R65 - layer problems4 @8 F3 ]( m7 o3 [# r
    ERROR: Unable to issue shapes for padstack S_R0R60X0R80 - layer problems
    , _0 }9 @9 d- I5 E: DERROR: Unable to issue shapes for padstack S_R1R20X1R70 - layer problems# {" {5 Z9 R) e9 B; E
    ERROR: Unable to issue shapes for padstack S_R3R10X2R31 - layer problems
    7 i1 I8 b) ~: n$ M2 HERROR: Unable to issue shapes for padstack S_R0R76X1R93 - layer problems4 @5 C  \- Z2 a5 e( A/ r
    ERROR: Unable to issue shapes for padstack S_O0R76X1R93 - layer problems9 t: e: J( Y% ?0 {0 v
    ERROR: Unable to issue shapes for padstack S_S4R40 - layer problems9 @! W2 T! R9 |; u
    ERROR: Unable to issue shapes for padstack S_R0R80X0R20 - layer problems) A3 ?, y! p: [6 H: P
    ERROR: Unable to issue shapes for padstack S_R0R20X0R80 - layer problems, y* p: Z9 |) D4 a% a/ X% x% J, d
    ERROR: Unable to issue shapes for padstack S_O0R20X0R80 - layer problems( N& K% Z. ]+ B& P1 H. L0 w- V9 ^8 e
    ERROR: Unable to issue shapes for padstack S_R1R00X0R70 - layer problems
    5 B+ [" k8 `. E2 i1 XERROR: Unable to issue shapes for padstack P_C1R00_C1R00_NP - layer problems
    " H: C$ d5 j- O: z3 RERROR: Unable to issue shapes for padstack P_C1R40_C1R40_NP - layer problems
    ! ?- ~% ?. H2 x8 |% H  y& wERROR: Unable to issue shapes for padstack S_R0R76X2R05 - layer problems
    0 a) t& m2 g  n$ a+ qERROR: Unable to issue shapes for padstack S_R0R70X3R00 - layer problems
    3 F1 e) p# ^( b1 f' ~/ lERROR: Unable to issue shapes for padstack S_R1R50X2R30 - layer problems! T7 J* W! V* {2 t/ c, X) N
    ERROR: Unable to issue shapes for padstack S_R0R80X1R20 - layer problems6 A  y& C' R* \
    ERROR: Unable to issue shapes for padstack S_R1R90X2R50 - layer problems
    3 U/ L1 G9 Z% K4 `ERROR: Unable to issue shapes for padstack S_R1R016X1R625 - layer problems' V$ M. N7 {' o6 }7 k
    ERROR: Unable to issue shapes for padstack P_C1R00_O1R80X2R00 - layer problems
    7 `4 {: l' R/ y4 eERROR: Unable to issue shapes for padstack S_C0R80 - layer problems: Z& r( h4 V+ q$ t- U
    ERROR: Unable to issue shapes for padstack S_O0R48X1R30 - layer problems3 X9 `  c, F6 E4 C# e* \
    ERROR: Unable to issue shapes for padstack S_R0R48X1R30 - layer problems2 Q" E/ J8 t, |4 I7 F+ q
    ERROR: Unable to issue shapes for padstack P_C0R75_C0R75_NP - layer problems/ J8 e4 x% U' t! }3 d) n
    ERROR: Unable to issue shapes for padstack S_R1R20X0R50 - layer problems9 H, P& F; P; m4 I% s$ V
    ERROR: Unable to issue shapes for padstack S_R3R50X4R30 - layer problems
    4 g! L7 M7 |+ ], kERROR: Unable to issue shapes for padstack S_O1R90X0R70 - layer problems
    3 H9 U9 \, J! t. z" q" K$ YERROR: Unable to issue shapes for padstack S_R1R90X0R70 - layer problems
    3 |/ d% u9 |8 y0 B- @: |- iERROR: Unable to issue shapes for padstack P_C0R50_C0R50_NP - layer problems7 f7 \$ `2 G& k$ a$ G5 ~
    ERROR: Unable to issue shapes for padstack S_R2R00X4R00 - layer problems% g) V! O# c4 h
    ERROR: Unable to issue shapes for padstack S_S2R20 - layer problems! W' G& L# O" x' Q9 B- C
    ERROR: Unable to issue shapes for padstack S_R2R286X0R508 - layer problems8 X9 Y' _* j$ G3 K
    ERROR: Unable to issue shapes for padstack P_C0R90_C0R90_NP - layer problems
    " {3 R3 h* B& `$ m; R2 xERROR: Unable to issue shapes for padstack 0402_via - layer problems! g# F0 m. u+ O) }9 Y3 [
    % }+ V3 b: m) i/ eERROR: Unable to issue shapes for padstack 03502 - layer problems
    4 g/ t' o' k0 B9 Y$ @9 oWARNING: layer internal_pad_def not found in layer table.  Check the Allegro cross-section!
    $ `( z: o* y4 P- SWARNING: layer ~TSM not found in layer table.  Check the Allegro cross-section!& H4 ~- a" X; h" t+ t. d
    % T7 x% M4 O! bWARNING: layer ~TPM not found in layer table.  Check the Allegro cross-section!
    ( {' f3 l' B0 I: ~WARNING: layer ~BPM not found in layer table.  Check the Allegro cross-section!! q* x& x5 o% B. D6 Q! F
    WARNING: layer ~TFM not found in layer table.  Check the Allegro cross-section!9 x5 k8 U8 v, |5 w8 V" j
    WARNING: layer ~BFM not found in layer table.  Check the Allegro cross-section!5 U2 }0 z: s0 b
    $ @3 v9 n2 d2 m% R也遇到上面的问题,哪位大侠帮忙看看怎么解决,谢谢!!!用Allegro 16.3版本的PCB文件,转成PADS VX2.3, 报错。  H0 _+ d  ]  S  \5 Q
    21#
    发表于 2020-11-19 01:00 | 只看该作者
    顶上去 谁能解决ERROR: Unable to issue shapes for padstack 0402_via - layer problems5 A& w( ~( e# g1 K: U, J6 R* u4 y+ b! @: B" X
    ERROR: Unable to issue shapes for padstack 0503_via - layer problems( j4 J7 u# [0 a$ ^. Q6 a. F: l/ `% U7 Q. Z: f" N
    ERROR: Unable to issue shapes for padstack 03502 - layer problems这问题啊 ?我也遇到这种情况
    2023-12-8 15:41
  • 签到天数: 159 天
    [LV.7]常住居民III
    22#
    发表于 2021-4-30 10:03 | 只看该作者
    今天我也转不成功了,求教Techfile conversion failed
    2023-12-8 15:41
  • 签到天数: 159 天
    [LV.7]常住居民III
    23#
    发表于 2021-4-30 10:16 | 只看该作者
    0 g# m& [- g6 Q1 k. uextracting Layer Stackup
      O" I# h# O8 H) Gextracting Design Rules3 S, @% z4 K; i( X
    9 o% U7 L* w5 _1 k, x1 kDeleting Existing Props File
    9 B5 |0 V! F2 R, p2 H, b, gDeleting Existing Board Items File
    / t4 ^5 i2 |- KExporting Electrical Constraints...+ ?9 B. H0 y  k. a% a5 Z
    Reading report definition file 'D:/Cadence/SPB_16.6/share/pcb/signal/reports.dat'.
    8 j' h! l( w; J) e% AFinished reading report definition file successfully.
    9 m8 K! q9 g2 v  O+ DReading report definition file 'D:/Cadence/SPB_16.6/share/pcb/signal/custom_rep.dat'.
    * {9 Y. q5 A1 l2 g/ dFinished reading report definition file successfully." z2 F6 J$ z1 x  K
    deleting old device files7 Z8 e+ d4 B% J$ w; V
    extracting device files; T  f4 ?2 E1 R: p( @
      U9 d" A; C* H+ `: f6 [extracting Board Extent, ~1 i" T/ [9 z* ]
    extracting padstacks0 _/ h& N$ \, t& S" q4 u
    extracting padstack completed
    ( g0 F7 v, C/ Q! Sextracting Placement
    ' c- P+ X2 F4 T7 \) g* Uleaving placement0 M) y& p3 L0 U% b
    extracting Device Pads
    4 _  ^: U' l3 Edevices pads extraction completed
    , T9 v- m3 D- r1 m) ?extracting Board Areas
    * O! [/ ~" \5 J2 |/ h/ v1 pLoading skillExt.cxt : j0 _' z# Z! r" `( \. M2 E
    Starting report...
    " P* {) _8 }% j( v% L" Mreport completed successfully, use Viewlog to review the log file.4 P$ w1 J" t6 x0 k$ s0 k/ A( `
    report completed successfully, use Viewlog to review the log file.8 i# w' P( l/ g* Q
    Exporting net information.$ j/ n7 g: O, B5 v; N
    There are no component properties in this database.
    3 u$ N% q7 i: N6 j0 ?. l, eThere are 203 different net properties in this database.
    ; \( o+ a$ D6 X  MHierarchical net constraints have been flattened onto individual nets for export.
    6 ?2 R8 ]+ C' x. r" X8 vThere are 5 different pin properties in this database.$ N" E' k5 ~' I8 k; E; i3 |, O
    C:/Users/Administrator/Desktop/1/DXF_MGC/Work/propdelay_raw.tmp has been created.
    7 [8 s$ N% f; C: ^$ l3 X; s; rLoading cmds.cxt - W8 w! Q7 {) \) R
    * 143 error(s) generated, view interfacelog.txt
    8 }7 \7 D( F+ p: s4 B' |C:/Users/Administrator/Desktop/1/DXF_MGC/Work/LayoutDB.dfl Output Complete./ E9 {8 U& S" `& V1 i
    Generating Padstack HKP FIle.: x6 N/ h5 }/ D/ ~5 K
    , ]. d# N# n! B- o' rCreate .PAD Definitions.6 j$ y, y% j) a% |2 C( U; m  D& i
    Create .HOLE Definitions.  i2 e& O& Z& P* n. s5 ]# _6 A8 g
    Create .PADSTACK Definitions.
    + V; h6 o/ m6 s6 }. Q  Z5 uGenerating Cell HKP File.
    ) d5 o+ y8 v" O$ z6 g9 ` ---------------------------
    - a/ B4 r4 s. E+ v& }7 C; x& WInfo: Database transaction started.4 A% N1 I' ~# \. ?: u$ i9 d
    Cell HKP Added temp instance of symbol: "SOP127P600X155-9L"8 {- u" A) [  c0 g5 @
    Cell HKP Added temp instance of symbol: "CAPC3216"
    / a+ {0 I$ y# }/ x- C5 J. }Cell HKP Added temp instance of symbol: "SOP127P790X200-8L"; _* a/ U: A! Y" O
    Cell HKP Added temp instance of symbol: "INDC1608"# L$ F% _8 N& Q% J1 g" m0 v
    Cell HKP Added temp instance of symbol: "CON3-2D54_V1"* C2 D% h/ |* u8 J; A6 E) j# h2 t6 X$ N
    Cell HKP Added temp instance of symbol: "CRYSTAL-GND"6 z- |# ~) p; F& [) j% \. F
    Cell HKP Added temp instance of symbol: "RESC1608"1 `* W9 c9 ]+ \' B2 w
    Cell HKP Added temp instance of symbol: "R0201") n1 {" M" ?( q/ {. P8 [
    Cell HKP Added temp instance of symbol: "SOP127P600X175-16L"* _/ U% D$ {; D) u/ F' d
    Cell HKP Added temp instance of symbol: "CAPE-2D5-6D3_V0"
    8 G9 E7 U. z: ?0 `1 VCell HKP Added temp instance of symbol: "USBA-H_V1_TP"5 u8 A1 I/ [. R. Q7 r: V
    Cell HKP Added temp instance of symbol: "TP-1D5"3 E( B6 M, h: W0 F; c" f7 k, E
    Cell HKP Added temp instance of symbol: "CA-MCU-736-H4_V0"! e# r2 A3 I" W) G. R1 [6 e8 p
    Cell HKP Added temp instance of symbol: "QFN68-8X8-E6D4"
    # j7 Y$ X! G0 j& h( ^Cell HKP Added temp instance of symbol: "CAPE-2D5-5_V0"3 o& K2 o2 C" N+ |. n1 D6 m& h& F
    Cell HKP Added temp instance of symbol: "SOP50P310X110-10L"
    + I+ Z' L9 c3 t% w4 ?Cell HKP Added temp instance of symbol: "INDWS5X5"4 _3 C& b/ c* g: {4 V
    Cell HKP Added temp instance of symbol: "INDWCM2012"  m+ u9 A' I6 Y2 F+ H+ K' K. L" V
    Cell HKP Added temp instance of symbol: "CAPC2012"
    $ g, c$ j! H8 bCell HKP Added temp instance of symbol: "RESC2012"
    ) _. _, v1 E; `& CCell HKP Added temp instance of symbol: "SOT23-5"
    7 I& Z1 `. a9 f7 I# ZCell HKP Added temp instance of symbol: "QFN16-3X3"' `& d4 q8 w9 a$ `( u
    Cell HKP Added temp instance of symbol: "CAPC1005"/ i1 g; Q6 V5 w
    Cell HKP Added temp instance of symbol: "SW4-V_V0"
    + B6 V1 ?! S3 l+ J/ JCurrent Symbol: SW4-V_V0
    + ?8 |  c- c2 m- ]* O& E6 ^& qCurrent Symbol: IF-02D-MINI_V0_TP* ?% Z+ u# w- T& d- t9 C
    Current Symbol: SENSOR-V7 E$ \# u* x: h
    Current Symbol: CAPC1005
    ) J+ E1 v4 _1 D4 W& d6 X9 BCurrent Symbol: QFN16-3X3) ]* Q. Q* Z' d7 r. ~0 m$ t
    Current Symbol: CON6-2_V1
    / @& N% S7 c, G+ y$ E  Z3 hCurrent Symbol: SOT23-5
    - l. E: z6 p1 }# s- d: j/ N% MCurrent Symbol: MARK
    ! O: |/ d  u0 b9 m3 j3 |Current Symbol: RESC2012
    & y4 e* A3 {( S+ R. FCurrent Symbol: C0201
    ( u/ V8 F% X% b% d$ X; a8 ^( Z/ XCurrent Symbol: LL-345 Y, l" @: m& q  A& K+ }3 }6 i
    Current Symbol: CAPC2012
    / t+ j2 W/ i, ^9 uCurrent Symbol: PCB_PROCESS_REQUIREMENTS* s  A  s1 j' x' i8 O
    Current Symbol: INDWCM2012
    % q! j) Z  R: `Current Symbol: DCPOWER005-2_V0_TP( |) n" e& S2 m3 ^
    Current Symbol: INDWS5X56 t, n+ A! }" k) a
    Current Symbol: SOT223
    + {" A! N. f: S3 V" B" nCurrent Symbol: SOP50P310X110-10L
    0 R; N8 x. s5 GCurrent Symbol: CAPE-2D5-5_V0
    " h8 N( Y" X. C6 T/ a6 xCurrent Symbol: QFN68-8X8-E6D4: M6 r/ v2 L9 f/ `; d3 F, [
    Current Symbol: SOT23+ U" }$ F/ z$ b) J" J4 E1 _
    Current Symbol: CA-MCU-736-H4_V0
    " i, A3 D) V" E) b( ~Current Symbol: TP-1D5
    4 }  F& b! M/ y1 A- oCurrent Symbol: USBA-H_V1_TP
    ' _0 `9 A1 j9 t6 fCurrent Symbol: AV-8D4-3-B_V2_TP: q! \" h8 d3 x/ [
    Current Symbol: SN_6X6
    ( J  \6 F5 A- m5 _8 b  g6 vCurrent Symbol: CAPE-2D5-6D3_V0) m" s0 L$ p$ N& {8 ?" |
    Current Symbol: CON4-2D54_V16 c" d( Q% [' _9 g
    Current Symbol: SOP127P600X175-16L3 y! d3 L' [( I9 n+ k* h
    Current Symbol: R0201
    4 v4 Z: N4 m8 o0 {2 G  vCurrent Symbol: DFN-10
    " b$ {% }5 Z6 oCurrent Symbol: SMA
    6 s& |! L3 z; ~8 s5 W  y' l8 FCurrent Symbol: RESC1608- R9 R, q0 Z' x" t/ v7 k; G
    Current Symbol: INDWS4X4
    3 X2 y- v. `0 r+ F1 |- U/ XCurrent Symbol: SOT23-69 P; V& Q- L% |1 ]2 U
    Current Symbol: LINEAR_DIMENSION* O7 r$ Q7 {0 P+ K' h
    Current Symbol: CRYSTAL-GND$ r# @- X6 m* {
    Current Symbol: SCART-A_V20 h( k, n% {- ~( @5 O
    Current Symbol: CON3-2D54_V12 i- u! G$ o. }: X( ~) y1 q
    Current Symbol: AV3-45_V0_TP
    4 t& ]0 z4 w' t7 D; pCurrent Symbol: INDC1608
    9 Y' v3 q+ C8 i+ QCurrent Symbol: DISPLAY-SINGLEROW_LED-38X10-V
    % f  v: {" ?8 _Current Symbol: HDMI-10D55_V2
    6 Z$ b8 i  l- g+ CCurrent Symbol: SOP127P790X200-8L; U6 p, W) I4 f) }+ |3 u1 O6 a4 u
    Current Symbol: CAPC1608
    3 N' _( G0 _4 n9 r; G- u3 {Current Symbol: RESC1005% O/ d( c3 B  N) b% _2 j
    Current Symbol: CAPC3216% v, K4 L" t! n7 q0 D$ ]
    Current Symbol: SOP127P600X155-9L
    2 L% i' S/ q9 g/ sRemoving temporarily added symbols.
    + n( A6 a2 B, G9 o  D% F% \/ ?24 symbols removed.7 D1 R$ S8 l; \8 L7 Z; {# P0 u6 @9 _
    Creating Net Properties
    / k9 |9 ^" T* [9 s2 _# OCreating Net Class6 n: {  I9 P/ O
    ---------------------- Al2Exp summary ----------------------
    ( j$ s) ?$ f1 ^; NAl2Exp - 143 error(s), 9 warning(s)! b* ?. l. y/ h5 K" o0 d3 i
    Export log file saved at "C:/Users/Administrator/Desktop/1/DXF_MGC\LogFiles\interfacelog.txt" file
    7 P$ z: h; d' x1 U7 `: N% CRun "show log" command to view log file. ^6 [7 j2 G" f0 F
    ------------------------------ Done -------------------------------
    24#
    发表于 2021-10-14 19:45 | 只看该作者
    转不了:o:o
    2022-6-8 15:08
  • 签到天数: 9 天
    [LV.3]偶尔看看II
    25#
    发表于 2021-10-29 15:55 | 只看该作者
    这问题解决了吗?" M' @: C4 N$ M6 S  i) I7 r
    2021-8-19 15:42
  • 签到天数: 21 天
    [LV.4]偶尔看看III
    26#
    发表于 2022-6-11 01:05 | 只看该作者
    ERROR: Unable to issue shapes for padstack THS-0R9_1R5 - layer problems
    ' b: h3 T7 s1 m/ W# sERROR: Unable to issue shapes for padstack SMDS0P5 - layer problems+ [/ P+ c, n  u
    ERROR: Unable to issue shapes for padstack PAD_0R3X2R6_REC - layer problems! Z" S5 W' M  ]! t, B7 Y
    ERROR: Unable to issue shapes for padstack OB150_71X83_36D - layer problems
    6 j' D2 s: t, t1 N+ M' Y5 mERROR: Unable to issue shapes for padstack OB103_63X59_36D - layer problems: d4 O. f- l) z: K' O! c* H9 g) D. [
    ERROR: Unable to issue shapes for padstack PAD_0R3X0R9_REC - layer problems/ A+ |6 S5 M$ B! j  `( Q
    ERROR: Unable to issue shapes for padstack PAD_C0R65_D0R4 - layer problems. A+ U: x- c+ q# [
    ERROR: Unable to issue shapes for padstack HOLE-0R65_mtg - layer problems
    3 X( [  N4 I8 m' N- FERROR: Unable to issue shapes for padstack HOLE_0R65X0R95_OB_mtg - layer problems
    ( }1 x! l7 U4 f5 _" ]8 U) I+ o& QERROR: Unable to issue shapes for padstack OB63_39X43_20D - layer problems) Z4 Q3 b8 s2 r- s
    ERROR: Unable to issue shapes for padstack PAD_1R1X1R8_REC - layer problems. W2 p# H' j, i) P& _6 _. ]
    ERROR: Unable to issue shapes for padstack SMDR1P15X1P45 - layer problems
    . r6 p; S$ R5 U- e. xERROR: Unable to issue shapes for padstack SMDR0P8X0P85 - layer problems& _! I9 h' Q. q8 Z% ]/ n# n' ^
    ERROR: Unable to issue shapes for padstack SMD36_36 - layer problems3 A! x0 [1 H- }2 g3 d3 U" S: s7 Q
    ERROR: Unable to issue shapes for padstack SMD36_50 - layer problems) @: j7 k2 d+ D" m% ~# ^0 o
    ERROR: Unable to issue shapes for padstack PAD_S0R8 - layer problems3 W7 P* E- ?5 s5 H' `. H" K
    ERROR: Unable to issue shapes for padstack PAD_65X118_R - layer problems
    / a) ^* i  Q5 O8 `ERROR: Unable to issue shapes for padstack PAD_20X24 - layer problems
    6 t4 O2 j8 J5 E1 i% L6 Z* z1 {ERROR: Unable to issue shapes for padstack PAD_14X44 - layer problems
    $ k, l# U+ _+ N* zERROR: Unable to issue shapes for padstack OB75_91X28_61D - layer problems
    + g$ k1 |( V; U7 q8 L5 e* AERROR: Unable to issue shapes for padstack OB63_47X33_24D - layer problems6 `6 F* q) h3 s( F
    ERROR: Unable to issue shapes for padstack RE63_47X33_24D - layer problems: k. _, O/ g9 u  {
    ERROR: Unable to issue shapes for padstack HOLE-1R3 - layer problems. Z( O) m! z- r: w  f, _
    ERROR: Unable to issue shapes for padstack THC-OR9_1R5 - layer problems
    # ]* x- e  a) i- Q4 w5 V, WERROR: Unable to issue shapes for padstack PAD_53X102 - layer problems5 K. a" z/ r# [
    ERROR: Unable to issue shapes for padstack PAD_S34 - layer problems
    7 {) h. K5 F, j) l- K5 [8 a: |$ FERROR: Unable to issue shapes for padstack PAD_16X20_R - layer problems
    ( j4 Y# C  D4 J' \% n, F6 D% ?ERROR: Unable to issue shapes for padstack SMD12_35OB - layer problems
    & i, v# Q4 P7 t! ~$ E' cERROR: Unable to issue shapes for padstack PAD_S24 - layer problems( @$ m9 N0 x3 |7 `  o- z7 V0 g
    ERROR: Unable to issue shapes for padstack PAD_O24X47 - layer problems0 ]4 U; h' T' B- C. l3 e8 _5 @
    ERROR: Unable to issue shapes for padstack SMDO0P6X1P8 - layer problems
    % K) r$ ~' X9 z0 \) K! G! w: CERROR: Unable to issue shapes for padstack PAD_1X0D22_R - layer problems( @1 ?& g& h) x2 L/ j" N
    ERROR: Unable to issue shapes for padstack THS-2R0_6R3 - layer problems
    ; B2 b! b* \, R/ Y3 OERROR: Unable to issue shapes for padstack PAD_8X39 - layer problems% E- j: V( i2 C) O) i2 o; ]
    ERROR: Unable to issue shapes for padstack PAD_14X62_R - layer problems
    & k4 k/ I9 M) u, dERROR: Unable to issue shapes for padstack THS-1R5_3R78 - layer problems
    , H4 f/ F7 O- [# F1 W9 I) TERROR: Unable to issue shapes for padstack PAD_10X60OB - layer problems. k( y1 e) i4 Z" M& }: y, a( s* @
    ERROR: Unable to issue shapes for padstack THS-2R5_7R75 - layer problems3 ]2 Y& K$ c+ G8 s! O. b) E. o
    ERROR: Unable to issue shapes for padstack PAD_8X25 - layer problems: F# x/ j( S1 Y- j+ G
    ERROR: Unable to issue shapes for padstack PAD_S2R7_D1R2 - layer problems
    2 i1 ]4 v' v' z* g/ n1 I1 \ERROR: Unable to issue shapes for padstack SMD55X10 - layer problems
    3 e0 r9 _. M- h" a: p8 x5 k- o- kERROR: Unable to issue shapes for padstack PAD_10X30_OB - layer problems
    + a! M, ~+ i& z6 ?  \$ Y0 L; dERROR: Unable to issue shapes for padstack PAD_S130-CIR59D - layer problems9 ?! ~% L4 K- |0 R# i
    ERROR: Unable to issue shapes for padstack PAD_12X63_R - layer problems4 w7 z6 g7 H7 F- t" Q
    ERROR: Unable to issue shapes for padstack PAD_10X55 - layer problems
    + ?/ \8 }( }! \9 VERROR: Unable to issue shapes for padstack PAD_12X55 - layer problems
    ; `- D9 T$ B4 v. U. m% T, F8 JERROR: Unable to issue shapes for padstack PAD_52X40 - layer problems9 w1 r- Q- }) L8 T' F
    ERROR: Unable to issue shapes for padstack HOLE_3 - layer problems- C' H: E$ P' S4 n3 k3 U) ~% d
    ERROR: Unable to issue shapes for padstack 4-65MM - layer problems
    * W/ S& O9 n( x1 mERROR: Unable to issue shapes for padstack 2-7MM - layer problems
    % a; F& T( X1 F, ?ERROR: Unable to issue shapes for padstack 3MM - layer problems- ]5 a4 A- F$ f. I/ l9 {; R; w
    ERROR: Unable to issue shapes for padstack ID-BOARD - layer problems
    % a1 B, P& Q8 zERROR: Unable to issue shapes for padstack PAD315CIR158D - layer problems
    & n. {, Y6 W9 }. V4 d; K4 CERROR: Unable to issue shapes for padstack PAD79CIR40D - layer problems
    7 w8 r8 T) I2 c# kERROR: Unable to issue shapes for padstack THC60D40 - layer problems+ K8 X4 y# X3 Q7 c% z  K% u7 f3 P
    ERROR: Unable to issue shapes for padstack THC80D55 - layer problems
    # B; r& z! P9 ^$ ]ERROR: Unable to issue shapes for padstack OB118_61X79_32D - layer problems
    / ^; d/ d! M' R0 F5 U" ?& DERROR: Unable to issue shapes for padstack OB118_55X79_24D - layer problems
    $ F5 S2 u0 O+ ^. M0 O: r  B& KERROR: Unable to issue shapes for padstack SMDS2P4 - layer problems$ c5 N  V. C$ u; o
    ERROR: Unable to issue shapes for padstack PAD_S3R0_D1R4 - layer problems+ g6 h, S3 T! h  n  o
    ERROR: Unable to issue shapes for padstack OB208_81X118_31D - layer problems
    & b) R3 h! L: mERROR: Unable to issue shapes for padstack OB150_71X80_31D - layer problems
    ' z2 `+ S( E( {6 o7 |: @ERROR: Unable to issue shapes for padstack VIA-GEN_12_24_via - layer problems. b) A6 e2 G% g
    ERROR: Unable to issue shapes for padstack VIA-GEN_16_28_DBFIX1_via - layer problems( L7 v, t* V% I& C2 s% d
    ERROR: Unable to issue shapes for padstack VIA-GEN_14_28_via - layer problems' z. W6 Z& q) ?
    ERROR: Unable to issue shapes for padstack VIA10-20_GEN_via - layer problems
    . q, X2 f3 l5 ~1 [ERROR: Unable to issue shapes for padstack PAD_40X71 - layer problems: I# D5 m) ]1 |& ?, X  `: J
    ERROR: Unable to issue shapes for padstack PAD_28X36_R - layer problems% P5 a; Y& J$ Y8 p0 A
    ERROR: Unable to issue shapes for padstack SMD10X55 - layer problems, _; N2 e3 Q% L
    ERROR: Unable to issue shapes for padstack VIA-GEN_16_28_via - layer problems9 p- _! {9 Z! }$ P& }- M
    ERROR: Unable to issue shapes for padstack OB70_50X50_25D - layer problems
    + H5 X) V. W4 h- mERROR: Unable to issue shapes for padstack RE70_50X50_25D - layer problems
    7 j& {* `* b5 H, \ERROR: Unable to issue shapes for padstack PAD_S2R7 - layer problems) M# d' E6 ?+ d0 ^+ b3 W
    ERROR: Unable to issue shapes for padstack PAD_2R7X3R2_REC - layer problems
    * C" u+ e7 X. W$ rERROR: Unable to issue shapes for padstack PAD_0R3X1R7_REC - layer problems
    4 q3 }, Y6 K, TERROR: Unable to issue shapes for padstack THS-1R2_6R3 - layer problems
    - R1 E/ H8 g' M6 LERROR: Unable to issue shapes for padstack THS-1R2_3R78 - layer problems
    * {/ W- r% j9 Q% ^4 q- ]) [ERROR: Unable to issue shapes for padstack PAD_50X60 - layer problems9 r; h* b, L/ `  H  K
    ERROR: Unable to issue shapes for padstack PAD_10X42 - layer problems
    # z$ Y, r& M' V# O! F! bERROR: Unable to issue shapes for padstack PAD_S8_VIA2R5 - layer problems
    ; M. ~+ Z' F) g2 f; \% CERROR: Unable to issue shapes for padstack SMDR0P6X1P8 - layer problems& C: N  z( a+ T7 d" j
    ERROR: Unable to issue shapes for padstack HOLE_C4R2-D2R5 - layer problems7 @6 q0 y* m2 b; k( _& V
    2 d! o0 c  b' o$ TERROR: Unable to issue shapes for padstack VIA-GEN_12_24_via - layer problems
    & f4 l. ]5 [  z$ `* n/ a) vERROR: Unable to issue shapes for padstack VIA-GEN_16_28_via - layer problems
    ) L  ]% |0 u1 V" yWARNING: layer internal_pad_def not found in layer table.  Check the Allegro cross-section!
    8 t! z8 s2 W. K3 x$ ^" ~WARNING: layer ~TSM not found in layer table.  Check the Allegro cross-section!
    7 Q1 O* e% F# |/ iWARNING: layer ~BSM not found in layer table.  Check the Allegro cross-section!: S& V! ]( t5 Q2 {9 o  [
    WARNING: layer ~TPM not found in layer table.  Check the Allegro cross-section!) }1 M& w# h8 ?4 U. P" s
    $ a' }: ^, @6 m( m0 N1 GWARNING: layer ~TFM not found in layer table.  Check the Allegro cross-section!
    ; O# M5 h- v1 j4 fWARNING: layer ~BFM not found in layer table.  Check the Allegro cross-section!5 z: ]7 K" {( W9 r3 C* v7 c
    ' u5 J6 }3 l" C
    都是有问题。软件为PADS VX2.3 和ALLEGRO PCB 16.6
    请教下有方法解决问题嘛?我导入提示层不匹配,不晓得怎么解决  详情 回复 发表于 2022-6-29 22:00
    2022-12-29 15:40
    27#
    发表于 2022-6-29 22:00 | 只看该作者
    szkalwa 发表于 2022-6-11 01:05
    # x* a$ ~2 a$ L4 YERROR: Unable to issue shapes for padstack THS-0R9_1R5 - layer problems
    , p: Z1 ^3 J0 B4 z" p8 ?ERROR: Unable to issue shap ...
    / F7 X) M  B- T) v9 I7 X
    + Y# h5 G3 i; v% ^
    搞定了。打开16.6时,不要选GXL,要选XL这个。 进入再去操作就OK了! 输入粘贴:skill load "D:\\spb_data\\pcbenv\\dfl_main.il" 回车后,返回t, 最后输入 main out 点转换, 如下图无错误即为OK! 哎,折腾这  详情 回复 发表于 2022-7-20 14:11
    2021-8-19 15:42
  • 签到天数: 21 天
    [LV.4]偶尔看看III
    28#
    发表于 2022-7-20 14:11 | 只看该作者
    peng2016 发表于 2022-6-29 22:00& C: H5 I0 ?5 H
    / S5 w- C* B2 N8 d) [* m
    6 {3 }! y) C& ^1 _进入再去操作就OK了!1 {, X% t$ z- c0 O$ i& O
    ' i$ j% X$ Q' {$ e1 f最后输入 main out 点转换,. _3 z% o) o: H7 H
    如下图无错误即为OK!; D7 c% I+ z% c: u
    哎,折腾这么久全靠自摸。。。。。。/ E: s* F" m; S* d- @
    1 u0 w4 p  {9 {8 n3 U, Q  U
    我也是勾选的XL,也是导不进去,奇了怪了  详情 回复 发表于 2022-7-21 09:35
    2022-12-29 15:40
    29#
    发表于 2022-7-21 09:35 | 只看该作者
    szkalwa 发表于 2022-7-20 14:11. ?% s! v& D+ g" n
    3 S% ^$ ^( F6 W6 a6 w+ |9 _/ ^进入再去操作就OK了!( I( c! b- g0 j- _: I
    输入粘贴:skill load "D:\\spb_d ...
    & y% J- `* W/ N' O9 R0 b1 x
    我也是勾选的XL,也是导不进去,奇了怪了: ^$ d9 |- a4 \
    文件路径弄短一点,比如D:\SPB_Data 下面建个英文的文件夹即可 另外注意PADS导入时 BRD文件格式,下拉会有二个 brd后缀的,刚开始我搞错,不小心选成另一个Eagle的! [attachimg]353566[/attachimg]  详情 回复 发表于 2022-7-25 09:57
    2021-8-19 15:42
  • 签到天数: 21 天
    [LV.4]偶尔看看III
    30#
    发表于 2022-7-25 09:57 | 只看该作者
    peng2016 发表于 2022-7-21 09:35( ~2 d& i; n9 k
    # }! x. g- Q0 ]6 J, ]. r文件路径弄短一点,比如D:\SPB_Data  下面建个英文的文件夹即可
    - X" h8 m) L$ n  Z) N6 e7 ^另外注意PADS导入时 BRD文件格式,下拉会有二个 brd后缀的,刚开始我搞错,不小心选成另一个Eagle的!$ N0 y8 {1 p- t' h3 @8 E' \
    6 f7 s: m; [* {/ ?+ \' w; c% G7 |
    GMT+8, 2025-4-28 16:45 , Processed in 0.093750 second(s), 22 queries , Gzip On.
